查看: 1299|回复: 4
求答疑
发表于 2023-10-19 08:50:46 | 显示全部楼层 |阅读模式
大神帮忙看下如何去掉尾部的nil?
 楼主| 发表于 2023-10-19 08:58:35 | 显示全部楼层
(defun c:bz()
   (setvar "cmdecho" 0)
   (setq en (entsel "\n 选取尺寸标注"))
   (setq I 0)
   (while (/= en nil)
          (setq DM  (entget (car en)))
             (setq x (cdr(assoc 42 DM)))
                (princ x)
             (princ \n)
             (setq I (+ 1 I))
        (setq en (entsel "\n 选取下一个尺寸标注"))
  (princ "\n 共选取")(princ I)(princ "个尺寸标注")
  (prin1)
发表于 2023-10-19 09:44:37 | 显示全部楼层
试试下面的:
(defun c:bz()
        (setq I 0)
        (while (/= en nil)
                (princ x)
                (setq I (+ 1 I))
  (prin1)
发表于 2023-10-19 14:34:32 | 显示全部楼层
(defun c:bz(/ i en dm x )
   (setq I 0)
   (while (setq en (entsel "\n 选取尺寸标注"))
                (print x)
             (setq I (+ 1 I))
  (print (strcat  "共选取" (rtos I ) "个尺寸标注"))
 楼主| 发表于 2023-10-19 20:10:47 | 显示全部楼层
sowin 发表于 2023-10-19 09:44
试试下面的:
(defun c:bz()
多谢,语法错误
(princ \n)   nil
(princ "\n")
GMT+8, 2025-5-24 11:45 , Processed in 0.167974 second(s), 23 queries , Gzip On.
