查看: 1367|回复: 5
[提问] 各位大神看下,求 输入TT 提示框选图纸,框选后右键确认后,提示点击插入点,点击确...
发表于 2023-10-28 11:51:02 | 显示全部楼层 |阅读模式
求 输入TT 提示框选图纸,框选后右键确认后,提示点击插入点,点击确人后吧图纸移动到0,0点
 楼主| 发表于 2023-10-28 12:21:25 | 显示全部楼层
(defun c:tt (/ b c doc lays p p0)
        (princ "\n选择对象")
        (if (and (ssget)
                                (setq p (getpoint "\n点取基点:"))
                                (setq p (vlax-3D-point p))
                                (setq p0 (vlax-3D-point 0 0 0))
                        (setq doc (vla-get-ActiveDocument(vlax-get-acad-object)))
                        (setq lays (vla-get-Layers doc))
                        (vlax-for a (vla-get-activeselectionset doc)
                                (setq b (vla-Item lays (vla-get-Layer a)))
                                (setq c (vla-get-Lock b))
                                (vla-put-Lock b :vlax-false)
                                (vla-Move a p p0)
                                (vla-put-Lock b c)
)波总代码
发表于 2023-10-28 16:20:22 | 显示全部楼层
(defun c:tt ()
  (princ "\n选择对象: ")
  (if (and (setq ss (ssget))(setq p0 (getpoint "\n移动基点: ")))
    (command "move" ss "" "non" p0 "non" '(0 0))
 楼主| 发表于 2023-10-28 16:21:30 | 显示全部楼层
xyp1964 发表于 2023-10-28 16:20
(defun c:tt ()
  (princ "\n选择对象: ")
  (if (and (setq ss (ssget))(setq p0 (getpoint "\n移动基点 ...
(defun c:tt (/ p s ss)
        (princ "\n选择对象")
        (if (and (setq s (ssget))
                        (vlax-for a (vla-get-Layers (vla-get-ActiveDocument(vlax-get-acad-object)))
                                (setq ss (cons (list a (vla-get-Lock a)) ss))
                        (foreach x ss (vla-put-Lock (car x) :vlax-false))
                        (command "MOVE" s "" "non" p "non" '(0 0))
                        (foreach x ss (apply 'vla-put-Lock x))
        (princ "\n选择对象")
        (if (and (ssget)
                                (vla-Move a p p0)
                                (vla-put-Lock b c)
        (princ "\n选择对象")
        (if (and (ssget)
                                (if (= :vlax-false c)
                                        (vla-Move a p p0)
                                                (vla-Move a p p0)
                                                (vla-put-Lock b c)
累不?  发表于 2023-10-29 13:09
 楼主| 发表于 2023-10-28 16:30:50 | 显示全部楼层
(defun c:tt ()
  (princ "\n选择对象: ")
谢谢派大....
GMT+8, 2025-11-12 05:48 , Processed in 0.201725 second(s), 29 queries , Gzip On.
