[提问] 这个代码错哪了啊?检查了很多遍都找不到原因
发表于 2023-12-5 12:45:48 | 显示全部楼层
  1. (defun c:tt ()
  2.   (defun SubUpd(e dxf val)
  3.     (entmod (subst (cons dxf val)(assoc dxf (entget e))(entget e)))
  4.     (entupd e)
  5.   )
  6.   (if (and (setq rr (getreal "\n输入新半径: "))
  7.            (setq p1 (getpoint "\n选择基点: "))
  8.            (setq p2 (getcorner p1 "\n对角点: "))
  9.            (setq ss (ssget "C" p1 p2 '((0 . "circle"))))
  10.            (setq i -1)
  11.       )
  12.     (while (setq s1 (ssname ss (setq i (1+ i))))(SubUpd s1 40 rr))
  13.   )
  14.   (princ)
  15. )
发表于 2023-12-5 16:06:57 | 显示全部楼层
  1. (defun c:tt (/ r)
  2.         (if (and (setq r (getdist "\n输入或量取新半径:"))
  3.                                 (ssget '((0 . "CIRCLE")))
  4.                         )
  5.                 (vlax-for e (vla-get-activeselectionset (vla-get-ActiveDocument (vlax-get-acad-object)))
  6.                         (vla-put-Radius e r)
  7.                 )
  8.         )
  9. )
代码简洁明了  发表于 2023-12-5 21:04
发表于 2023-12-5 16:18:30 | 显示全部楼层
hhh454 发表于 2023-11-3 23:29
批量更新圆的半径
http://bbs.mjtd.com/forum.php?mod=viewthread&tid=188850&fromuid=363233
(出处: 明 ...
打只苍蝇,不需要研发量子炮吧
发表于 2023-12-5 23:19:21 | 显示全部楼层
  1. (defun c:tt ()  "批量更新圆或圆弧的半径"
  2.   (setq r (Ureal 7 "" "新半径" r))
  3.   (while(setq s(ssget'((0 . "CIRCLE,ARC"))))(xyp-SubUpd s 40 r))
  4.   (princ)
  5. )
GMT+8, 2026-1-7 06:04 , Processed in 0.155785 second(s), 19 queries , Gzip On.
