查看: 3612|回复: 13
[源码] 多点自动连线
发表于 2023-11-6 13:49:31 | 显示全部楼层 |阅读模式
命令:dlx 功能:选中的点按X轴递增的方向依次连接
(defun c:DLX ()
  (setq points (ssget '((0 . "POINT"))))
  (if (zerop (setq num-points (sslength points)))
    (princ "\nNo points selected.")
      (setq sorted-points (list))
      (repeat num-points
        (setq ent (ssname points 0))
        (setq pt (cdr (assoc 10 (entget ent))))
        (setq sorted-points (cons pt sorted-points))
        (setq points (ssdel ent points))
      (setq sorted-points (vl-sort sorted-points (function (lambda (a b) (< (car a) (car b))))))
      (command "_pline")
      (repeat num-points
        (setq pt (car sorted-points))
        (setq sorted-points (cdr sorted-points))
        (command pt)
(整理贴)
发表于 2023-11-6 19:23:37 | 显示全部楼层
  1. (defun c:tt1 ()
  2.   (if (and (setq ss (ssget '((0 . "POINT"))))
  3.            (setq nn (sslength ss))
  4.       )
  5.     (progn
  6.       (setq ptn '() i 0)
  7.       (repeat nn
  8.         (setq pt  (cdr (assoc 10 (entget (ssname ss i))))
  9.               ptn (cons pt ptn)
  10.               i (1+ i)
  11.         )
  12.       )
  13.       (setq ptn (vl-sort ptn '(lambda (a b) (< (car a) (car b)))))
  14.       (command "pline")
  15.       (foreach pt ptn (command pt))
  16.       (command "")
  17.     )
  18.   )
  19.   (princ)
  20. )
  21. (defun c:tt2 (/ ptn)
  22.   (if (setq ss (ssget '((0 . "POINT"))))
  23.     (progn
  24.       (setq i -1)
  25.       (while (setq s1 (ssname ss (setq i (1+ i))))
  26.         (setq ptn (cons (cdr (assoc 10 (entget s1))) ptn))
  27.       )
  28.       (command "pline")
  29.       (foreach pt (vl-sort ptn '(lambda (a b) (< (car a) (car b)))) (command pt))
  30.       (command "")
  31.     )
  32.   )
  33.   (princ)
  34. )
发表于 2023-11-8 23:06:23 | 显示全部楼层
  1. (defun c:tt2 (/ i ss s1 ptn)
  2.   (and(setq i 0 ss(ssget '((0 . "POINT"))))
  3.       (while(setq s1(ssname ss i))
  4.         (setq i(1+ i)
  5.               ptn(cons(cdr(assoc 10 (entget s1)))ptn))
  6.         )
  7.       (entmakex(vl-list*'(0 . "lwpolyline")'(100 . "AcDbEntity")'(100 . "AcDbPolyline")(cons 90(length ptn))
  8.                         (mapcar(function(lambda(x)(cons 10 x)))
  9.                                (vl-sort ptn(function(lambda (a b) (< (car a) (car b))))))))
  10.       )
  11.   )
发表于 2023-11-6 14:45:31 | 显示全部楼层
发表于 2023-11-6 18:40:19 | 显示全部楼层
后面好像少了个空格
 楼主| 发表于 2023-11-7 09:19:07 | 显示全部楼层
大佬对点的处理方式比我的方便太多了,码住学习下
发表于 2023-11-8 18:17:56 | 显示全部楼层
感谢楼主分享
 楼主| 发表于 2023-11-9 11:50:34 | 显示全部楼层
发表于 2023-12-23 05:05:47 | 显示全部楼层
收藏,自动连线
发表于 2023-12-23 09:46:24 | 显示全部楼层
不错的帖子 顶一下
GMT+8, 2025-9-13 05:12 , Processed in 0.187229 second(s), 28 queries , Gzip On.
