查看: 3836|回复: 13
用Excel vba判断某个文件是否已经打开
发表于 2023-11-28 13:13:10 | 显示全部楼层 |阅读模式
请教大家,怎样用Excel vba判断某个dwg文件是否已经打开?
发表于 2024-4-13 20:45:53 | 显示全部楼层
Function IsFileInUse(FileName As String) As Boolean
    Dim ff As Long, ErrNo As Long
    On Error Resume Next
    ff = FreeFile()
    Open FileName For Input Lock Read As #ff
    Close ff
    ErrNo = Err
    On Error GoTo 0
    Select Case ErrNo
        Case 0:
            IsFileInUse = False
        Case 70:
            IsFileInUse = True
        Case Else:
            Error ErrNo
    End Select
End Function
Public Sub CheckFileIsInuse()
     Dim fn As String
    fn = "D:\A.xlsx"
    If dir(fn) = vbNullString Then MsgBox fn & vbNewLine & "not found, please check", vbCritical + vbOKOnly: Exit Sub
    If IsFileInUse(fn) Then
        MsgBox fn & vbNewLine & "is open already", vbCritical + vbOKOnly: Exit Sub
    Else
        MsgBox fn & vbNewLine & "no body open this file", vbInformation + vbOKOnly:
    End If
End Sub
发表于 2023-11-28 14:03:11 | 显示全部楼层
获取打开文档的所有名称,需要获取CAD的appliction
Sub Example_Documents()
    ' This example obtains a reference to the Documents collection
    ' and displays information about the loaded documents.
'此示例获取对Documents集合的引用
'并显示有关已加载文档的信息。
    Dim Document As AcadDocument
    Dim msg As String
    msg = vbCrLf
    ' Cycle through the Documents collection and retrieve the names
    ' of the loaded documents
'循环浏览Documents集合并检索名称
'加载的文档
    For Each Document In Documents
        msg = msg & Document.name & vbCrLf
    Next
    ' Display loaded document information
'显示加载的文档信息
    If Documents.count > 0 Then
        MsgBox "The loaded documents are: " & msg
    Else
        MsgBox "There are no loaded documents!"
    End If
End Sub
发表于 2024-5-22 14:03:54 | 显示全部楼层
'引用FileSystemObject
Public Function IsOccupied(ByVal strFileName As String) As Boolean
Dim Fso As New FileSystemObject, strPath As String
strPath = Replace(LCase(strFileName), ".dwg", ".dw2")
If Fso.FileExists(strPath) = True Then
    Fso.DeleteFile strPath
    If Fso.FileExists(strPath) = True Then IsOccupied = True
End If
End Function
 楼主| 发表于 2023-11-28 17:27:08 | 显示全部楼层
谢谢您的帮助,效果不错。唯一美中不足的是必须在   工具--引用  那里手工引用Autocad 2010类型库,我以前的是不需要的,有办法解决吗,类似的Excel文档很多(比如用代码取代这个过程)
发表于 2023-11-29 09:02:42 | 显示全部楼层
尝试改名,改成功了就说明没被打开,当然要先排除无权限的情况。
 楼主| 发表于 2023-11-30 08:22:05 | 显示全部楼层
谢谢您的关注。不会写这个改名代码,能帮忙写下吗
发表于 2023-12-20 12:08:02 | 显示全部楼层
sunny_8848 发表于 2023-11-28 17:27
谢谢您的帮助,效果不错。唯一美中不足的是必须在   工具--引用  那里手工引用Autocad 2010类型库,我以 ...
不引用的话excel不认识这个类型啊没办法的,而且cad版本不同这个名称也不同,我cad2024是 AutoCAD 2021 Type Library
沙发的代码很经典,遍历类型msg显示名称
你可以自己改下适合自己匹配那个你需要判断的dwg文件名。
 楼主| 发表于 2023-12-20 17:32:48 | 显示全部楼层
谢谢关注,已经放弃这个功能了
 楼主| 发表于 2024-4-29 19:52:31 | 显示全部楼层
    On Error ...
谢谢帮忙。fn = "D:\A.xlsx",您的代码是判断xlxs文件是否已经打开的吗
发表于 2024-5-1 14:46:15 | 显示全部楼层
任意文件不一定是excel文件啊
GMT+8, 2025-12-15 06:11 , Processed in 0.166085 second(s), 24 queries , Gzip On.
