查看: 1014|回复: 1
[提问] 请大神优化公差标注程序
发表于 2023-12-4 15:43:30 | 显示全部楼层 |阅读模式
程序目前能达到功能要求,因为是用 COMMAND 实线 所以命令栏有该提示
不想让命令栏出现这些提示,还有其他函数能达到要求吗?
红色区域的代码需要优化......
以下是源码:
;;快速设置公差
(defun c:gc()
        ;;读取参数文件信息
        (setq TKK_text (open (findfile "GC.dat") "r")     ;打开读取文件   "r"代表读取
                        %sk1 (read-line TKK_text)               ;读取正公差
                        %sk2 (read-line TKK_text)               ;读取负公差
                  %sk3 (read-line TKK_text)               ;读取对称公差比例
                        %sk4 (read-line TKK_text)               ;读取极限公差比例
  (close TKK_text )                                 ;关闭文件
        (setq fname  (vl-filename-mktemp "GC.dcl") f (open fname "w"))
        (write-line "zhuc:dialog   {label=\"快速公差 @ JAYCHOU\";" f)
        (write-line ":boxed_column {label=\"公差值设置\" ;" f)                                                     ;; 分行符
        (write-line ":edit_box{label=\"正公差                 +\";key=\"e01\";edit_width=6;}" f)
        (write-line ":edit_box{label=\"负公差                 -\";key=\"e02\";edit_width=6;}}" f)
        (write-line ":boxed_column {label=\"公差比例设置\" ;" f)
        (write-line ":edit_box{label=\"对称公差标注比例      \";key=\"e03\";edit_width=6;}" f)
        (write-line ":edit_box{label=\"极限公差标注比例      \";key=\"e04\";edit_width=6;}}" f)
        (write-line ":row{:button {label=\"确定\";key=\"e05\";is_default=true;}" f)
        (write-line "     :button {label=\"退出\";is_cancel=true;}}}" f)
        (close f)
        (new_dialog "zhuc" (setq dcl_re (load_dialog fname)))
        (set_tile "e01" %sk1)    ;;正公差
        (set_tile "e02" %sk2)    ;;负公差
        (set_tile "e03" %sk3)    ;;对称公差比例
        (set_tile "e04" %sk4)    ;;极限公差比例
        (mode_tile "e01"  2 )
        (action_tile "e01" "(setq %sk1 (get_tile \"e01\"))")     ;;正公差
        (action_tile "e02" "(setq %sk2 (get_tile \"e02\"))")     ;;负公差
  (action_tile "e03" "(setq %sk3 (get_tile \"e03\"))")     ;;对称公差比例
  (action_tile "e04" "(setq %sk4 (get_tile \"e04\"))")           ;;极限公差比例
        (if (= (start_dialog) 1)
;;                          (vl-registry-write "HKEY_CURRENT_USER\\SOFTWARE\\Autodesk\\AutoCAD" "+gc"    %sk1)
;;                          (vl-registry-write "HKEY_CURRENT_USER\\SOFTWARE\\Autodesk\\AutoCAD" "-gc"    %sk2)
;;写入参数文件信息
        (SETQ TKK_text (OPEN (findfile "GC.dat") "W"))  ;打开读取文件
(close TKK_text)
  (setq TKK_text (open (findfile "GC.dat") "a"))
  (write-line  %sk1    TKK_text)                    ;写入正公差
  (write-line  %sk2    TKK_text)                    ;写入负公差
        (write-line  %sk3    TKK_text)                    ;写入对称公差比例
        (write-line  %sk4    TKK_text)                    ;写入极限公差比例
                          (c:gcc)))
        (unload_dialog dcl_re)
        (vl-file-delete fname)
;;设置公差
(defun c:gcc()
        ;;读取参数文件信息
  (princ "\n命令: 选择标注尺寸:")
        (setq n   (atof %sk1))    ;;将字符串转换为数字
        (setq m   (atof %sk2))    ;;将字符串转换为数字
        (setq bl1 (atof %sk3))    ;;将字符串转换为数字
  (setq bl2 (atof %sk4))    ;;将字符串转换为数字
      (setq k 0)
                        (while (<= k 5)
                                (setq a (fix (* (EXPT 10 (- 5 K)) n)))
                                (setq b (* 10 (fix (* (expt 10 (- 4 k)) n))))
                                (setq k1 (- 5 k))
                                (IF        (= a b)
                                        (SETQ K (+ K 1))
                                        (setq K 6)
                        (setq k 0)
                        (while (<= k 5)
                                (setq a (fix (* (EXPT 10 (- 5 K)) M)))
                                (setq b (* 10 (fix (* (expt 10 (- 4 K)) M))))
                                (SETQ K2 (- 5 k))
                                (IF        (= a b)
                                        (SETQ K (+ K 1))
                                        (setq K 6)
                        (setQ d2 (max K1 K2))
                        (if (= n m)
                                (setq c bl1)      ;;对称公差比例
                                (setq c bl2)      ;;极限公差比例
                        (if (and (= n 0) (= m 0))
                                (COMMAND "_DIMOVERRIDE" "dimtol" "off" "")
        (while          (setq ss (ssget ":S" '((0 . "DIMENSION"))))
                                        (COMMAND "_DIMOVERRIDE"           "DIMTP"    n                 "DIMTM"
                                        M                "DIMTOL"   "ON"              "DIMTFAC"         c
                                        "DIMTDEC"        D2         "DIMTZIN" 8  ""  SS  ""
;;中间这段代码也可以写公差,但是不能调整公差精度和大小比例
;;        (defun vla-ssname (ss index)
;;                (vlax-ename->vla-object (ssname ss index))
;;  (while (setq ss (ssget ":S" '((0 . "DIMENSION"))))
;;                (repeat (setq i (sslength ss))
;;                        (setq vobj (vla-ssname ss (setq i (1- i))))
;;                        (vla-put-ToleranceDisplay vobj acTolDeviation)
;;                        (vla-put-ToleranceUpperLimit vobj %sk1)
;;                        (vla-put-ToleranceLowerLimit vobj %sk2)
        (c:gcc)
发表于 2025-2-28 22:45:47 | 显示全部楼层
帮顶了,一直在找一款公关标注工具。
GMT+8, 2025-5-1 09:41 , Processed in 0.170757 second(s), 25 queries , Gzip On.
