查看: 905|回复: 3
[提问] 文字样式对话框怎样才能插入自定义对话框
发表于 2023-12-4 17:21:37 | 显示全部楼层 |阅读模式
文字样式对话框的插入形式。
(defun c:test()
  (setq f (vl-filename-mktemp "test.dcl"))
  (setq of (open f "w"))
  (write-line "test : dialog {" of)
  (write-line "label = \"试验\" ;" of)
  (write-line ":button {key = \"m\"; label = \"文字样式\";}" of)
  (write-line "ok_only;" of)
  (write-line "}" of)
  (close of)
  (setq dcl_id (load_dialog f))
  (new_dialog "test" dcl_id)
  (action_tile "m" "(vl-cmdf \"_.STYLE\")")
  (action_tile "accept" "(done_dialog 1)")
  (start_dialog)
  (unload_dialog dcl_id)
  (vl-file-delete f)
自定义插入对话框无论何种形式,command或vl-cmdf均会产生错误
VEVAL-STR+ ARX 命令中发生异常
Unhandled Exception e06d7363 (e06d7363h) at address fd10be0dh
未处理的异常 e06d7363(e06d7363h) ,地址 fd10be0dh
发表于 2023-12-4 18:47:12 | 显示全部楼层
  1. (defun c:test()
  2.   (setq f (vl-filename-mktemp "test.dcl"))
  3.   (setq of (open f "w"))
  4.   (write-line "test : dialog {" of)
  5.   (write-line "label = "试验" ;" of)
  6.   (write-line ":button {key = "m"; label = "文字样式";}" of)
  7.   (write-line "ok_only;" of)
  8.   (write-line "}" of)
  9.   (close of)
  10.   (setq dcl_id (load_dialog f))
  11.   (new_dialog "test" dcl_id)
  12.   (action_tile "m" "(done_dialog 2)")
  13.   (action_tile "accept" "(done_dialog 1)")
  14.   (SETQ DD(start_dialog))
  15.   (IF (= DD 2)(T1))
  16.   (unload_dialog dcl_id)
  17.   (vl-file-delete f)
  18.   )
  19. (DEFUN T1()
  20.   (vl-cmdf "_.STYLE"))
 楼主| 发表于 2023-12-4 19:46:14 | 显示全部楼层
象上面那样对话框重叠放置的有没有方法?
发表于 2023-12-6 17:47:50 | 显示全部楼层
zdqwy19 发表于 2023-12-4 19:46
象上面那样对话框重叠放置的有没有方法?
不可以调用command 命令,DCL必须是焦点,很多函数无法执行
GMT+8, 2025-2-24 04:52 , Processed in 0.161854 second(s), 26 queries , Gzip On.
