查看: 2253|回复: 7
[源码] 求助:如何实现对象偏移后变虚线?
发表于 2023-12-14 23:28:14 | 显示全部楼层 |阅读模式
大侠们,请问如何实现对象(直线 圆,椭圆 多段线等)偏移后变白色虚线?
(defun c:oset()
  (setq obj (car (entsel "\n选择一个对象: ")))
  (setq offsetDist (prompt "\n输入偏移距离: "))
  (setq resultId (acdbObjectIdNew obj offsetDist))
  (setq es (acdbObjectIdOffset obj offsetDist resultId))
  (if (equal es 0)
    (repeat 5
      (setq entityType (cdr (assoc 0 (acdbObjectIdGetAcDbObjectResultType resultId))))
      (if (equal entityType "LINE")
          (setq p0 (acdbObjectIdGetPointResult resultId 0))
          (setq p1 (acdbObjectIdGetPointResult resultId 1))
          (command "_.dash" p0 p1)
发表于 2023-12-16 10:44:12 | 显示全部楼层
  • (defun c:tt(/ point pyjl s1 s2)
  •   (setq pyjl (getreal "\n输入偏移距离:"))
  •   (while
  •     (setq s1 (entsel "\n 选择对象:"))
  •     (setq point (getpoint "\n指定偏移方向:"))
  •     (command "OFFSET" pyjl s1 "non" point "")
  •     (setq s2 (entlast))
  •     (command "CHANGE" s2 "" "P" "LT" "HIDDEN" "S" "50" "")
  •   (command "REGEN")
  •   (princ)
发表于 2023-12-15 12:26:29 | 显示全部楼层
别指望AI 了 全是错误
发表于 2023-12-15 07:05:25 | 显示全部楼层
偏移成功后,用(setq e (entlast))取得它,然后就可以变虚线了
 楼主| 发表于 2023-12-15 11:56:02 | 显示全部楼层
(defun c:oset()
  (if (equal es 0)
    (repeat 5
 楼主| 发表于 2023-12-15 11:57:25 | 显示全部楼层
请问错误的地方
发表于 2023-12-16 11:23:37 | 显示全部楼层
  •   (while
  • 大佬好!可以再加上偏移几根线吗?谢谢大佬!
    发表于 2023-12-16 12:32:52 来自手机 | 显示全部楼层
    可以的………
    GMT+8, 2025-5-13 23:14 , Processed in 0.198273 second(s), 25 queries , Gzip On.
