查看: 2001|回复: 5
[函数] 提取TEXT/MTEXT内的纯文本,过滤文字样式格式
发表于 2023-12-19 13:32:54 | 显示全部楼层 |阅读模式
  1. (if (null vlax-dump-object) (vl-load-com));;将 Visual LISP 扩展功能加载到 AutoLISP
  2. ;提取多行文字,去除无用格式符号--(一级)----
  3. ;由尘缘一生提供 QQ:15290049
  4. (defun gets-mt (nam / s ob)
  5.   (setq s (vlax-get (vlax-ename->vla-object nam) 'TextString))
  6.   (vlax-put-property (setq ob (vlax-create-object "Vbscript.RegExp")) "IgnoreCase" 0)
  7.   (vlax-put-property ob "Global" 1)
  8.   (setq s
  9.     (mapcar
  10.       '(lambda (x y) (vlax-put-property ob "Pattern" x) (setq s (vlax-invoke-method ob "Replace" s y)))
  11.       '("\\\\\\\\" "\\\\{" "\\\\}" "\\\\p(.[^;]*);" "\\\\S(.[^;]*)(\\^|#|\\\\)(.[^;]*);"
  12.          "(\\\\F|\\\\f|\\\\C|\\\\H|\\\\T|\\\\Q|\\\\W|\\\\A)(.[^;]*);" "(\\\\L|\\\\O|\\\\l|\\\\o)" "\\\\~"
  13.          "\\\\P" "\n" "({|})" "\\x01" "\\x02" "\\x03")
  14.       (list (chr 1) (chr 2) (chr 3) "" "" "" "" "" (chr 0) "" "" "\\" "{" "}")
  15.     )
  16.   )
  17.   (if ob (vlax-release-object ob))
  18.   (last s)
  19. )
  20. ;样例
  21. (defun  c:tt (/ str)
  22.   (setq mtext_name (car(entsel "\n 请选择MTEXT文字:?")))
  23.   (setq str (gets-mt mtext_name))
  24.   str
  25. )
参与人数 2明经币 +2 金钱 +20 收起 理由
USER2128 + 1 赞一个!
kucha007 + 1 + 20 赞一个!
发表于 2023-12-20 00:18:31 | 显示全部楼层
感谢分享代码
发表于 2023-12-20 01:00:05 | 显示全部楼层
感谢楼主分享
发表于 2023-12-20 22:43:12 | 显示全部楼层
MTEXT直接炸开获取更简单明了……
有些炸开就分段了.不好获取吧  发表于 2024-12-26 22:26
发表于 2023-12-25 02:27:24 | 显示全部楼层
天正文字不正持
GMT+8, 2025-5-2 01:32 , Processed in 0.168843 second(s), 26 queries , Gzip On.
