![](source/plugin/imc_colorcode/images/loading.gif) - (defun AllLines(filename / fn tx tmp)
- (setq fn(open filename "r"))
- (while(setq tx(read-line fn))
- (setq tmp(cons tx tmp)))
- (close fn)
- (reverse tmp))
- (defun GetNUmsLine(nlst txts / lines)
- (vl-every(function(lambda(x)(setq lines(cons(nth x txts)lines))))nlst)
- (reverse lines))
- (defun Modlines(ntxts filename / txts fn old)
- (setq txts(AllLines filename)
- old(GetNUmsLine(mapcar(function car)ntxts)txts)
- fn(open filename"w"))
- (vl-every(function(lambda(a b)(setq txts(subst a(cadr b)txts))))old ntxts)
- (write-line(substr(apply'strcat(mapcar(function(lambda(x)(strcat"\n"x)))txts))2)fn)
- (close fn))
- (defun c:tt(/ filename);读取所有行
- (if(setq filename(getfiled""""""4))
- (AllLines filename)))
- (defun c:t1(/ filename nlst);读取指定行
- (GetNUmsLine'(0 7 12)(AllLines filename))))
- (defun c:t2(/ filename ntxts);修改指定行
- (Modlines'((0 "ABC")(7"ABCD")(12"ABCDE"))filename)))
