查看: 2678|回复: 11
[源码] vla方法过滤图元
发表于 2024-1-1 15:39:33 | 显示全部楼层 |阅读模式
  1. (defun $ssget-vla$ (pt1 pt2 filter lst / ss-n ss tmp ents e)
  2.           ;vla选择集
  3. ;示例 :($ssget-vla$ (getpoint)(getpoint)(list(cons 0 "*LINE*"))nil)
  4.   (setq ss-n "SSGET")
  5.   (if filter
  6.     (progn
  7.       (vl-Catch-All-Apply
  8.   'vla-delete
  9.   (LIST
  10.     (vl-Catch-All-Apply
  11.       'vla-item
  12.       (list (vla-get-SelectionSets
  13.         (vla-get-ActiveDocument (vlax-get-acad-object))
  14.       )
  15.       ss-n
  16.       )
  17.     )
  18.   )
  19.       )
  20.       (setq
  21.   ss (vl-Catch-All-Apply
  22.        'vla-add
  23.        (list (vla-get-selectionsets
  24.          (vla-get-activedocument (vlax-get-acad-object))
  25.        )
  26.        ss-n
  27.        )
  28.      )
  29.       )
  30.       (setq
  31.   tmp (mapcar
  32.         (function
  33.     (lambda  (x y)
  34.       (vl-catch-all-apply
  35.         'vlax-make-variant
  36.         (list (vl-catch-all-apply
  37.           'vlax-safearray-fill
  38.           (list (vl-Catch-All-Apply
  39.             'vlax-make-safearray
  40.             (list y (cons 0 (1- (length x))))
  41.           )
  42.           x
  43.           )
  44.         )
  45.         )
  46.       )
  47.     )
  48.         )
  49.         (list (mapcar 'car filter) (mapcar 'cdr filter))
  50.         (list vlax-vbInteger vlax-vbVariant)
  51.       )
  52.       )
  53.       (if (and pt1 pt2)
  54.   (progn
  55.     (setq pt1 (list (car pt1) (cadr pt1) 0))
  56.     (setq pt2 (list (car pt2) (cadr pt2) 0))
  57.     (vl-catch-all-apply
  58.       'vla-select
  59.       (list
  60.         ss
  61.         acSelectionSetCrossing
  62.         (vlax-3d-point pt1)
  63.         (vlax-3d-point pt2)
  64.         (car TMP)
  65.         (cadr TMP)
  66.       )
  67.     )
  68.   )
  69.   (vl-catch-all-apply
  70.     'vla-select
  71.     (list
  72.       ss
  73.       acSelectionSetAll
  74.       nil
  75.       nil
  76.       (car TMP)
  77.       (cadr TMP)
  78.     )
  79.   )
  80.       )
  81.     )
  82.   )
  83.   (setq ents nil)
  84.   (if ss
  85.     (VLAX-FOR obj ss
  86.       (setq e (vlax-vla-object->ename obj))
  87.       (setq ents (cons e ents))
  88.     )
  89.   )
  90.   (setq ss nil)
  91.   ENTS
  92. )
飞雪神光 + 1 那么这个用在什么场景呢
发表于 2024-1-1 21:35:43 | 显示全部楼层
-4倒是简单
和其它的组码代号没啥区别
;;全图搜索非250色的“TK-*”图框
(setq ssets (vla-get-selectionsets *doc*))
(if (vl-catch-all-error-p (vl-catch-all-apply 'vla-item (list ssets "$Set")))
        (setq alltkset (vla-add ssets "$Set"))
                (vla-delete (vla-item ssets "$Set"))
(setq filter_code  (vlax-make-safearray vlax-vbinteger '(0 . 3)))
(setq filter_value (vlax-make-safearray vlax-vbvariant '(0 . 3)))
(vlax-safearray-fill filter_code '(0 2 -4 62))
(vlax-safearray-fill filter_value '("insert" "TK-*" "!=" 250))
(vla-Select alltkset acSelectionSetAll nil nil filter_code filter_value)
发表于 2024-1-1 19:44:01 | 显示全部楼层
vla的select方法比较麻烦,模式较多:Window、Crossing、Previous、Last、All,虽然有这么多mode,实际使用起来远远不够,更多的情况还需要使用 SelectByPolygon, SelectAtPoint, SelectOnScreen方法。但各种方法模式不相同,导致不太容易直接按ssget函数习惯去匹配适用的方法和模式,当然也不是完全不可能,只是特别麻烦,更麻烦的是-3组,因为-3组是一个大项,需要专门组建数据和其它组结合在一起才能进行有效过滤....再加上ssget函数常用到的-4组,过滤表整合起来比较累人
另外,对于选择集,很多时候都是创建一个命名选择集,但循环调用不注意间可能导致选择集数量超限(128),一般情况下可以直接 使用activeselectionset,
(vlax-get-property(vlax-get-property(vlax-get-acad-object)'activedocument)'activeselectionset)
发表于 2025-8-17 09:58:51 | 显示全部楼层
你有种再说一遍 发表于 2024-1-2 16:56
给迷途羔羊一条路,后台获取数据制造索引和八叉树就是选择集了,至于你会不会,至少我在lisp没看到人敲这个
别管几叉树,能高速的核心是多线程。多线程是lisp不支持的,即便分了四叉树,lisp也要按照顺序来一个个顺次执行处理,顶多算是优化了一下内存使用,而对于速度不会有任何的提升。
发表于 2024-1-1 19:25:46 | 显示全部楼层
难道用在DBX?
发表于 2024-1-1 19:35:36 | 显示全部楼层
DBX不支持select方法
发表于 2024-1-1 21:39:49 | 显示全部楼层
vla选择集有一点很好玩
写外部块的时候
它同时输出模型和布局里的内容
发表于 2024-1-2 16:56:46 | 显示全部楼层
发表于 2024-1-2 22:28:39 | 显示全部楼层
很多人别说8叉树
4叉树或者2叉树是啥都不知道
比如我
所以
楼上用lisp写个?
大家都来学习下
发表于 2024-1-2 22:53:53 | 显示全部楼层
能比选择易高效和省事?
发表于 2025-8-16 23:54:27 | 显示全部楼层
xyp1964 发表于 2024-1-2 22:53
能比选择易高效和省事?
信息差不是一点半点的。
GMT+8, 2025-12-12 07:53 , Processed in 0.181640 second(s), 28 queries , Gzip On.
