1002| 25
[提问] 请教用angle获取的角度值为科学技术法、如何转换为常规角度 |
2明经币
最佳答案Command: (setq Val 9.31323e-13)
9.31323e-013
Command: (equal val 0 1e-9)
T
Command: (equal val 0 1e-13)
nil
Command: (equal val 0 1e-12)
T
Determines whether two expressions are equal
(equal expr1 expr2 [fuzz])
Arguments
expr1
The expression to be compared.
expr2
The expression to compare with expr1.
fuzz
A real number defining the maximum amount by which expr1 a ...
发表于 2024-1-9 16:23
显示全部楼层
发表于 2024-1-9 18:36
显示全部楼层
发表于 2024-1-9 19:26
显示全部楼层
