查看: 1152|回复: 2
[讨论] 求助,哪位高手有多条线段一键相交,自动裁剪的插件?
发表于 2024-1-11 10:49:45 | 显示全部楼层 |阅读模式
请问各位高手有多条线段一键相交,自动裁剪的插件,就是两条线段一键相交,合并为一条线段,并把多余的部分裁剪了
就比如让左边的线段,变成右边这样的插件
发表于 2024-1-11 20:09:42 | 显示全部楼层
  1. ;;; 用模糊距离连接线,弧和多义线
  2. (defun c:tt ()
  3.   (setq oldcmdecho (getvar "cmdecho"))
  4.   (setq oldpeditaccept (getvar "PEDITACCEPT"))
  5.   (setvar "cmdecho" 0)
  6.   (setq A2k4 (>= (substr (getvar "ACADVER") 1 2) "16"))
  7.   (if A2k4 (setvar "PEDITACCEPT" 0))
  8.   (setq  okObjects '((0 . "LINE,ARC,POLYLINE,LWPOLYLINE")))
  9.   (princ "\nSelect object to join: ")
  10.   (setq ss1 (ssget okObjects))
  11.   (setq fuzz (getdist "\nFuzz distance <0>: "))
  12.   (if (= fuzz nil) (setq fuzz 0))
  13.   (if (/= ss1 nil)
  14.       (progn
  15.   (setq objType (cdr (assoc 0 (entget (setq entLine (ssname ss1 0))))))
  16.   (if (= (sslength ss1) 1) (setq ss1 (ssget "X" okObjects)))
  17.   (if (member objType '("LINE" "ARC"))
  18.     (command "_.pedit" "_M" ss1 "" "_Y" "_J" "_J" "_B" fuzz "")
  19.     (command "_.pedit" "_M" ss1 "" "_J" "_J" "_B" fuzz "")
  20.   )
  21.       )
  22.   )
  23.   (setq ss1 nil)
  24.   (setvar "cmdecho" oldcmdecho)
  25.   (if A2k4 (setvar "PEDITACCEPT" oldpeditaccept))
  26.   (princ)
  27. )
参与人数 1明经币 +2 收起 理由
xyp1964 + 2 赞一个!
发表于 2024-1-12 22:19:53 | 显示全部楼层
不错的帖子  顶一下
GMT+8, 2025-5-12 07:35 , Processed in 0.248525 second(s), 30 queries , Gzip On.
