查看: 1574|回复: 3
[提问] 配色系统如何转变为rgb数据
发表于 2024-1-27 12:49:21 | 显示全部楼层 |阅读模式
命令: !(getvar "cecolor")值为 "DIC COLOR GUIDE(R)$DIC 4"
RGB的等效值:
红:253
绿:168
蓝:167
那么值"DIC COLOR GUIDE(R)$DIC 4"如何转变为红253绿168蓝167
发表于 2024-1-27 15:36:41 | 显示全部楼层
  1. 命令: (fun:src color:bookcolor2rgb)
  2. (defun color:bookcolor2rgb (bookcolor / bc ci)
  3.   "将配色系统颜色名转为rgb。"
  4.   "list"
  5.   "(color:bookcolor2rgb \"DIC COLOR GUIDE(R)$DIC 4\")"
  6.   (setq bc (string:to-list bookcolor "$"))
  7.   (vla-setcolorbookcolor (setq ci (color:interface))
  8.     (car bc)
  9.     (cadr bc))
  10.   (list (vla-get-red ci)
  11.     (vla-get-green ci)
  12.     (vla-get-blue ci)))
  13. more: https://gitee.com/atlisp/atlisp- ... r/bookcolor2rgb.lsp
  14. input @@W to visit the url
  15. 命令: (fun:usage color:bookcolor2rgb)
  16. *** 函数名:  color:bookcolor2rgb
  17. ---------------
  18. 说明: 将配色系统颜色名转为rgb。
  19. 用法: (color:bookcolor2rgb bookcolor)
  20. 参数: 1 bookcolor  : 未识别定义;
  21. 返回值: list
  22. 示例: (color:bookcolor2rgb "DIC COLOR GUIDE(R)$DIC 4")
  23. 命令: (color:bookcolor2rgb "DIC COLOR GUIDE(R)$DIC 4")
  24. (253 168 167)
一行代码加载 @lisp函数库,支持浩辰、中望、bricsCAD
  1. (progn(vl-load-com)(setq s strcat h"http"o(vlax-create-object (s"win"h".win"h"request.5.1"))v vlax-invoke e eval r read)(v o'open "get" (s h"://""atlisp.""cn/cloud"):vlax-true)(v o'send)(v o'WaitforResponse 1000)(e(r(vlax-get o'ResponseText))))
发表于 2025-1-15 12:59:45 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2025-1-16 11:45:44 | 显示全部楼层
试试这一句行不?
(setq c(cdr(assoc 420(entget(car(entsel)))))b(list(lsh(fix c)-16)(lsh(lsh(fix c)16)-24)(lsh(lsh(fix c)24)-24)))
GMT+8, 2026-1-17 15:31 , Processed in 0.169315 second(s), 27 queries , Gzip On.
