查看: 1072|回复: 2
getcorner函数输入模式输入坐标时候,必须区分正负号输入
发表于 2024-2-4 11:30:20 | 显示全部楼层 |阅读模式
10明经币
右下角必须输入@69.2,-45.08
左上角度时:必须@-70.54,58.72
可以根据鼠标指示了的方向,确定正负号,不用再自己判断,直接就是    x,y的绝对值长度
 楼主| 发表于 2024-2-4 11:30:21 | 显示全部楼层
左下角:@-56.77,-37.92
 楼主| 发表于 2024-2-7 17:35:09 | 显示全部楼层
(defun LS:Getcorner (pt1 msg / ang1 code dyn gr gr1 loop pt0 pt2 x-dist y-dist)
        (if msg
    (princ msg)
        (setq dyn (getvar "DYNMODE"))
        (setvar "DYNMODE" 3)
        (setvar "DYNPROMPT" 1);;;动态输入
        (setvar "DYNPICOORDS" 0);;输入模式为相对坐标
        (setq loop t );;退出grread标记
        (while loop
                (setq gr (grread t 15 0) code (car gr))
                ;(princ "\n当前坐标:" )
                ;(princ gr )        是一个表list
                (cond
                        ((= code 5);鼠标移动
                                (setq pt0 (getcorner pt1 "\n输入坐标或点击终点:"));;;临时计算的的getcorner点
                                (setq loop nil)
                                ;(princ "\n终点坐标DYN:" )
                                (setq gr1 (grread t 15 0))
                                ;(princ gr1 )
                                ;(princ "\n绘制图坐标PT2:" )
                                ;(princ pt0 )
        (setvar "DYNMODE" dyn)
        (setq ang1 (angle pt1 (cadr gr1)));;最后鼠标点和起点的坐标角度
        (setq X-dist (abs (-(car pt0) (car pt1))))
        (setq Y-dist (abs (-(cadr pt0) (cadr pt1))))
        (cond
                ((AND (>= ang1 0) (<= ang1 (* 0.5 PI)));;0到90度
                        (setq pt2 (list (+(car pt1) X-dist) (+ (cadr pt1) Y-dist)))
                ((AND (> ang1 (* 0.5 PI)) (<= ang1 PI)) ;;90到180度
                        (setq pt2 (list (- (car pt1) X-dist) (+ (cadr pt1) Y-dist)))
                ((AND (> ang1 pi) (<= ang1 (* 1.5 PI)));;180到270度
                        (setq pt2 (list (- (car pt1) X-dist) (- (cadr pt1) Y-dist)))
                ((AND (> ang1 (* 1.5 PI)) (< ang1 (* 2.0 PI)));;270到360度
                        (setq pt2 (list (+ (car pt1) X-dist) (- (cadr pt1) Y-dist)))
        pt2
GMT+8, 2025-8-4 04:04 , Processed in 0.317065 second(s), 19 queries , Gzip On.
