查看: 2494|回复: 5
[讨论] 表中函数该如何表达?
发表于 2024-2-10 21:07:21 | 显示全部楼层 |阅读模式
(defun c:delreg ()
(setq bat_file (open (strcat "c:" "\\" "regdel.bat") "w"))
(progn (foreach x '(
"reg delete \"HKCU\\SOFTWARE\\Autodesk\\AutoCAD\\R23.1\\ACAD-3001:804\" / f >nul 2>nul "
)(write-line x bat_file))
(setq bat_file (close bat_file)))
请教:其中R23.1\\ACAD-3001:804如何用(vlax-product-key)替换呢?
发表于 2024-2-11 17:30:29 | 显示全部楼层
  1. (defun c:delreg (/ bat_file)
  2.         (setq bat_file (open (strcat "c:" "\\" "regdel.bat") "w"))
  3.         (foreach x (list
  4.                                                          (strcat "reg delete \"HKCU\\"(vlax-product-key)"\" / f >nul 2>nul ")
  5.                                                  )
  6.                 (write-line x bat_file)
  7.         )
  8.         (setq bat_file (close bat_file))
  9.         (princ)
  10. )
 楼主| 发表于 2024-2-11 21:02:11 | 显示全部楼层
非常感谢,还是要用list
发表于 2024-2-15 23:10:18 | 显示全部楼层
感谢分享学习了
发表于 2024-2-20 11:08:15 | 显示全部楼层
maghreb 发表于 2024-2-11 21:02
非常感谢,还是要用list
肯定要List了,’是直接引用,括号内的表达式不能进行计算
 楼主| 发表于 2024-2-20 12:15:56 来自手机 | 显示全部楼层
是的,quote直接引用不计算,保护性的
GMT+8, 2025-9-13 07:18 , Processed in 0.145126 second(s), 25 queries , Gzip On.
