查看: 2067|回复: 5
[源码] 相同文字连线如何加入属性块文字
发表于 2024-2-18 08:40:29 | 显示全部楼层 |阅读模式
;;--------------相同文字连线----------------
(setq *ent2obj*     vlax-Ename->Vla-Object)
(defun c:tt()
  (if (setq ss (ssget ":e:s" '((0 . "TEXT"))))
   (setq ttent (ssname ss 0))
   (command "layer" "m" "f_temp_文字连线" "c" "6" "" "")
   (setq str (cdr (assoc 1 (entget ttent))))
   (setq po (getmidpo (entbox ttent)))
   (setq ss (ssget "x" (list '(0 . "TEXT")(cons 1 str))))
   (if (< 1 (sslength ss))
     (setq oldliness (ssget "x" '((0 . "line")(8 . "f_temp_文字连线"))))
     (if oldliness (command "erase" oldliness ""))
     (setq ss (vl-remove ttent (ss2list ss)))
     (foreach x ss
      (setq px (getmidpo (entbox x)))
      (command "line" "non" po "non" px "")
    (command "change" ttent "" "p" "co" "2" "")
;;单个物体的最小(正交)包围框
(defun entbox ( ent / ll ur )
(vla-getboundingbox (*ent2obj* ent) 'll 'ur)
(mapcar 'vlax-safearray->list (list ll ur))
;;求两点中点
(defun getmidpo( pts / P1 P2 X Y )
(setq p1 (car pts) p2 (cadr pts))
(if (= (length p1) (length p2))
  nil
  (setq p1 (list (car p1) (cadr p1))
    p2 (list (car p2) (cadr p2))
(mapcar '(lambda (X Y) (/ (+ X Y) 2.0)) P1 P2)
;;选择集转为图元列表
(defun ss2list( ss )
(if (= 'PICKSET (type ss))
  (reverse (vl-remove-if-not '(lambda (x) (= (type x) 'ENAME)) (mapcar 'cadr (ssnamex ss))))
上述程序如何加入属性块文字?有请高手出手
发表于 2024-2-18 09:29:56 | 显示全部楼层
  1. (defun c:tt (/ *ent2obj* entbox get-dxf getmidpo olayer oldliness po px ss ss2list sslst str str2 ttent tylx)
  2.   (setq *ent2obj*     vlax-Ename->Vla-Object)
  3.   ;;单个物体的最小(正交)包围框
  4.   (defun entbox ( ent / ll ur )
  5.     (vla-getboundingbox (*ent2obj* ent) 'll 'ur)
  6.     (mapcar 'vlax-safearray->list (list ll ur))
  7.   )
  8.   ;;求两点中点
  9.   (defun getmidpo( pts / P1 P2 X Y )
  10.     (setq p1 (car pts) p2 (cadr pts))
  11.     (if (= (length p1) (length p2))
  12.       nil
  13.       (setq p1 (list (car p1) (cadr p1))
  14.         p2 (list (car p2) (cadr p2))
  15.       )
  16.     )
  17.     (mapcar '(lambda (X Y) (/ (+ X Y) 2.0)) P1 P2)
  18.   )
  19.   ;;选择集转为图元列表
  20.   (defun ss2list( ss )
  21.     (reverse (vl-remove-if-not '(lambda (x) (= (type x) 'ENAME)) (mapcar 'cadr (ssnamex ss))))
  22.   )
  23.   (defun get-dxf(en n)
  24.     (if (not (listp en)) (setq en (entget en)))
  25.     (cdr (assoc n en))
  26.   )
  27.   (setq olayer (getvar "clayer"))
  28.   (command "layer" "m" "f_temp_文字连线" "c" "6" "" "")
  29.   (setvar "cmdecho" 0)
  30.   (if (setq ss (ssget ":e:s" '(
  31.                                 (-4 . "<OR")
  32.                                 (-4 . "<AND")(0 . "TEXT")(-4 . "AND>")
  33.                                 (-4 . "<AND")(0 . "INSERT")(66 . 1)(-4 . "AND>")
  34.                                 (-4 . "OR>")
  35.                               )
  36.                )
  37.       )
  38.     (progn
  39.       (setq ttent (ssname ss 0))
  40.       (setq tylx (get-dxf ttent 0))
  41.       (cond
  42.         ((= tylx "TEXT")
  43.           (setq str (cdr (assoc 1 (entget ttent))))
  44.         )
  45.         ((= tylx "INSERT")
  46.           (setq str (car (mapcar '(lambda (x) (vla-get-textstring x)) (vlax-invoke (vlax-ename->vla-object ttent) "getattributes"))))
  47.         )
  48.       )
  49.       (setq po (getmidpo (entbox ttent)))
  50.       (setq ss (ssget "x" (list
  51.                             '(-4 . "<OR")
  52.                             '(-4 . "<AND")'(0 . "TEXT")(cons 1 str)'(-4 . "AND>")
  53.                             '(-4 . "<AND")'(0 . "INSERT")'(66 . 1)'(-4 . "AND>")
  54.                             '(-4 . "OR>")
  55.                           )
  56.                )
  57.       )
  58.       (setq sslst '())
  59.       (foreach ty (ss2list ss)
  60.         (setq tylx (get-dxf ty 0))
  61.         (if (= tylx "INSERT")
  62.           (progn
  63.             (setq str2 (car (mapcar '(lambda (x) (vla-get-textstring x)) (vlax-invoke (vlax-ename->vla-object ty) "getattributes"))))
  64.             (if (/= str str2)
  65.               (ssdel ty ss)
  66.             )
  67.           )
  68.         )
  69.       )
  70.       (if (< 1 (sslength ss))
  71.         (progn
  72.           (setq oldliness (ssget "x" '((0 . "line")(8 . "f_temp_文字连线"))))
  73.           (if oldliness (command "erase" oldliness ""))
  74.           (setq ss (vl-remove ttent (ss2list ss)))
  75.           (foreach x ss
  76.             (setq px (getmidpo (entbox x)))
  77.             (command "line" "non" po "non" px "")
  78.           )
  79.         )
  80.         (command "change" ttent "" "p" "co" "2" "")
  81.       )
  82.     )
  83.   )
  84.   (setvar "clayer" olayer)
  85.   (princ)
  86. )
发表于 2024-2-18 10:02:35 | 显示全部楼层
(setq ss (ssget ":e:s" '((0 . "TEXT,attdef"))))
 楼主| 发表于 2024-2-18 10:14:35 | 显示全部楼层
这个取不到属性块的文字(setq str (cdr (assoc 1 (entget ttent))))
 楼主| 发表于 2024-2-19 08:55:28 | 显示全部楼层
谢谢飞雪的程序 完美
发表于 2024-2-19 13:53:29 来自手机 | 显示全部楼层
感谢飞雪大神的分享,牛
GMT+8, 2025-8-22 04:53 , Processed in 0.151622 second(s), 26 queries , Gzip On.
