查看: 43495|回复: 41
[2025] AutoCAD 2025 64位多国语言
发表于 2024-3-26 22:56:02 | 显示全部楼层 |阅读模式
1、Autodesk AutoCAD 2025 64位简体中文版软件下载地址:
https://dds.autodesk.com/NetSWDLD/ODIS/prd/2025/ACD/7B66591E-A260-34D2-B2AD-8FDC4EA76CE8/SFX/AutoCAD_2025_Simplified_Chinese_Win_64bit_db_001_002.exe
https://dds.autodesk.com/NetSWDLD/ODIS/prd/2025/ACD/7B66591E-A260-34D2-B2AD-8FDC4EA76CE8/SFX/AutoCAD_2025_Simplified_Chinese_Win_64bit_db_002_002.7z
1、Autodesk Revit 2025 64位简体中文版软件下载地址:
https://dds.autodesk.com/NetSWDLD/ODIS/prd/2025/RVT/686CE2A3-7C33-3AD5-806A-75A6E648117F/SFX/Revit_2025_English_Win_64bit_dlm_001_002.exe
https://dds.autodesk.com/NetSWDLD/ODIS/prd/2025/RVT/686CE2A3-7C33-3AD5-806A-75A6E648117F/SFX/Revit_2025_English_Win_64bit_dlm_002_002.7z
1、Autodesk Maya 2025 64位多国语言版下载地址:
https://dds.autodesk.com/NetSWDLD/ODIS/prd/2025/MAYA/9492D878-1D29-3499-A4DA-0B73819C7DA9/SFX/Autodesk_Maya_2025_Windows_di_001_002.exe
https://dds.autodesk.com/NetSWDLD/ODIS/prd/2025/MAYA/9492D878-1D29-3499-A4DA-0B73819C7DA9/SFX/Autodesk_Maya_2025_Windows_di_002_002.7z
1、Autodesk 3ds Max 2025 64位简体中文版软件下载地址:
https://dds.autodesk.com/NetSWDLD/2025/3DSMAX/14FA05D6-D56B-3FDC-8E00-9025FE259283/SFX/Autodesk_3ds_Max_2025__EFGJKPS_Win_64bit_001_003.sfx.exe
https://dds.autodesk.com/NetSWDLD/2025/3DSMAX/14FA05D6-D56B-3FDC-8E00-9025FE259283/SFX/Autodesk_3ds_Max_2025__EFGJKPS_Win_64bit_002_003.sfx.exe
https://dds.autodesk.com/NetSWDLD/2025/3DSMAX/14FA05D6-D56B-3FDC-8E00-9025FE259283/SFX/Autodesk_3ds_Max_2025__EFGJKPS_Win_64bit_003_003.sfx.exe
1、Autodesk Inventor Professional 2025 64位简体中文版软件下载地址:
https://dds.autodesk.com/NetSWDLD/ODIS/prd/2025/INVPROSA/8F302D2A-FEB3-373B-99A8-D0592508FD09/SFX/Inventor_Professional_2025_Simplified_Chinese_Win_64bit_db_001_002.exe
https://dds.autodesk.com/NetSWDLD/ODIS/prd/2025/INVPROSA/8F302D2A-FEB3-373B-99A8-D0592508FD09/SFX/Inventor_Professional_2025_Simplified_Chinese_Win_64bit_db_002_002.7z
1、Autodesk Civil 3D 2025 64位简体中文版软件下载地址:
https://dds.autodesk.com/NetSWDLD/ODIS/prd/2025/CIV3D/A6E1380C-F5F8-3991-9D83-3374503614C7/SFX/CIV3D_2025_Chinese_Simplified_Win_64bit_db_001_002.exe
https://dds.autodesk.com/NetSWDLD/ODIS/prd/2025/CIV3D/A6E1380C-F5F8-3991-9D83-3374503614C7/SFX/CIV3D_2025_Chinese_Simplified_Win_64bit_db_002_002.7z
1、Autodesk Navisworks Manage 2025 64位多国语言版下载地址:
https://dds.autodesk.com/NetSWDLD/ODIS/prd/2025/NAVMAN/D87B131B-2A64-3A01-822F-3FB63EBEDD3B/SFX/Autodesk_Navisworks_Manage_2025_Win_64bit_db_001_002.exe
https://dds.autodesk.com/NetSWDLD/ODIS/prd/2025/NAVMAN/D87B131B-2A64-3A01-822F-3FB63EBEDD3B/SFX/Autodesk_Navisworks_Manage_2025_Win_64bit_db_002_002.7z
1、Autodesk AutoCAD Mechanical 2025 64位简体中文版下载地址:
https://dds.autodesk.com/NetSWDLD/ODIS/prd/2025/AMECH_PP/3CB969A9-51E8-3BE6-917F-935D3ACCC692/SFX/AutoCAD_Mechanical_2025_Simplified_Chinese_Win_64bit_db_001_002.exe
https://dds.autodesk.com/NetSWDLD/ODIS/prd/2025/AMECH_PP/3CB969A9-51E8-3BE6-917F-935D3ACCC692/SFX/AutoCAD_Mechanical_2025_Simplified_Chinese_Win_64bit_db_002_002.7z
1、Autodesk AutoCAD MEP 2025 64位简体中文版软件下载地址:
https://dds.autodesk.com/NetSWDLD/ODIS/prd/2025/BLDSYS/7D4C688B-C18B-3244-8A07-14A27347E687/SFX/AutoCAD_MEP_2025_Chinese_Simplified_Win_64bit_dlm_001_002.exe
https://dds.autodesk.com/NetSWDLD/ODIS/prd/2025/BLDSYS/7D4C688B-C18B-3244-8A07-14A27347E687/SFX/AutoCAD_MEP_2025_Chinese_Simplified_Win_64bit_dlm_002_002.7z
2、Autodesk AutoCAD 2025 64位繁体中文版软件下载地址:
https://dds.autodesk.com/NetSWDLD/ODIS/prd/2025/ACD/51DF6195-54FE-35DC-B7E1-2FF767474517/SFX/AutoCAD_2025_Traditional_Chinese_Win_64bit_db_001_002.exe
https://dds.autodesk.com/NetSWDLD/ODIS/prd/2025/ACD/51DF6195-54FE-35DC-B7E1-2FF767474517/SFX/AutoCAD_2025_Traditional_Chinese_Win_64bit_db_002_002.7z
1、Autodesk AutoCAD Plant 3D 2025 64位简体中文版下载地址:
https://dds.autodesk.com/NetSWDLD/ODIS/prd/2025/PLNT3D/A22F9D0C-D365-3098-8171-AA2BBA85E10E/SFX/AutoCAD_Plant_3D_2025_Simplified_Chinese_Win_64bit_db_001_002.exe
https://dds.autodesk.com/NetSWDLD/ODIS/prd/2025/PLNT3D/A22F9D0C-D365-3098-8171-AA2BBA85E10E/SFX/AutoCAD_Plant_3D_2025_Simplified_Chinese_Win_64bit_db_002_002.7z
5、Autodesk AutoCAD 2025 64位英文版软件下载地址:
https://dds.autodesk.com/NetSWDLD/ODIS/prd/2025/ACD/99E57530-7CC1-31F4-89E9-24175C7690C2/SFX/AutoCAD_2025_English_Win_64bit_db_001_002.exe
https://dds.autodesk.com/NetSWDLD/ODIS/prd/2025/ACD/99E57530-7CC1-31F4-89E9-24175C7690C2/SFX/AutoCAD_2025_English_Win_64bit_db_002_002.7z
 楼主| 发表于 2024-4-2 17:58:13 | 显示全部楼层
benny2 发表于 2024-4-2 15:40
有Plant 3D的下载地址吗?
shangm上面已更新
回复 支持 1 反对 1
发表于 2024-3-27 14:28:52 | 显示全部楼层
AutoCAD_Mechanical_2025 简体中文版
https://dds.autodesk.com/NetSWDL ... 4bit_db_001_002.exe
https://dds.autodesk.com/NetSWDL ... 64bit_db_002_002.7z
CAD2025内部版本是R25.0,文件格式是CAD2018
天正T20V10不支持
回复 支持 1 反对 1
 楼主| 发表于 2025-6-17 08:32:55 | 显示全部楼层
https://dds.autodesk.com/NetSWDL ... 7/SFX/AutoCAD_MEP_2
发表于 2024-3-26 23:02:14 | 显示全部楼层
现在就等大佬和谐了~~
发表于 2024-3-26 23:05:11 | 显示全部楼层
除了简体中文,其他都多余。
发表于 2024-3-26 23:05:14 | 显示全部楼层
今年来的有点晚
发表于 2024-3-26 23:06:22 | 显示全部楼层
就等大佬和谐了~~
发表于 2024-3-26 23:30:04 | 显示全部楼层
这么快出这么多版本.66
发表于 2024-3-27 01:03:09 | 显示全部楼层
明经能人太多,卧龙藏虎。
发表于 2024-3-27 07:48:16 | 显示全部楼层
这也太快了
发表于 2024-3-27 08:19:07 | 显示全部楼层
LT 版本啥时候出来哦??
发表于 2024-3-27 08:58:53 | 显示全部楼层
有啥新功能吗?拜托别老刷版本号
GMT+8, 2025-12-8 07:58 , Processed in 0.190638 second(s), 27 queries , Gzip On.
