查看: 1275|回复: 2
[源码] 空间三点画三维圆弧和三维圆
发表于 2024-4-1 23:12:56 | 显示全部楼层 |阅读模式
;;;空间三点画三维圆弧和三维圆
  1. (defun c:3Darc (/ p1 p2 p3)
  2. (command "_ucs" "_w")
  3. (setq p1(getpoint "Arc point #1: "))
  4. (setq p2(getpoint "Arc point #2: "))
  5. (setq p3(getpoint "Arc point #3: "))
  6. (command "_ucs" "_3p" p1 p2 p3)
  7. (command "_arc" (trans p1 0 1)(trans p2 0 1)(trans p3 0 1))
  8. (command "_ucs" "_p")
  9. )
  10. (defun c:3Dcircle (/ p1 p2 p3)
  11. (command "_ucs" "_w")
  12. (setq p1(getpoint "Circle point #1: "))
  13. (setq p2(getpoint "Circle point #2: "))
  14. (setq p3(getpoint "Circle point #3: "))
  15. (command "_ucs" "_3p" p1 p2 p3)
  16. (command "_circle" "_3p"(trans p1 0 1)(trans p2 0 1)(trans p3 0 1))
  17. (command "_ucs" "_p")
  18. )
xyp1964 + 1 赞一个!
发表于 2024-4-2 10:17:58 | 显示全部楼层
沙发支持一下
发表于 2024-4-3 09:24:18 | 显示全部楼层
向量叉积定法向,向量与法向叉积定径向,中点、径向定中垂线,中垂线交点定圆心,全都是代数运算,比用command 要好。
GMT+8, 2025-8-22 04:23 , Processed in 0.180483 second(s), 26 queries , Gzip On.
