查看: 3266|回复: 9
【K:CreatRvTXT】创建云线文字标注
发表于 2024-4-4 17:05:05 | 显示全部楼层 |阅读模式
之前写了云线标注,很多小伙伴反馈缺少文字标注。
刚好最近有小伙伴付费定制,就把原先的云线程序整体上做了一些修改。
主要是增加了这个子函数,也分享给大家耍耍~
  1. ;创建云线文字标注
  2. (defun K:CreatRvTXT (TgtObj Col TgtDIM STR / CurCol Code StaPT EndPT MTEN)
  3.     (setq StaPT Nil EndPT Nil)
  4.     (if (eq 'ENAME (type TgtObj))(setq TgtObj (vlax-ename->vla-object TgtObj)))
  5.     (setq Col
  6.         (if (/= Col (atoi (setq CurCol (getvar "CECOLOR"))))
  7.             (cond
  8.                 ((= "BYBLOCK" CurCol) 7);随块
  9.                 ((= "BYLAYER" CurCol) (cdr (assoc 62 (tblsearch "layer" (getvar "CLAYER")))));随层
  10.                 (T (atoi CurCol))
  11.             )
  12.             Col
  13.         )
  14.     )(redraw)
  15.     (while ;Grread
  16.         (progn
  17.         (princ "\n——★★★ 请指定标注点或空格 ★★★——\n")
  18.         (while (and (setq Code (grread T (+ 1 4 8) 0)) (eq (car Code) 5))
  19.             (redraw)
  20.             (setq StaPT (trans (cadr Code) 1 0) ;WCS
  21.                     EndPT (vlax-curve-getClosestPointTo TgtObj StaPT);WCS
  22.             )
  23.             (grdraw (trans StaPT 0 1) (trans EndPT 0 1) Col);UCS
  24.         )
  25.         (cond
  26.             ((and (eq (car Code) 3) (eq (type StaPT) 'LIST));点选
  27.                 Nil ;退出循环
  28.             )
  29.             ((equal Code '(2 32));空格
  30.                 (redraw)
  31.                 (setq StaPT (trans (cadr (grread '(2 32))) 1 0) ;WCS
  32.                     EndPT (vlax-curve-getClosestPointTo TgtObj StaPT);WCS
  33.                 )
  34.                 (grdraw (trans StaPT 0 1) (trans EndPT 0 1) Col);UCS
  35.                 Nil ;退出循环
  36.             )
  37.             (T
  38.             (princ "\n——★★★ 请输入点或 ESC退出! ★★★——\n")
  39.             T ;继续循环
  40.             );退出循环
  41.         )
  42.         )
  43.     )
  44.     (if (and StaPT EndPT)
  45.         (progn
  46.             (entmake (list '(0 . "LINE") (cons 10 StaPT) (cons 11 EndPT)));直线
  47.             (setq MTEN
  48.                 (entmakeX
  49.                     (list (cons 0 "MTEXT")
  50.                             (cons 100 "AcDbEntity")
  51.                             (cons 100 "AcDbMText")
  52.                             (cons 10 StaPT)
  53.                             (cons 40 (* TgtDIM 5.0));字高
  54.                             (cons 41 (* TgtDIM 100.0));总页宽
  55.                             (cons 71
  56.                                 (if (> (cadr (mapcar '- (trans StaPT 0 1)(trans EndPT 0 1))) 0);Y大,上侧
  57.                                     7 ;左下
  58.                                     1 ;左上
  59.                                 )
  60.                             );对齐基点
  61.                             (cons 1
  62.                                 (strcat
  63.                                     STR "时间:"(menucmd "M=$(edtime,$(getvar,date),YYYY/MO/DD HH:MM)")
  64.                                     "\n" STR "人员:"(getenv "USERNAME")
  65.                                     "\n" STR "内容:"
  66.                                 )
  67.                             );文字内容
  68.                             (cons 50 (-
  69.                                         (- (* 2 pi) (getvar "viewtwist"))
  70.                                         (angle '(0. 0. 0.) (trans (getvar 'UCSXDIR) 0 (trans '(0. 0. 1.) 1 0 t) t)))
  71.                             );文字旋转始终水平视图
  72.                     )
  73.                 );多行文字
  74.             )
  75.             (if MTEN
  76.                 (progn
  77.                     (command "_.MTEDIT" MTEN)
  78.                     (while (> (getvar "CMDACTIVE") 0) (command PAUSE));等待前面的命令完成
  79.                 )
  80.
  81.
  82.             );编辑多行文字
  83.         )
  84.     )
  85.     (redraw);刷新视图
  86. )
用法:
  1. (K:CreatRvTXT (car (nentsel)) 230 1.0 "修改")
  2. (K:CreatRvTXT (car (nentsel)) 230 1.0 "批注")
ssyfeng + 1 很给力!
发表于 2024-4-4 21:36:19 | 显示全部楼层
要这么长的命令吗😅
 楼主| 发表于 2024-4-4 21:40:58 | 显示全部楼层
嘛,你有需要就自己改咯
发表于 2024-4-7 08:09:53 | 显示全部楼层
感谢分享
感谢分享
发表于 2024-4-30 15:10:26 | 显示全部楼层
  1. (defun-c TT (/ TgtObj Col TgtDIM STR)
  2.   (setq TgtObj (car (nentsel "\n选择一个对象: ")))
  3.   (setq Col 230) ; 颜色编号设置为230
  4.   (setq TgtDIM 1.0) ; 文字标注的高度设置为1.0
  5.   (setq STR "修改") ; 文字内容设置为"修改"
  6.   (K:CreatRvTXT TgtObj Col TgtDIM STR)
  7.   (princ)
  8. )
发表于 2024-6-10 11:42:49 | 显示全部楼层
(K:CreatRvTXT (car (nentsel)) 230 1.0 "修改")除了修改生效,其他230 好像是不生效
发表于 2024-11-8 15:09:03 | 显示全部楼层
多谢分享,稍微调整了一点点,把文字高度跟全局比例关联了一下
GMT+8, 2025-12-24 04:13 , Processed in 0.177127 second(s), 27 queries , Gzip On.
