查看: 945|回复: 3
【K:Cecolor4ACI】获取当前色的ACI近似色
发表于 2024-4-5 18:07:48 | 显示全部楼层 |阅读模式
  1. (defun K:Cecolor4ACI (/ LayObj CurCol AciCol LayLck TmpEn)
  2.     (setq LayObj (vlax-ename->vla-object (tblobjname "LAYER" (getvar "CLAYER"))));当前层
  3.     (setq CurCol (getvar "CECOLOR"))
  4.     (cond
  5.         ((<= 1 (atoi CurCol) 255)(setq AciCol (atoi CurCol)));1~255
  6.         ((= "BYBLOCK" CurCol) (setq AciCol 7));随块0
  7.         ((= "BYLAYER" CurCol) (setq AciCol (vla-get-Color LayObj)));随层取层色
  8.         (T
  9.             (setq LayLck Nil)
  10.             (if (eq (vla-get-lock LayObj) :vlax-true);锁定了
  11.                 (progn
  12.                   (setq LayLck T)
  13.                   (vla-put-lock LayObj :vlax-false);解锁
  14.                 )
  15.             );临时解锁当前层
  16.             (setq TmpEn (entmakeX (list '(0 . "POINT") (cons 10 '(0.0 0.0 0.0)))));创建临时实体
  17.             (setq AciCol (cdr (assoc 62 (entget TmpEn))))
  18.             (if TmpEn (vla-Delete (vlax-ename->vla-object TmpEn)));删除临时实体
  19.             (if LayLck (vla-put-lock LayObj :vlax-false));重新锁定当前层
  20.         );RGB或其它
  21.     )
  22.     AciCol
  23. )
主要用途:
  1. (grdraw (getpoint) (getpoint) (K:Cecolor4ACI));UCS
发表于 2024-4-5 22:52:16 | 显示全部楼层
感谢大佬分享
发表于 2024-4-6 10:51:28 | 显示全部楼层
感谢分享,赞
发表于 2024-4-7 09:19:41 | 显示全部楼层
感谢大佬分享
GMT+8, 2025-5-24 15:57 , Processed in 0.934458 second(s), 23 queries , Gzip On.
