查看: 1034|回复: 6
加入指定基准
发表于 2024-4-10 22:43:22 | 显示全部楼层 |阅读模式
5明经币
    • (defun string:from-lst        (lst Separator)
    •   "列表转成字符串"
    •   (if        (cdr lst)
    •     (strcat (car lst) Separator (string:from-lst (cdr lst) Separator))
    •     (car lst)
    • (defun string:to-lst        (str Separator / pos)
    •   "字符串转成列表"
    •   (if        (setq pos (vl-string-search Separator str))
    •     (cons (substr str 1 pos)
    •       (string:to-lst (substr str (+ pos 1 (strlen Separator))) Separator)
    •     (list str)
    • (defun at-pm:saveas-dxf (file-name file-path ss)
    •   "save selected entity to dxf"
    •   (if (and (= 'str (type file-name))
    •         (/= "" file-name)
    •         (vl-file-directory-p file-path)
    •         (> (sslength ss) 0))
    •     (progn
    •       ;;(push-var)
    •       (setq file-name
    •         (string:from-lst
    •           (reverse (cdr (reverse (string:to-lst file-name "."))))
    •       (setvar "cmdecho" 0)
    •       (setvar "filedia" 0)
    •       (vl-cmdf "_.dxfout" (strcat file-path "\\" file-name)  "O" ss "" "16" )
    •       ;;(pop-var)
    •       T)
    •     nil
    •   (setvar "filedia" 1)
    • (defun c:gdxf ()
    •   (at-pm:saveas-dxf
    •     (getvar "DWGNAME")
    •     "D:\\024"
    •     (ssget '((-4 . "<NOT") (8 . "DIM,TEMP")(-4 . "NOT>")))))
求加入指定一点为基准点后再输入文件名保存
原帖:
求DXF输出路径 LISP - AutoLISP/Visual LISP 编程技术 - AutoCAD论坛 - 明经CAD社区 - Powered by Discuz! (mjtd.com)
发表于 2024-4-11 15:30:09 | 显示全部楼层
导dxf需要指定点么 命令里没有点参数啊
 楼主| 发表于 2024-4-11 15:56:38 | 显示全部楼层
是导出后指定一个原点
发表于 2024-4-11 17:17:19 | 显示全部楼层
把导出的对象移到指定坐标上?
 楼主| 发表于 2024-4-11 17:22:48 | 显示全部楼层
ssyfeng 发表于 2024-4-11 17:17
把导出的对象移到指定坐标上?
对  指定一个点为原点
发表于 2024-4-11 17:26:16 | 显示全部楼层
谢谢分享谢谢分享谢谢分享
发表于 2024-4-11 17:59:16 | 显示全部楼层
zwq8629 发表于 2024-4-11 17:22
对  指定一个点为原点
那就先把要导出的对象移动一下不就行了,就是个移动命令的事
GMT+8, 2025-5-23 13:56 , Processed in 0.161182 second(s), 19 queries , Gzip On.
