查看: 1912|回复: 3
【K:DynDrawCircle】Grread动态绘制圆并返回图元名称
发表于 2024-4-12 21:46:28 | 显示全部楼层 |阅读模式
  1. ;动态绘制圆@Kucha
  2. (defun K:DynDrawCircle (StaPt Col / K:GrvecsCircle Code TgtKey EntNam)
  3.   ;grdraw绘制近似圆@LEEMAC
  4.   (defun K:GrvecsCircle (Cen Rad Col / ang inc)
  5.     (setq inc (/ (+ pi pi) 24.0)
  6.           ang 0.0
  7.     )
  8.     (repeat 24 (grdraw (polar Cen ang Rad) (polar Cen (setq ang (+ ang inc)) Rad) Col))
  9.   )
  10.   (while
  11.     (progn
  12.       (princ "\n→请指定半径<空格退出>: ")
  13.       (while (and (setq Code (grread T (+ 1 4 8))) (eq (car Code) 5))
  14.           (redraw)(K:GrvecsCircle StaPt (distance StaPt (cadr Code)) Col)
  15.       );显示预览
  16.       (setq TgtKey (cadr Code))
  17.       (cond
  18.         ((eq (car Code) 3);点选
  19.             (redraw)
  20.             (setq EntNam (entmakeX (list '(0 . "CIRCLE") (cons 10 (trans StaPt 1 0)) (cons 40 (distance StaPt (cadr Code))))))
  21.             Nil ;退出循环
  22.         )
  23.         (T Nil)
  24.       )
  25.     )
  26.   )
  27.   EntNam
  28. )
用法:
  1. (K:DynDrawCircle (getpoint) 1)
发表于 2024-4-12 23:50:58 | 显示全部楼层
感谢大佬分享~
发表于 2024-9-11 14:30:05 | 显示全部楼层
好帖子,学习了。顶一个
发表于 2025-2-14 14:30:32 | 显示全部楼层
正是我想要 的..感谢楼主..............
GMT+8, 2025-5-24 22:22 , Processed in 0.192705 second(s), 22 queries , Gzip On.
