- 积分
- 30968
- 明经币
- 个
- 注册时间
- 2013-1-25
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
原帖子地址:
http://bbs.mjtd.com/forum.php?mo ... 1%C4%BB%D1%A1%D7%D6
这个功能是比较有用的,
三领做了点集成:
1:对任意角度的文字支持
2:对任意炸碎的文字支持
3:集成TAB键取词库
4:对选中的文字画出矩形矢量框,变色系统保留
5:对MTEXT支持集成
 - (defun c:tt ()
- (while (setq e1
- (clh-entsel
- (slmsg
- "\n -> 拖动决定替换字符串 [输入(左键)/取词(TAB)/删除(空格)/取消(右键)]"
- "\n -> ╈笆∕﹚蠢传才﹃ [块(オ龄)/迭(TAB)/埃()/(龄)]"
- "\n ->Drag to determine the replacement string [Enter (left click)/Take words (TAB)/Delete (space)/Cancel (right click)]"
- ) "nil" '((0 . "TEXT,MTEXT,TCH_TEXT,TCH_MTEXT,SWR_TEXT")) str1)
- (setq e (car e1) p0 (cadr e1))
- ;(setvar "snapang" (sl-r2d (e-ang e p0)))
- (substrdynamic e p0) ;动态取字
- ;(setvar "snapang" 0)
- (setq e nil e1 nil p0 nil)
- ;TEXT屏幕动态选字---(一级)-----
- ;e实体名 p0 e实体范围内点
- (defun substrdynamic (e p0 / ss2 sss s1 code p01 n newe color newcolor newstr newe2 ang nam e1 p1 p2 p3 p4 tp)
- (setq color (vla-get-color (en2obj e)) newcolor 1)
- (setq tp (dxf1 e 0) e1 (entlast) sss (ssadd))
- (wzcf (ssadd e));炸碎
- (if (and (setq ss2 (last_ent e1))
- (setq newe (car (nentselp p0)))
- (progn
- (mapcar '(lambda (x) (vla-put-color (en2obj x) color)) (ss-enlst ss2))
- (setq ang (angle-sharp (dxf1 newe 50)) p1 (dxf1 newe 10) p4 (polar p1 (+ ang pi2) (dxf1 newe 40)))
- (if (= (vla-get-color (en2obj newe)) newcolor) (setq newcolor (atoi (slsjqs))))
- (while (and (setq code (grread t 15 2)) (= (car code) 5)) ;拖动
- (redraw)
- (setq p01 (cadr code))
- (setq sss (ssget "c" p0 p01 '((0 . "TEXT,MTEXT,TCH_TEXT,TCH_MTEXT,SWR_TEXT"))))
- (setq n 1)
- (while (and (not sss) (< n 50))
- (setq sss (ssget "c" p0 (mapcar '(lambda (x) (+ x (* n (getvar 'pickbox)))) p01) '((0 . "TEXT,MTEXT,TCH_TEXT,TCH_MTEXT,SWR_TEXT"))))
- (setq n (1+ n))
- (setq p2 (polar p1 ang 400)
- p2 (pertolinecz p01 p1 p2)
- p3 (polar p4 ang 400)
- p3 (pertolinecz p01 p4 p3)
- (grdraw p1 p2 2 2)
- (grdraw p2 p3 2 2)
- (grdraw p3 p4 2 2)
- (grdraw p4 p1 2 2)
- (mapcar '(lambda (x) (vla-put-color (en2obj x) newcolor)) (ss-enlst sss))
- (cond
- ((= (car code) 3) ;左键取词修改
- (setq newstr (dclxz ""))
- ((member code '((2 9))) ;;table 键
- (setq newstr (sl-qc))
- (if newstr
- (progn
- (setq s1 (entget (setq newe2 (ssname sss (1- (sslength sss))))))
- (setq s1 (subst (cons 1 newstr) (assoc 1 s1) s1))
- (entmod s1)
- (entupd newe2)
- (ssdel newe2 sss)
- (setq n -1)
- (while (setq nam (ssname sss (setq n (1+ n))))
- (ssdel nam ss2)
- (entdel nam)
- (if (member tp '("TEXT" "TCH_TEXT" "SWR_TEXT"))
- (wzhb ss2)
- (sswzhb ss2)
- (setq ss2 nil)
- (redraw)
- (princ)
对于拖动,PICBOX选择问题,思考应该有其他办法为好,不知各位有好思路吗?
改动做法如下:
- ;e实体名 p0 e实体范围内点
- (defun substrdynamic (e p0 / ss2 sss s1 code p01 n newe color newcolor newstr newe2 ang nam e1 p1 p2 p3 p4 tp h)
- (progn
- (setq ang (angle-sharp (dxf1 newe 50)) h (dxf1 newe 40) p1 (dxf1 newe 10) p4 (polar p1 (+ ang pi2) h))
- (redraw)
- (setq n 1 h (* 0.9 h))
- (setq sss
- (ssget "cp"
- (list
- (polar p0 (+ ang pi2) h)
- (polar p0 (- ang pi2) h)
- (polar p01 (+ ang pi2) h)
- (polar p01 (- ang pi2) h)
- '((0 . "TEXT,MTEXT,TCH_TEXT,TCH_MTEXT,SWR_TEXT"))
- (setq n (1+ n))
- (cond
- (if newstr
- (progn
- (entmod s1)
- (entupd newe2)
- (ssdel newe2 sss)
- (setq n -1)
- (ssdel nam ss2)
- (entdel nam)
- (wzhb ss2)
- (sswzhb ss2)
- (setq ss2 nil)
- (redraw)
- (princ)
