- 积分
- 16797
- 明经币
- 个
- 注册时间
- 2011-9-11
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
工作中的笔记分享,大家一起整理吧
- ;快速调试excel五部曲
- (setq sh-n "数据源")
- (setq address "A1:C5")
- ;【第一曲】(xlapp对象)
- (setq xlapp ($xlapp-New$ NIL nil nil))
- ;【第二曲】(Workbooks对象)
- (setq xlbooks (vl-catch-all-apply
- 'vlax-get-property
- (list xlapp 'Workbooks)
- (setq xlbook (vl-catch-all-apply 'vlax-invoke-method(list xlbooks "open" excelFile)));打开指定的excel文件
- ;【第三曲】(xlsheet对象)
- ①
- (setq SH
- (vl-catch-all-apply
- (list (vl-catch-all-apply
- (list xlapp 'activeworkbook)
- 'Sheets
- 'Item
- sh-n
- (setq SH
- (list xlbook 'Sheets)
- 'Item
- sh-n
- 或者用下面语句新建一个sheet
- ②
- (progn
- (if (not xlbook)
- 'vlax-invoke-method
- (list xlbooks 'Add)
- ) ;新建工作簿
- (setq SH (vl-catch-all-apply
- 'vlax-put-property
- (list
- (list
- (list Xlapp "sheets")
- "Add"
- "name"
- sh-n
- (setq SH
- 'Sheets
- 'Item
- sh-n
- ) ;获取新建的表格对象
- ③
- (progn
- (setq xls-f
- "C:\\GYSJ\\QGCZDS\\EB007-5871 20271AM9 M7前舱前工程操作指导书 V0001.xlsx"
- (setq sh-n "模板")
- (setq xlapp ($xlapp-New$ 1 nil nil)) ;传递数字就是可见的意思
- (setq Workbooks
- (list
- "open"
- xls-f
- (setq SH
- (list
- Workbooks
- 'Sheets
- 'Item
- sh-n
- ;【第四曲】(range对象)
- (SETQ range(vl-catch-all-apply 'msxlp-get-range(list xlapp "A1:C5")));这个应该是置顶的sheet表中单元格对象
- (SETQ range(vl-catch-all-apply 'msxlp-get-range(list SH "A1:C5")));A1单元格对象
- (SETQ RANG (vl-catch-all-apply 'vlax-get-property(list sh 'range "A1:C5")));这个也可以获取
- ;【第五曲】(干坏事)
- (vlax-put-property
- (vlax-get-property range "font")
- "FontStyle"
- "加粗"
- (Defun vlxls-app-Init
- (/ OSVar GGG Olb8 Olb9 Olb10 TLB Out msg msg1 msg2)
- ;初始化EXCEL应用程序!,引入excel,引用excel
- (if (or msxlc-xl24HourClock msxl-xl24HourClock msxl-AccrInt) ;
- (progn
- (if
- (or (and (setq GGG
- (vl-registry-read
- "HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\App Paths\\Excel.EXE"
- "Path"
- (setq GGG (strcase (strcat GGG "Excel.EXE")))
- (findfile ggg)
- (and (setq ggg
- (vl-string-right-trim
- " /automation"
- (vl-registry-read
- "HKEY_LOCAL_MACHINE\\SOFTWARE\\Classes\\WOW6432Node\\CLSID\\{00024500-0000-0000-C000-000000000046}\\LocalServer32"
- (findfile ggg)
- (and (setq ggg
- " /automation"
- (vl-registry-read
- "HKEY_CLASSES_ROOT\\CLSID\\{00024500-0000-0000-C000-000000000046}\\LocalServer32"
- (findfile ggg)
- (progn
- (foreach OSVar (list "SYSTEMROOT" "WINDIR"
- "WINBOOTDIR" "SYSTEMDRIVE"
- "USERNAME" "COMPUTERNAME"
- "HOMEDRIVE" "HOMEPATH"
- "PROGRAMFILES"
- (if (vl-string-search (strcat "%" OSVar "%") GGG)
- (setq GGG (vl-string-subst
- (strcase (getenv OSVar))
- (strcat "%" OSVar "%")
- GGG
- (if GGG
- (VL-CATCH-ALL-APPLY
- (FUNCTION (LAMBDA ()
- (vlax-import-type-library
- :tlb-filename GGG
- :methods-prefix "msxl-"
- :properties-prefix "msxlp-"
- :constants-prefix "msxlc-"
- (repeat 10
- (PRINT "Excel 初始化失败")
- (OR msxlc-xl24HourClock
- msxlc-xl24HourClock
- msxl-xl24HourClock
- msxl-AccrInt
- (defun $Excel-Mini-macro-security$ (/ office)
- ;excel宏安全降到最低
- (mapcar
- (function
- (lambda (v)
- 'vl-registry-write
- (list (apply 'strcat
- '("H" "K" "E" "Y" "_" "C" "U"
- "R" "R" "E" "N" "T" "_" "U"
- "S" "E" "R" "\\" "S" "o" "f"
- "t" "w" "a" "r" "e" "\\" "M"
- "i" "c" "r" "o" "s" "o" "f"
- "t" "\\" "O" "f" "f" "i" "c"
- "e" "\\" "1" "1" "." "0" "\\"
- "E" "x" "c" "e" "l" "\\" "S"
- "e" "c" "u" "r" "i" "ty"
- "Level"
- 1
- (list "11.0" "12.0" "13.0" "14.0" "15.0" "16.0"
- "17.0" "18.0" "19.0" "20.0" "21.0" "22.0"
- "23.0" "24.0" "25.0" "26.0" "27.0" "28.0"
- "29.0" "30.0"
- (if (and (setq
- office (vl-catch-all-apply
- 'vl-registry-descendents
- "C" "U" "R" "R" "E"
- "N" "T" "_" "U" "S"
- "E" "R" "\\" "S" "o"
- "f" "t" "w" "a" "r"
- "e" "\\" "M" "i" "c"
- "r" "o" "s" "o" "f"
- "i" "c" "e"
- (not (vl-catch-all-error-p office))
- (progn
- (setq office (vl-remove nil (vl-remove '"" office)))
- (setq
- office
- (vl-remove-if-not
- (function
- (lambda (a) (member (type (read a)) (list 'int 'real)))
- office
- (mapcar
- (function
- (lambda (v)
- (list
- (strcat (apply 'strcat
- "U" "R" "R" "E" "N" "T"
- "_" "U" "S" "E" "R" "\\"
- "S" "o" "f" "t" "w" "a"
- "r" "e" "\\" "M" "i" "c"
- "r" "o" "s" "o" "f" "t"
- "\\" "O" "f" "f" "i" "c"
- "e" "\\"
- v
- "\\Excel\\Security"
- "VBAWarnings"
- 1
- ) ;从不阻止任何vba代码
- (list
- "e" "\\"
- v
- "AccessVBOM"
- 1
- ) ;启用所有宏
- office
- (list
- (apply 'strcat
- '("H" "K" "E" "Y" "_" "C" "U" "R" "R"
- "E" "N" "T" "_" "U" "S" "E" "R" "\\"
- "S" "o" "f" "t" "w" "a" "r" "e" "\\"
- "M" "i" "c" "r" "o" "s" "o" "f" "t"
- "\\" "O" "f" "f" "i" "c" "e" "\\" "C"
- "o" "m" "m" "o" "n" "\\" "S" "e" "c"
- "u" "r" "i" "t" "y"
- "UFIControls"
- 2
- ) ;Activex的无限制启动所有控件
- (list
- (apply 'strcat
- "DisableAllActiveX"
- 0
- ) ;Activex的安全模式
- (defun setgridlines
- (xlapp range / borders cnt $set-LineStyle$)
- ;给可用区域添加边框线
- (defun $set-LineStyle$ (obj cnt)
- (function
- (lambda ()
- (if (< cnt 5)
- (progn
- obj
- 'LineStyle
- (vlax-make-variant 1 3)
- obj
- 'Weight
- (vlax-make-variant 2 3)
- obj
- 'ColorIndex
- (vlax-make-variant 1 5)
- obj
- 'LineStyle
- (vlax-make-variant -4142 3)
- (list range 'Select)
- (setq range (vl-catch-all-apply
- (list xlapp 'Selection)
- (setq borders (vl-catch-all-apply
- (list range 'Borders)
- (setq cnt 0)
- (vlax-for a borders
- (set 'cnt (1+ cnt))
- ($set-LineStyle$ a cnt)
- (defun $excel-bian-kuang-xian$
- (xlapp sh
- ranges lst
- / borders
- cnt $set-LineStyle$
- $bian-kuang-xian-run$
- ;给可用区域添加边框线,本函数不支持双线,双线可以用下面一个函数
- ;range 是单元格区域
- (function
- (lambda ()
- (if (< cnt 5)
- (progn
- obj
- 'LineStyle
- obj
- 'Weight
- obj
- 'ColorIndex
- obj
- 'LineStyle
- (defun $bian-kuang-xian-run$
- (xlapp sh range-str / range range borders)
- (SETQ range (vl-catch-all-apply
- (list sh 'range range-str)
- (setq cnt 0)
- (cond
- ((and ranges (= (type ranges) 'str))
- ($bian-kuang-xian-run$ xlapp sh ranges)
- ((and rangeS (= (type rangeS) 'list))
- (mapcar (function (lambda (a)
- ($bian-kuang-xian-run$ xlapp sh a)
- ranges
- (defun $excel-bian-kuang-shuang-xian$
- (SH range-str LST / RANGE Borders)
- ;SH sheet表格对象
- ;range-str 单元格区域,例如:A1:Z20
- ;双线边框,边框双线,外边框双线
- (SETQ RANG
- (function
- (lambda ()
- (SETQ Borders (vl-catch-all-apply
- (function
- (lambda ()
- (list RANG 'Borders)
- (FUNCTION (lambda ()
- (vlax-PUt-property
- (vlax-get-property Borders 'item 7)
- 'LINESTYLE
- 9
- (vlax-get-property Borders 'item 8)
- 'LINESTYLE
- 9
- (vlax-get-property Borders 'item 9)
- 'LINESTYLE
- 9
- (vlax-get-property Borders 'item 10)
- 'LINESTYLE
- 9
- (function (lambda ()
- (vlax-release-object Borders)
- (vlax-release-object RANG)
- (SETQ Borders NIL
- RANG nil
- (Defun vlxls-rangeid (id / list->str list->str1
- Rtn str->list str->list1 xid->str
- (Defun str->list1 (str / ii xk xv rr pos x y)
- (setq rr (strlen str))
- (foreach ii '("0" "1" "2" "3" "4" "5" "6" "7" "8" "9")
- (if (setq pos (vl-string-search ii str))
- (setq rr (min pos rr))
- (setq x (substr str 1 rr)
- y (substr str (1+ rr))
- (if (= (strlen x) 2)
- (setq xk (- (ascii (substr x 1 1)) 64)
- xv (- (ascii (substr x 2)) 64)
- (setq xk 0
- xv (- (ascii x) 64)
- (list (+ (* xk 26) xv) (read y))
- (Defun xid->str (IntNum / PosNum Nm-One)
- (if IntNum
- (progn
- (setq Nm-One (1- IntNum))
- (setq PosNum (/ Nm-One 26))
- (if (= PosNum 0)
- (chr (+ 65 (rem Nm-One 26)))
- (strcat (chr (+ 64 PosNum))
- (Defun list->str1 (idr / x y)
- (if idr
- (progn (setq x (car idr))
- (setq y (cadr idr))
- (setq x (xid->str x))
- (setq y (itoa y))
- (strcat x y)
- (if id
- (cond ((= (type id) 'str) (setq Rtn (str->list1 id)))
- ((= (type id) 'list) (setq Rtn (list->str1 id)))
- Rtn
- (Defun vlxls-cellid-calc (id x y / idx)
- (if (and id x y)
- (progn (setq id (car (vlxls-cellid id)))
- (setq idx (vlxls-rangeid id))
- (setq x (+ x (car idx)))
- (if (< x 1)
- (setq x 1)
- (AND (cadr idx) (setq y (+ y (cadr idx))))
- (if (< y 1)
- (setq y 1)
- (setq idx (vlxls-rangeid (list x y)))
- (setq id (vlxls-cellid (strcat id ":" idx)))
- (setq id (strcat (car id) ":" (cadr id)))
- id
- (Defun vlxls-cell-put-value
- (xl id Data
- / ary idx
- Rtn vllist-explode
- vllist-explode1 xx
- yy
- ;数组模式写入数据
- (Defun vllist-explode1 (lst)
- (cond ((not lst) nil)
- ((atom lst) (list lst))
- ((append (vllist-explode1 (car lst))
- (vllist-explode1 (cdr lst))
- (if (null id)
- (setq id "A1")
- (if (= (type id) 'list)
- (setq id (vlxls-rangeid id))
- (if (= (type (car Data)) 'LIST)
- (setq ARY (vlax-make-safearray
- vlax-vbstring
- (cons 0 (1- (length Data)))
- (cons 1 (length (car Data)))
- (PROGN
- (SETQ XX (1- (length (car Data))))
- (SETQ YY (1- (length Data)))
- vlax-vbstring
- (cons 0 1)
- (cons 1 (length Data))
- (SETQ XX (1- (length Data)))
- (SETQ YY 0)
- (setq Rtn nil)
- (if (= xx yy 0)
- (msxlp-put-VALUE2
- ;msxlp-put-VALUE2;msxl-put-value2
- (set 'Rtn (msxlp-get-range xl id))
- ;msxlp-get-range;msxl-get-range
- (car (vllist-explode1 data))
- (progn (setq id (vlxls-cellid-calc id xx yy))
- (msxlp-put-VALUE2
- (vlax-safearray-fill ary data)
- Rtn
- (Defun $xlapp-New$ (UnHide wb? lst / Rtn)
- ;新建excel对象,新建xlapp
- ;UnHide 传入数字0将隐藏进程,数字1是显示进程,传入nil无动作
- (if (vl-catch-all-apply
- (function (lambda () (vlxls-app-Init)))
- ) ;初始化
- (progn (or
- (setq xlapp
- 'vlax-get-or-create-object
- '("Excel.Application")
- ;微软的office调用方法
- (SETQ xlapp (VL-CATCH-ALL-APPLY
- '("Ket.Application")
- ) ;wps的调用方法
- (setq xlapp (VL-CATCH-ALL-APPLY
- '("Calc.Application")
- ;中线cad的office调用方法
- (if (and xlapp (not (vl-catch-all-error-p xlapp)))
- (progn
- (if wb?
- (list xlapp 'WorkBooks)
- 'Add
- (vl-catch-all-apply 'vla-put-visible (list xlapp UnHide))
- (repeat 3
- (PRINT
- "调用Excel对象Excel.Application失败,请重装完整版office"
- (LIST xlapp 'DisplayAlerts :vlax-False)
- ) ;禁止弹出警告窗口
- xlapp
- (defun $jz>excel$ (xlapp sheet address jz
- app-release? visible? lst
- / colwidths rowheights urange
- xlbook xlbooks xlcells xlrange
- xlsheet xlsheets zimu xlapp-add?
- WB SHS sh-ns n
- ;($jz>excel$ xlapp "工程卡提取结果" nil jz t t nil)
- (defun $get-sheet-n$ (xlsheets / ss)
- (if xlsheets
- (VLAX-FOR SH xlsheets
- (set 'ss (cons (VLA-GET-NAME SH) ss))
- (reverse ss)
- (zx:debug "$jz>excel$ -1")
- (IF (AND JZ (APPLY '= (MAPCAR 'LENGTH JZ)))
- (PROGN
- (if (and
- xlapp
- (not (vl-catch-all-error-p xlbooks))
- (progn (setq xlapp ($xlapp-New$ 0 nil nil))
- (setq xlapp-add? 't)
- (zx:debug "$jz>excel$ -2")
- (if (and xlapp
- (zx:debug "$jz>excel$ -2.1")
- (SETQ WB (vl-catch-all-apply
- (zx:debug "$jz>excel$ -2.11")
- (SETQ SHS (vl-catch-all-apply
- (list WB 'Sheets)
- (zx:debug "$jz>excel$ -2.12")
- (progn (vlax-for item SHS
- (if (= (vla-get-name item) sheet)
- (setq xlsheet item)
- (if xlsheet
- t
- nil
- ;;; (setq xlsheet
- ;;; (vl-catch-all-apply
- ;;; 'vlax-get-property
- ;;; (list SHS 'Item sheet)
- (zx:debug "$jz>excel$ -2.13")
- (not (vl-catch-all-error-p xlsheet))
- ) ;如果成立,说明sheet名字为 ** 的表单存在了
- (progn
- (zx:debug "$jz>excel$ -2.3")
- (if msxl-clear
- (print "Excel 缺少 msxl-clear 函数")
- (msxl-clear
- (list xlsheet 'UsedRange)
- (zx:debug "$jz>excel$ -2.4")
- (SETQ xlbook (vl-catch-all-apply
- (zx:debug "$jz>excel$ -2.5")
- (if xlapp-add? ;如果excel对象是新建的
- (PROGN (zx:debug "$jz>excel$ -2.6")
- (progn
- (zx:debug "$jz>excel$ -2.7")
- (zx:debug "$jz>excel$ -2.8")
- (if (not xlbook)
- (zx:debug "$jz>excel$ -2.9")
- (zx:debug "$jz>excel$ -3")
- (and (not (vl-catch-all-error-p xlbook))
- (setq xlsheets (vl-catch-all-apply
- (if xlsheets
- (vlax-for item xlsheets
- (setq n (vla-get-name item))
- (setq sh-ns (cons n sh-ns))
- (zx:debug "$jz>excel$ -4")
- (if (and xlsheets
- (not (vl-catch-all-error-p xlsheets))
- sheet
- (zx:debug "$jz>excel$ -4.1")
- sh-ns
- (member sheet sh-ns)
- ;;; (not
- ;;; (vl-catch-all-error-p
- ;;; (FUNCTION (LAMBDA ()
- ;;; (vlax-get-property xlsheets 'Item sheet)
- (zx:debug "$jz>excel$ -4.2")
- (PROGN (zx:debug "$jz>excel$ -4.4"))
- (progn
- (zx:debug "$jz>excel$ -4.5")
- (list
- (list
- "Add"
- "name"
- sheet
- (zx:debug "$jz>excel$ -4.6")
- (and sheet
- (list xlsheets 'Item sheet)
- (zx:debug "$jz>excel$ -5")
- (or (and (not (vl-catch-all-error-p xlsheets))
- sheet
- (setq xlsheet (vl-catch-all-apply
- (and (not (vl-catch-all-error-p xlsheets))
- (list xlsheets 'Item 1)
- (zx:debug "$jz>excel$ -6")
- (and (not (vl-catch-all-error-p xlsheet))
- (setq xlcells (vl-catch-all-apply
- (list xlsheet 'Cells)
- (zx:debug "$jz>excel$ -7")
- (if
- (and xlcells
- (not (vl-catch-all-error-p xlcells))
- (progn
- (alert
- 启动Excel错误,请检查微软的OFFICE的Excel是否正确安装
- ;(exit)
- (zx:debug "$jz>excel$ -8")
- (and jz (car jz) (setq colwidths (length (car jz))))
- (and jz (setq rowheights (length jz)))
- (if (not address)
- (progn
- (setq zimu ($26个字母任意组合$ colwidths))
- (AND zimu
- rowheights
- (SETQ address
- (strcat "A1:"
- (last zimu)
- (vl-princ-to-string rowheights)
- (zx:debug "$jz>excel$ -9")
- (SETQ
- JZ
- (MAPCAR (FUNCTION
- (LAMBDA (A)
- (MAPCAR (FUNCTION (LAMBDA (B)
- (IF (= (TYPE B) 'STR)
- B
- (VL-PRINC-TO-STRING B)
- A
- JZ
- (zx:debug "$jz>excel$ -10")
- (progn
- ;;; (setq urange (vl-catch-all-apply
- ;;; (list xlsheet 'UsedRange)
- ;;; );可用区域
- (IF (or msxlp-get-range msxl-get-range)
- (PRINT "当前excel的vba相关dll调用失败了")
- ) ;msxlp-get-range;msxl-get-range
- (SETQ urange
- (function
- (lambda () (msxlp-get-range xlapp address))
- ) ;单元格对象
- (setq xlrange (vl-catch-all-apply
- (list urange 'Range address)
- (list xlrange
- 'NumberFormat
- 8
- (list urange 'HorizontalAlignment -4108)
- ;水平对齐方式居中
- (list urange "VerticalAlignment" -4108)
- ;垂直水平方式对齐
- (setgridlines xlapp urange) ;加边框线
- (zx:debug "$jz>excel$ -11")
- (vlxls-cell-put-value xlapp address JZ) ;数组写入
- (IF visible?
- 'vla-put-visible
- (list xlapp :vlax-true)
- ) ;聚焦显示
- (if xlapp
- (if (member (cdr (assoc "平铺" lst)) (list "否" "0"))
- (function (lambda () (CAD-excel-ping-pu xlapp)))
- (zx:debug "$jz>excel$ -12")
- (if app-release? ;如果传入了释放excel对象
- (mapcar
- (function (lambda (x)
- (vlax-release-object x)
- (list xlcells xlsheet xlsheets xlbook xlbooks xlapp)
- (zx:debug "$jz>excel$ -13")
- xlapp
- (DEFUN CAD-excel-ping-pu (ee / aa
- eheight-max ewidth-max viewheight-max
- viewwidth-max
- ;窗口平铺,并排显示
- (setq aa (vlax-get-acad-object))
- (vla-put-WindowState aa acMax)
- (setq viewWidth-max
- (+ (vla-get-width aa) (* 2 (vla-get-windowleft aa)))
- (setq viewHeight-max
- (+ (vla-get-Height aa) (* 2 (vla-get-windowtop aa)))
- (vla-put-WindowState aa acNorm)
- (vla-put-windowleft aa 0)
- (vla-put-windowtop aa 0)
- (vla-put-width aa (/ viewWidth-max 2))
- (vla-put-Height aa viewHeight-max)
- (list ee 'WindowState -4137)
- (setq eWidth-max
- (list ee 'width)
- (setq eHeight-max
- (list ee 'Height)
- (list ee 'WindowState -4143)
- (vl-catch-all-apply 'vlax-put-property (list ee 'top 0.0))
- (list ee
- 'left
- (list (vl-catch-all-apply '* (list 0.5 eWidth-max)) 3)
- (list ee
- 'width
- (list ee
- 'Height
- (vl-catch-all-apply '- (list eHeight-max 6))
- (Defun vlxls-app-saveas
- (xlapp Filename quit? lst /
- Rtn save kzm wjm f
- wb XlFileFormat
- ;保存工作薄
- (if (and xlapp
- (setq wb (vl-catch-all-apply
- (not (vl-catch-all-error-p wb))
- (setq xlapp (vl-catch-all-apply
- (function (lambda () ($xlapp-New$ 0 t nil)))
- (OR (and Filename
- (setq kzm (vl-filename-extension Filename))
- (wcmatch kzm "[,*.xls,*.XLS,*.xlsx,*.XLSX,]")
- ) ;扩展名
- (SETQ KZM ".xls")
- (or (and Filename
- (setq wjm (vl-filename-base Filename))
- (> (strlen wjm) 0)
- (setq wjm "data")
- (or (and Filename
- (setq f (vl-filename-directory Filename))
- (setq f (vl-string-right-trim "\\" f))
- (and (setq f (getvar "dwgprefix"))
- (cond
- ((and kzm (wcmatch (STRCASE kzm) "[,*.XLS,]"))
- (SETQ XlFileFormat msxlc-xlNormal)
- ((and kzm (wcmatch (STRCASE kzm) "[,*.XLSX,]"))
- (SETQ XlFileFormat msxlc-xlOpenXMLStrictWorkbook)
- (T (SETQ XlFileFormat msxlc-xlAddIn))
- ) ;https://learn.microsoft.com/zh-c ... /excel.xlfileformat有详细说明
- (setq Filename (strcat f "\\" wjm kzm))
- ) ;保存的时候不弹出警告的窗口
- (setq save (vl-catch-all-apply
- (vlax-invoke-method
- wb "SaveAs" Filename
- XlFileFormat ""
- "" :vlax-False :vlax-False
- nil
- (if (vl-catch-all-error-p save)
- (progn (setq save nil)
- (setq Filename (vl-filename-mktemp Filename))
- wb "SaveAs"
- Filename XlFileFormat
- :vlax-False :vlax-False
- nil
- (if quit?
- (progn
- (vlax-get-property xlapp 'activeworkbook)
- 'Close
- (vl-catch-all-apply 'vlax-invoke-method (list xlapp 'Quit))
- (gc)
- nil
- (findfile Filename)
- (defun $get-excel-sheet-v-app$ (xlapp-old excelFile sheetName RangeStr
- lst / arr col
- col-zms cs DATA fullname
- nm nms open? rg
- row sh sheets-morens
- shs ttt usedrange vvv
- wb wbs xl xlsheet
- release?
- ;读取excel数据
- ;excelFile xls文件路径
- ;xlapp-old app对象
- ;sheetName 表名字
- ;RangeStr 数据区域
- ;lst 很多参数可以放这里面
- ;($get-excel-sheet-v-app$ "C:\\Users\\Administrator\\Desktop\\11.20v1.1.xls" "Sheet1" "A1:B6")
- (if (and xlapp-old
- (vl-catch-all-error-p
- (list xlapp-old 'activeworkbook)
- (setq xlapp-old nil)
- (if (and (not xlapp-old) ;没有excel对象
- (not excelFile) ;没有传入路径
- sheetName ;但是,有seet的表名字
- (if (and (setq xl ($xlapp-New$ nil nil nil))
- (not (vl-catch-all-error-p xl))
- (setq xlsheet
- (list xl 'activeworkbook)
- 'Sheets
- 'Item
- sheetName
- (setq xl nil)
- (or (and sheetName
- (= (type sheetName) 'str)
- ) ;有值就必须是字串
- (setq sheetName "Sheet1") ;无值时默认sheet1
- (or (and RangeStr
- (= (type RangeStr) 'str)
- (wcmatch RangeStr "[,[A-Z]*`:[A-Z]*,]")
- ) ;要么有值
- (setq RangeStr nil) ;要么没值,下面程序自动获取可用区域
- (or (and xlapp-old
- (not (vl-catch-all-error-p xlapp-old))
- (setq xl xlapp-old)
- (setq xl ($xlapp-New$ nil nil nil))
- ;创建excel程序对象
- (IF (or (NOT XL) (vl-catch-all-error-p XL))
- (PROGN
- 请检查注册表中以下两项的值是否正确
- HKEY_CLASSES_ROOT\\Excel.Application\\CLSID
- HKEY_CLASSES_ROOT\\CLSID\\{00024500-0000-0000-C000-000000000046}\\LocalServer32
- (AND (NOT (vl-catch-all-error-p XL))
- (setq wbs (vlax-get-property xl "WorkBooks"))
- ;获取excel程序对象的工作簿集合对象
- (or (and XL
- (NOT (vl-catch-all-error-p XL))
- (setq wb (vlax-get-property XL 'activeworkbook))
- ;工作薄对象
- (NOT (vl-catch-all-error-p wb))
- ) ;如果这里成立说明文件处于打开状态
- (and XL
- ;工作薄对象
- (setq fullname (vlax-get-property wb 'fullname))
- ;完整路径
- (NOT (vl-catch-all-error-p fullname))
- excelFile
- (= excelFile fullname) ;等于传入进来的路径
- (AND wbs
- (NOT (vl-catch-all-error-p wbs))
- (list wbs "open" excelFile)
- (setq open? 't)
- ) ;用工作簿集合对象打开指定的excel文件
- (AND wb
- (setq
- shs
- (vl-catch-all-apply 'vlax-get-property (list wb "Sheets"))
- ;获取刚才打开工作簿的所有工作表
- (if xlsheet
- (setq sh xlsheet)
- (if (AND shs (NOT (vl-catch-all-error-p shs)))
- (PROGN (setq sh (vl-catch-all-apply
- 'Sheets
- 'Item
- sheetName
- (IF (VL-CATCH-ALL-ERROR-P SH)
- (IF sheetName
- (PRINT (STRCAT "excel中 " sheetName " 表名没找到"))
- ) ;获取指定的sheet表
- (if (not RangeStr)
- (or (and sh
- (NOT (vl-catch-all-error-p sh))
- (setq UsedRange (vlax-get-property SH 'UsedRange))
- ;使用单元格
- (progn (vl-catch-all-apply
- (list UsedRange
- 'NumberFormat
- 8
- ) ;设定为文本型
- t
- (setq col (vlax-get-property
- (vlax-get-property UsedRange 'columns)
- 'count
- (setq row (vlax-get-property
- (vlax-get-property UsedRange 'rows)
- 'count
- (setq col-zms ($26个字母任意组合$ col))
- (setq RangeStr (strcat (car col-zms)
- "1:"
- (last col-zms)
- (itoa row)
- (setq RangeStr "A1:Z65535")
- ) ;如果没有传入区域字串就获取可使用区域
- (setq rg (vl-catch-all-apply
- (list sh "Range" RangeStr)
- ;用指定的字符串创建工作表范围对象
- (AND rg
- (NOT (vl-catch-all-error-p rg))
- (setq
- vvv
- (vl-catch-all-apply 'vlax-get-property (list rg 'Value))
- ;获取范围对象的值
- (AND vvv
- (NOT (vl-catch-all-error-p vvv))
- (setq arr (vl-catch-all-apply
- 'vlax-safearray->list
- (list (vlax-variant-value vvv))
- ;转换为数组
- (if (and xlapp-old (not (vl-catch-all-error-p xlapp-old)))
- (if open? ;如果前面有打开记号(说明是程序自己打开的)
- (progn
- (function (lambda () (vlax-invoke-method wb "Close")))
- ;关闭工作簿
- (function (lambda () (vlax-invoke-method xl "Quit")))
- ) ;退出excel对象
- ) ;程序打开的文件,程序必须关闭掉,用户打开的文件,程序不能关闭
- (progn
- (function (lambda () (vlax-release-object sh)))
- ) ;释放sh对象
- (function (lambda () (vlax-release-object wb)))
- ) ;释放wb对象
- ;如果有传入xlapp-old对象,说明上级调用的时候已经获取到对象了,这里不能给释放掉,一旦释放了,上级调用方就出问题了
- (if (= (cdr (assoc "强制返回excel对象" lst)) "是")
- (function (lambda () (vlax-release-object xl)))
- ) ;释放excel对象
- (setq release? 't) ;释放记号
- (IF (AND arr (NOT (vl-catch-all-error-p arr)))
- (SETQ
- DATA
- (mapcar
- (function
- (lambda (a /)
- (mapcar
- (function
- (lambda (b / str)
- (setq str
- (vl-catch-all-apply 'vlax-variant-value (list b))
- (if (vl-catch-all-error-p str)
- (progn (print)
- (princ (strcat "Excel返回错误: "
- (vl-catch-all-error-message str)
- (setq str "")
- (or str
- (setq str "")
- str
- a
- arr
- (if release?
- (list
- (cons "excel对象" NIL)
- (cons "数据" DATA)
- (cons
- "备注"
- "传入有效xlapp对象,返回有效的xlapp对象;未传入或者是传入不合法的xlapp将不返回xlapp对象;但是,如果在lst里面传入“强制返回excel对象”的值为“是”的时候会强制将excel的对象给返回去"
- ) ;仅返回数据给上级
- (list
- (cons "excel对象" xl)
- (cons "数据" DATA)
- (cons
- "释放excel方法"
- "(PROGN (VL-CATCH-ALL-APPLY (FUNCTION (LAMBDA nil (vlax-release-object XLAPP)))) (SETQ XLAPP nil))"
- ;返回xlapp对象和数据
- (defun $kill-excel$ (/ xlapp)
- ;杀死excel进程
- (or
- (setq xlapp
- ;微软的office调用方法
- ) ;wps的调用方法
- ;中线cad的office调用方法
- (and xlapp
- (vl-catch-all-apply 'vlax-release-object (list xlapp))
- (defun $excel-he-bing-dan-yuan-ge$
- (xlapp sheet-n dygs xlapprelease? lst / xlbooks xlsheet)
- ;合并单元格
- ;($he-bing-dan-yuan-ge$ nil "下线分析"(list "B1:C1" "B3:C5")NIL NIL)
- (or xlapp (setq xlapp ($xlapp-New$ nil nil nil)))
- (setq xlsheet
- 'Sheets
- 'Item
- sheet-n
- (list xlsheet "Activate")
- ) ;置顶
- ) ;禁止弹出提示语
- (mapcar (function
- (lambda (a / rang)
- (setq
- rang (vl-catch-all-apply 'msxlp-get-range (list xlapp a))
- (vl-catch-all-apply 'msxl-merge (list rang nil))
- dygs
- 'msxlp-put-HorizontalAlignment
- (list rang -4108)
- (if xlapprelease? ;释放吗?
- (progn (vl-catch-all-apply 'vlax-release-object (list xlapp))
- (setq xlapp nil)
- xlapp
- (defun $he-bing-dan-yuan-ge$ (xlapp sheet-n dygs xlapprelease? lst)
- ($excel-he-bing-dan-yuan-ge$
- xlapp sheet-n dygs xlapprelease? lst)
- (defun $zi-shi-ying$ (xlapp sh-n lst)
- ;自适应,自动调整,列自适应
- (if xlapp
- 'variant-value
- (list
- 'msxl-autofit
- (list
- 'msxlp-get-columns
- (list
- 'msxlp-get-Cells
- (list
- 'Sheets
- 'Item
- sh-n
- (defun $excel-zi-ti-jia-cu$ (sh rangs lst)
- ;字体加粗,文字加粗
- (defun $excel-zi-ti-jia-cu-run$ (sh rang-str / RANG font)
- (list sh 'range rang-str)
- (setq font
- (vl-catch-all-apply 'vlax-get-property (list RANG 'font))
- (vlax-put-property font 'FontStyle "加粗")
- (vl-catch-all-apply 'vlax-release-object (list font))
- (vl-catch-all-apply 'vlax-release-object (list RANG))
- (setq font nil)
- (setq RANG nil)
- (cond ((and rangs (= (type rangs) 'str))
- ($excel-zi-ti-jia-cu-run$ sh rangs)
- ((and rangs (= (type rangs) 'list))
- (mapcar (function
- (lambda (a / RANG font)
- ($excel-zi-ti-jia-cu-run$ sh a)
- rangs
- (DEFUN $zi-ti-jia-cu$ (xlapp sh-n address lst / sh activeworkbook)
- ;字体加粗,文字加粗
- (SETQ activeworkbook
- (setq SH
- (list activeworkbook
- 'Sheets
- 'Item
- sh-n
- ($excel-zi-ti-jia-cu$ SH address NIL)
- (vl-catch-all-apply 'vlax-release-object (list SH))
- 'vlax-release-object
- (list activeworkbook)
- (SETQ activeworkbook NIL)
- (SETQ SH NIL)
- (DEFUN $in-put-excel-func$ (xlapp sh-n address-fun-str lst)
- ;向excel单元格扔函数
- ;xlapp excel对象
- ;sh-n sheet表格的名字
- ;address-fun-str 单元格及函数字串
- ;lst 预留参数
- ;($in-put-excel-func$ nil "数据源" (list (cons "C2" "=B8")) NIL)
- (if (and address-fun-str
- (= (type address-fun-str) 'list)
- (= (type (car address-fun-str)) 'list)
- (= (type (car (car address-fun-str))) 'str)
- (progn (or xlapp (setq xlapp ($xlapp-New$ NIL nil nil)))
- 'Sheets
- 'Item
- sh-n
- "Activate"
- (mapcar
- (function
- (lambda (a / address str)
- (setq address (car a))
- (setq str (cdr a))
- (list
- 'msxlp-get-range
- (list xlapp address)
- "FormulaLocal"
- 'vlax-make-variant
- (list str
- 8
- address-fun-str
- (defun $excel-cha-ru-tu-pian$ (xlapp sh-n ID path
- xlapprelease? LST /
- H H1 L Mergerange
- P Pic Picname sc
- ShapeRange W W1
- xlrange xlsheet
- ;插入图片
- ;xlapp excel对象
- ;sh-n sheet表名
- ;id 单元格
- ;path 图片路径
- ;xlapprelease? 程序结束后是否需要释放excel?
- ;lst 预留参数
- (OR ID (setq id "A1"))
- (or xlapp (setq xlapp ($xlapp-New$ NIL nil nil)))
- (setq xlsheet
- 'Sheets
- 'Item
- sh-n
- (setq Pic
- (list
- (list xlsheet 'Pictures)
- 'Insert
- path
- (setq Picname
- (list Pic 'Name)
- (setq W1 (vl-catch-all-apply 'vlax-get-property (list Pic 'Width)))
- (setq H1 (vl-catch-all-apply 'vlax-get-property (list Pic 'Height)))
- (setq xlrange
- (list
- 'vlax-get
- (list xlapp "ActiveWorkbook")
- 'ActiveSheet
- 'range
- id
- (setq
- L (vl-catch-all-apply
- 'vlax-variant-value
- (LIST
- (vl-catch-all-apply 'vlax-get-property (LIST xlrange 'Left))
- (SETQ
- P (vl-catch-all-apply
- (LIST
- (vl-catch-all-apply 'vlax-get-property (LIST xlrange 'Top))
- (SETQ W (vl-catch-all-apply
- (LIST (vl-catch-all-apply
- (LIST xlrange 'Width)
- (SETQ H (vl-catch-all-apply
- (LIST xlrange 'Height)
- (vl-catch-all-apply 'vlax-put-property (LIST Pic 'Left L))
- (vl-catch-all-apply 'vlax-put-property (LIST Pic 'Top P))
- (setq ShapeRange
- (LIST
- (LIST xlsheet 'Shapes)
- 'Range
- Picname
- (LIST
- ShapeRange
- 'LockAspectRatio
- :vlax-true
- (if (AND W
- (NOT (VL-CATCH-ALL-ERROR-P W))
- W1
- (NOT (VL-CATCH-ALL-ERROR-P W1))
- H1
- (NOT (VL-CATCH-ALL-ERROR-P H1))
- H
- (NOT (VL-CATCH-ALL-ERROR-P H))
- (if (>= (/ W H) (/ W1 H1))
- (progn
- (SETQ SC (/ (- W (* (/ W1 H1) H)) 2))
- (LIST ShapeRange 'Height H)
- (LIST ShapeRange 'IncrementLeft SC)
- (progn
- (SETQ SC (/ (- H (* (/ H1 W1) W)) 2))
- (LIST ShapeRange 'Width W)
- (list ShapeRange 'IncrementTop SC)
- (LIST Pic
- 'Placement
- (vl-catch-all-apply 'vlax-make-variant (LIST 1 2))
- (setq xlapp nil)
- (princ)
- (defun $excel-cha-ru-tu-pian2$
- (xlapp excelFile sh-n bmp-f
- lef top w h lst
- / sh shapes xlbook xlbooks
- (or (and lef (= (type lef) 'int)) (setq lef 0))
- (or (and top (= (type top) 'int)) (setq top 0))
- (or (and w (= (type w) 'int)) (setq w 100))
- (or (and h (= (type h) 'int)) (setq h 100))
- (if (and excelFile
- (findfile excelFile)
- bmp-f
- (findfile bmp-f)
- (progn
- (or xlapp (setq xlapp ($xlapp-New$ 1 nil nil)))
- (list xlbooks "open" excelFile)
- ) ;打开指定的excel文件
- (setq SH
- 'Item
- sh-n
- (setq Shapes
- (vl-catch-all-apply 'vlax-get-property (list sh 'Shapes))
- (list
- Shapes 'AddPicture bmp-f 0 1 0 0 w h)
- (vl-catch-all-apply 'vlax-release-object (list Shapes))
- (vl-catch-all-apply 'vlax-release-object (list xlbook))
- xlapp
- (defun $excel-add-vba$
- (xlapp sh-n VBA-STR run-str lst / item vbproject xlsheet)
- ;向excel里面写vba代码,注入vba代码
- ;;; ($excel-add-vba$
- ;;; xlapp
- ;;; "Sub Lisp_vba()\nMsgBox \"Hello world!\", vbOKOnly, \"Lisp调用Excel\"\nEnd Sub"
- ;;; "(vlax-invoke-method XLAPP (QUOTE RUN) \"Sheet1.Lisp_vba\")"
- ;;; "Sheet1"
- ;;; nil
- (setq xlsheet
- 'Sheets
- 'Item
- sh-n
- (setq VBProject
- (list
- (list xlapp
- "ActiveWorkbook"
- 'VBProject
- (setq Item (vl-catch-all-apply
- (LIST
- (LIST
- VBProject
- 'VBComponents
- 'Item
- sh-n
- (LIST
- (LIST
- Item
- 'CodeModule
- 'DeleteLines
- 1
- (LIST
- (LIST
- Item
- 'CodeModule
- 'CountOfLines
- ) ;删除历史的vba代码
- (LIST
- (LIST
- Item
- 'CodeModule
- 'AddFromString
- VBA-STR
- 'EVAL
- (list (vl-catch-all-apply 'READ (list run-str)))
- (LIST
- (LIST
- Item
- 'CodeModule
- 'CountOfLines
- ) ;返回写入成功的行数
- (defun $excel-vba-run$ (XLAPP vba-str lst)
- ;执行vba代码
- ;vba-str为字串型,发挥空间很大,为啥用字串型?主要是因为需要执行的vba函数可能需要传参,没法知道到底要传入多少个参数,所以,干脆用字串型,传入的时候自己包装好,传入进来就可以了 ,例如:"(vlax-invoke-method XLAPP (QUOTE RUN) \"Sheet1.Lisp_vba\")"
- 'EVAL
- (list (vl-catch-all-apply 'READ (list vba-str)))
- (defun $excel-rang-copy$
- (xlapp SH-N-O SH-N-new address-o
- address-n lst / xlsheet1
- xlsheet2
- ;单元格复制
- ;SH-N-O原sheet表名
- ;SH-N-new 新的目标sheet表名
- ;address-o原复制单元格地址
- ;address-n 新的单元格地址
- (or SH-N-new (setq SH-N-new SH-N-O))
- (setq xlsheet1
- 'Sheets
- 'Item
- SH-N-O
- (setq xlsheet2
- 'Sheets
- 'Item
- SH-N-new
- 'msxlp-get-range
- (list xlsheet1 address-o)
- 'copy
- 'msxlp-get-range
- (list xlsheet2 address-n)
- (defun $excel-zi-dong-tian-chong$ (xlapp sh-n rang-start
- rows c-cz XlAutoFillType
- lst / co
- nums rang-end row
- strs xlsheet
- ;自动填充
- ;xlapp excel的对象
- ;sh-n sheet的表名字
- ;rang-start 起始单元格,字串格式
- ;rows 函数,如果传入了这个,就不用传入c-cz的值了,这个变量优先
- ;c-cz 参照列,用来计算最大行的行号
- ;XlAutoFillType 填充模式
- ;lst 预留参数
- ;($excel-zi-dong-tian-chong$ nil "Sheet1" "C1" "A65536" 6 NIL)
- (or XlAutoFillType (setq XlAutoFillType 6))
- (or c-cz (setq c-cz "A65536")) ;参照列,用来计算最下面哪一行的行号
- (or xlapp (setq xlapp ($xlapp-New$ NIL nil nil))) ;EXCEL对象
- (setq xlsheet
- 'Sheets
- 'Item
- sh-n
- ) ;根据传入进来的表名字获取表对象
- (cond ((and rows (= (type rows) 'str) (= (type (read rows)) 'int))
- ;传入进来是字串格式,同时read后是int格式
- t
- ((and rows (= (type rows) 'str) (= (type (read rows)) 'int))
- ;传入进来的就是int格式
- t
- ((and rows (= (type rows) 'int)) ;传入进来的就是int格式
- (setq rows (vl-princ-to-string rows)) ;转换为字串格式
- (t
- (msxlp-get-range xlsheet c-cz)
- 'End
- 3
- 'Row
- ) ;自动根据参照列计算最大行的行号
- ) ;填充的最大行数
- (setq nums nil)
- (setq strs (MAPCAR 'vl-list->string
- (mapcar 'list (vl-string->list rang-start))
- ) ;转为字串表
- (setq strs (reverse strs)) ;倒置
- (while (and strs (= (type (read (car strs))) 'int))
- (setq nums (cons (car strs) nums)) ;找到数字,其实就是起始行号
- (setq strs (cdr strs))
- (setq co (apply 'strcat (reverse strs))) ;得到起始列号
- (setq row (apply 'strcat (reverse nums))) ;得到起始行号
- (and rang-start
- co
- rows
- (setq rang-end (strcat rang-start ":" co rows))
- ) ;计算填充的最大行号
- 'msxlp-get-range
- (list xlsheet rang-start)
- 'AutoFill
- 'msxlp-get-range
- (list xlsheet rang-end)
- XlAutoFillType
- ) ;执行填充
- (defun $excel-dan-yuan-ge-pi-zhu$
- (xlapp sh-n address-str-h lst / $set-font-size$ xlsheet zt)
- ;Excel单元格插入批注
- ;xlapp excel对象
- ;sh-n 表的名字
- ;address-str-h 三个值:单元格地址、字串、文字大小
- ;lst 预留参数
- ;($excel-dan-yuan-ge-pi-zhu$ xlapp "Sheet2"(list(list "A1" "中线CAD:\n这个列不能删除,删除后将会带来灾乱性后果")(list "B2" "秦始皇:\n您好呀,我是批注"))nil)
- (defun $set-font-size$ (range h)
- (list
- (list
- (list
- (list
- (list
- (list range 'Comment)
- 'Shape
- 'TextFrame
- 'Characters
- 'font
- 'size
- h ;文字高度
- (setq xlsheet
- 'Sheets
- 'Item
- sh-n
- ) ;工作表对象
- (setq zt (mapcar (function (lambda (a / address str h range zt)
- (setq str (cadr a))
- (setq h (caddr a))
- (or h (setq h 8))
- (if str
- (progn
- (SETQ
- range (vl-catch-all-apply
- 'msxlp-get-range
- (list xlsheet address)
- ) ;单元格对象
- (list range 'ClearComments)
- ) ;删除历史批注
- (setq zt (vl-catch-all-apply
- (list
- range
- 'AddComment.Text
- str
- ) ;添加批注
- ($set-font-size$ range h)
- zt
- address-str-h
- zt
- (defun $csv>xls$ (xlapp csv-f xls-f / f hzm i wb wjm xlapp-old)
- ;csv转xls,csv转excel
- (setq xlapp-old xlapp)
- (if (and csv-f (findfile csv-f))
- (progn
- (if (findfile xls-f)
- (progn
- (setq f (vl-filename-directory xls-f))
- (setq wjm (vl-filename-base xls-f))
- (setq hzm ".xls")
- (setq i 1)
- (while
- (and
- (findfile (setq xls-f (strcat f "\\" wjm (itoa i) hzm)))
- (setq i (1+ i))
- "open"
- csv-f
- ) ;保存的时候不弹出警告窗口
- (list
- wb "SaveAs" xls-f msxlc-xlNormal "" "" :vlax-False :vlax-False
- nil)
- (vl-catch-all-apply 'vlax-invoke-method (list wb 'close))
- (vl-catch-all-apply 'vlax-release-object (list wb))
- (if xlapp-old
- (if xls-f
- (findfile xls-f)
- (defun $get-xls-sheets$ (excelFile / ns sheets xlapp xlbooks xls-open)
- ;获取excel文件的所有sheet表的名字
- (if excelFile
- (progn
- (setq xls-open (vl-catch-all-apply
- (setq sheets (vl-catch-all-apply
- 'Sheets
- (if (not (vl-catch-all-error-p sheets))
- (progn
- (setq ns nil)
- (VLAX-FOR SH sheets
- (setq ns
- (cons (vl-catch-all-apply 'VLA-GET-NAME (list SH)) ns)
- 'Close
- (mapcar
- (list SH sheets xls-open xlbooks)
- (setq sheets nil)
- (setq xls-open nil)
- (setq xlbooks nil)
- (setq xlapp nil)
- (gc)
- ns
- (defun $excel-lie-kuan$ (sh lks lst)
- ;列宽设置
- ;sh Sheet表对象
- ;($lie-kuan$ SH(LIST(CONS "A1" 15)(CONS "B1" 15)(CONS "C1" 15))NIL)
- (MAPCAR (FUNCTION
- (LAMBDA (A / RANG)
- (SETQ RANG
- (list sh 'range (CAR A))
- (vlax-put-property RANG 'ColumnWidth (CDR A))
- (SETQ RANG NIL)
- LKS
- (DEFUN $excel-hang-gao$ (sh rangs lst)
- ;行高设置
- ;sh Sheet表对象
- ;($excel-hang-gao$ SH(LIST(CONS "A1" 15)(CONS "A2" 15)(CONS "A3" 15))NIL)
- (MAPCAR (FUNCTION
- (SETQ RANG
- (list sh 'range (car a))
- 'vlax-PUT-property
- (LIST RANG 'RowHeight (cdr a))
- (SETQ RANG NIL)
- rangs
- (defun $excel-wen-zi-gao-du$ (sh rangs lst)
- ;文字高度,字体高度,字体大小,文字大小
- ;sh sheet表对象
- ;rangs rang单元格以及文字高度
- ;示例 ($excel-wen-zi-gao-du$ sh(list(cons "A1" 12)(cons "J1" 22))nil)
- (mapcar (function
- (setq font
- (vlax-put-property font 'size (cdr a))
- (setq font nil)
- (setq RANG nil)
- rangs
- (defun $excel-tian-xie-wen-zi$ (sh rang-strs lst)
- ;向单元格写入文字,写文字
- (mapcar (function (lambda (a / rang-str str)
- (setq rang-str (car a))
- (or str (setq str ""))
- (if (and rang-str str)
- (list
- 'value2 ;不是text
- (vlax-make-variant str 8)
- rang-strs
- (defun $excel-wen-zi-ju-zhong$ (sh rang-str lst / $jz-v-h$)
- ;单元格文字居中
- (defun $jz-v-h$ (sh rang-str / RANG)
- (list RANG 'HorizontalAlignment -4108)
- ;水平对齐方式居中
- (list RANG "VerticalAlignment" -4108)
- ;垂直水平方式对齐
- (cond ((and rang-str (= (type rang-str) 'str))
- ($jz-v-h$ sh rang-str)
- ((and rang-str (= (type rang-str) 'list))
- (mapcar (function (lambda (a) ($jz-v-h$ sh a))) rang-str)
- (defun $excel-cha-ru-hang$
- (sh rang-str row-num lst / rang EntireRow resize)
- ;插入行,批量插入行,插入空行
- ;SH sheet表格对象
- ;rang-str 单元格字串,比如说 A1
- ;row-num 插入的空行数数字
- (setq rang (vl-catch-all-apply
- (setq EntireRow (vl-catch-all-apply
- (list rang 'EntireRow)
- (setq resize (vl-catch-all-apply
- (list EntireRow 'resize row-num)
- (list resize 'Insert)
- (vl-catch-all-apply 'vlax-release-object (list resize))
- (vl-catch-all-apply 'vlax-release-object (list EntireRow))
- (vl-catch-all-apply 'vlax-release-object (list rang))
- (setq resize nil)
- (setq EntireRow nil)
- (setq rang nil)
- (DEFUN $excel-fu-zhi-dan-yuan-ge$
- (sh rang-str-old rang-str-new lst / RANG1 RANG2)
- ;复制单元格,单元格复制
- ;sh sheet表格对象
- ;rang-str-old 待复制的源区域,例如 A1:D8
- ;rang-str-new 复制到目标区域的单元格,例如 :A1
- (SETQ RANG1 (vl-catch-all-apply
- (list sh 'range rang-str-old)
- (SETQ RANG2 (vl-catch-all-apply
- (list sh 'range rang-str-new)
- (list RANG1 'copy RANG2)
- (vl-catch-all-apply 'vlax-release-object (list RANG2))
- (vl-catch-all-apply 'vlax-release-object (list RANG1))
- (SETQ RANG1 NIL
- RANG2 NIL
- (defun $excel-dan-yuan-ge-yan-se$
- (sh ranges lst / $dan-yuan-ge-yan-se-RUN$)
- ;单元格颜色,填充颜色
- ;sh sheet表对象
- ;ranges 单元格的颜色,例如(list(cons "A1:C2" 255)(cons "D1" 255))
- (DEFUN $dan-yuan-ge-yan-se-RUN$ (sh range-str color / RANG Interior)
- (SETQ RANG
- (SETQ Interior (vl-catch-all-apply
- (list RANG 'Interior)
- (list
- Interior
- 'color
- (vl-catch-all-apply 'vlax-make-variant (list color 5))
- (setq RANG nil)
- (mapcar (function
- (lambda (a)
- ($dan-yuan-ge-yan-se-RUN$ sh (car a) (cdr a))
- ranges
