查看: 1038|回复: 3
求助:lisp中如何打开已有图形?
发表于 2024-4-23 10:43:55 | 显示全部楼层 |阅读模式
lisp中如何打开已有图形?
发表于 2024-4-23 10:57:32 | 显示全部楼层
  1. (vlax-invoke-method (vlax-get-or-create-object "Wscript.Shell") 'run "dwg文件的完整路径")
复制代码
发表于 2024-4-23 11:09:17 | 显示全部楼层
;;106.1 [功能] 打开一个文件
;;示例: (MJ:OpenDwg "D:\\紫金防雨.dwg")(MJ:OpenDwg "D:\\DrawingA.dxf")
(defun MJ:OpenDwg (fullname)
  (command "vbastmt"
           (strcat "AcadApplication.Documents.Open "
                   (chr 34) fullname (chr 34)
;;106.2 [功能] 打开一个文件
;;示例(MJ:OpenDwg1 "D:\\紫金防雨.dwg")(MJ:OpenDwg1 "D:\\DrawingA.dxf")
(defun MJ:OpenDwg1 (fullname / *DOC*)
  (setq *DOCS* (vla-get-Documents *acad*))
  (vla-open *DOCS* fullname)
发表于 2024-4-23 13:31:07 | 显示全部楼层
;;  Uses the 'Open' method of the Shell Object to open the specified file or folder.
;;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com
;;  Arguments: target - file, folder or ShellSpecialFolderConstants enum
;;  Returns:  T if successful, else nil
(vl-load-com)
(defun LM:Open (target / shell result)
    (if
        (and
            (or
                (eq 'INT (type target))
                (setq target (findfile target))
            (setq shell (vla-getInterfaceObject (vlax-get-acad-object) "Shell.Application"))
            (setq result (vl-catch-all-apply 'vlax-invoke (list shell 'open target)))
            (vlax-release-object shell)
            (not (vl-catch-all-error-p result))
;Example to Open a File Selected by the User
(LM:Open (getfiled "Select File to Open" "" "" 16))
;Example to Open a Drawing File at a Specified Location:
(LM:Open "C:\\My Folder\\File.dwg")
;Example to Open a Directory:
(LM:Open "C:\\My Folder\\My SubFolder")
;Example to Open the Fonts Special Folder:
(LM:Open 20)
GMT+8, 2025-5-24 16:01 , Processed in 0.154817 second(s), 23 queries , Gzip On.
