查看: 2026|回复: 6
[提问] 求助大神,批量生成了填充后如何获得面积。
发表于 2024-4-24 11:54:50 | 显示全部楼层 |阅读模式
我写了个批量的多段线向两侧偏移,两头接上并填充。代码在下面。请问如何获取这些填充的面积。(重叠部分只算一次)
 楼主| 发表于 2024-4-24 11:58:25 | 显示全部楼层
(defun c:sx (/ getds ss i e obj e1 e2 e3 e4 e5 p1 p2 p3 p4 vertex_data vertex_coords e5_data)
  (vl-load-com)
  (setvar "osmode" 0)
  (setvar 'cmdecho 0)
  (initget 2)
  (setq getds (getdist "\n输入偏移距离<可直接量取>:"))
  (setq ss (ssget '((0 . "Arc,Circle,Ellipse,*Line"))))
  (setq i 0)
  (setq long 0)
  ; 遍历全部多段线
  (repeat (sslength ss)
    (setq e   (ssname ss i)
          obj (vlax-ename->vla-object e)
          i   (1+ i)
    ; 左侧偏移
    (vl-catch-all-apply 'vla-offset (list obj getds))
    (setq e1 (entlast))
    (setq e1_data (entget e1))
    (setq vertex_data (vl-remove-if '(lambda (X) (/= 10 (car x))) e1_data))
    (setq vertex_coords (mapcar 'cdr vertex_data))
    (setq p1 (nth 0 vertex_coords))
    (setq p2 (nth (- (length vertex_coords) 1) vertex_coords))
  ; 右侧偏移
    (vl-catch-all-apply 'vla-offset (list obj (* getds -1)))
    (setq e2 (entlast))
    (setq e2_data (entget e2))
    (setq vertex_data (vl-remove-if '(lambda (X) (/= 10 (car x))) e2_data))
    (setq p3 (nth 0 vertex_coords))
    (setq p4 (nth (- (length vertex_coords) 1) vertex_coords))
    ; 两头接上,合并
    (command "pline" p1 p3 "")
    (setq e3 (entlast))
    (command "pline" p2 p4 "")
    (setq e4 (entlast))
    (command "join" e1 e2 e3 e4 "")
    (setq e5 (entlast))
    (setq e5_data (entget e5))
    ; 填充
    (setq e5_data (subst (cons 8 "偏移后") (assoc 8 e5_data) e5_data))
    (command "-layer" "c" 5 "偏移后" "")
    (entmod e5_data)
    (setq e5 (entlast))
    (command "-hatch" "p" "ANSI32" "" "" "CO" 5 "" "s" e5 "" "")
发表于 2024-4-24 12:52:14 | 显示全部楼层
(setq e5 (entlast))
(princ (vla-get-Area (vlax-ename->vla-object  e5)))
 楼主| 发表于 2024-4-24 14:45:45 | 显示全部楼层
liuhe 发表于 2024-4-24 12:52
(setq e5 (entlast))
你好,我是想获得填充的累计面积,这样一个个加起来应该会把重叠部分加两遍
发表于 2024-4-24 19:09:12 | 显示全部楼层
  1. (defun c:tt ()
  2.   (setvar 'osmode 0)
  3.   (setvar 'cmdecho 0)
  4.   (setq dd (Udist 7 "" "偏移距离<输入或鼠标直接量取>" dd nil))
  5.   (if (setq ss (ssget '((0 . "Arc,Circle,Ellipse,*Line"))))
  6.     (progn
  7.       (setq i  0
  8.             aa 0
  9.       )
  10.       (xyp-MkLaCo "偏移后" 6)
  11.       (repeat (sslength ss)
  12.         (setq e          (ssname ss i)
  13.               obj (vlax-ename->vla-object e)
  14.               i          (1+ i)
  15.         )
  16.         (vl-catch-all-apply 'vla-offset (list obj dd)) ; 左侧偏移
  17.         (setq e1 (entlast))
  18.         (setq p1 (vlax-curve-getStartPoint e1))
  19.         (setq p2 (vlax-curve-getEndPoint e1))
  20.         (vl-catch-all-apply 'vla-offset (list obj (* dd -1))) ; 右侧偏移
  21.         (setq e2 (entlast))
  22.         (setq p3 (vlax-curve-getStartPoint e2))
  23.         (setq p4 (vlax-curve-getEndPoint e2))
  24.         (command "line" p1 p3 "")
  25.         (setq e3 (entlast))
  26.         (command "line" p2 p4 "")
  27.         (setq e4 (entlast))
  28.         (command "-hatch" "p" "ANSI32" "" "" "s" e1 e2 e3 e4 "" "")
  29.         (xyp-SubUpd (list e1 e2 e3 e4) '(8 62) '("偏移后" 6))
  30.         (setq ob (vlax-ename->vla-object (entlast))
  31.               aa (+ aa (* (vla-get-area ob) 1e-6))
  32.         )
  33.       )
  34.       (princ "\n面积 = ")
  35.       (princ aa)
  36.     )
  37.   )
  38.   (princ)
  39. )
 楼主| 发表于 2024-4-25 09:09:20 | 显示全部楼层
你好,是要导入什么第三方库吗?no function definition: XYP-MKLACO
要加载E派工具箱的  发表于 2024-4-25 15:58
GMT+8, 2025-5-1 13:39 , Processed in 0.165171 second(s), 26 queries , Gzip On.
