查看: 1128|回复: 3
[提问] 求问!不知道为什么在text命令选择点时候会出现string nil问题。txt文件附上
发表于 2024-5-3 16:03:44 | 显示全部楼层 |阅读模式
代码如下:
(defun split(str p)
  (setq i (+ 1 (strlen p)))
  (setq sl '())
  (while (setq pa (vl-string-search p str))
    (setq sl (cons (substr str 1 pa) sl)
          str (substr str (+ pa i)))
  (reverse (cons str sl))
(defun c:pipe(/)
  (setq filep (getfiled "选择一个管段txt文件" "" "txt" 8))
  (setq f (open filep "r"))
  (setq info (read-line f))
  (while (setq info (read-line f))
    (setq l (split info (chr 9)))
    (command "text" "j" "l" (list (atof(nth 3 l)) (atof(nth 4 l)))  (nth 5 l)
             (strcat (nth 0 l) "," (nth 1 l) "," (nth 2 l)))
发表于 2024-5-3 19:00:58 | 显示全部楼层
文件编码不对,另存为ANSI编码就可以了
试试我这个
 楼主| 发表于 2024-5-3 16:07:41 | 显示全部楼层
这是cad运行出现的问题
发表于 2024-5-4 21:44:46 | 显示全部楼层
高度 角度 都要吧 (command "text" "j" "m" (list (atof(nth 3 l)) (atof(nth 4 l)))  (abs (atof (nth 5 l))) 0 (strcat (nth 0 l) "," (nth 1 l) "," (nth 2 l)))
GMT+8, 2025-5-11 10:44 , Processed in 0.174804 second(s), 28 queries , Gzip On.
