查看: 1464|回复: 3
[提问] 求教!如何利用现有表数据批量设置快捷键
发表于 2024-5-6 15:35:05 | 显示全部楼层 |阅读模式
20明经币
  1. ;图层切换
  2. (defun lay_qh (lay lay_col lay_lt / lay_s)
  3.   (setq lay_s (tblsearch "layer" lay))
  4.   (if (= lay_s nil)
  5.     (command "-layer" "n" lay "c" lay_col lay "lay_lt" lay_lt lay "")
  6.   )
  7.   (setvar "clayer" lay)
  8. )
  9. (defun c:DEF()(lay_qh "Defpoints" 7 "Continuous"))
  10. (defun c:00()(lay_qh "Defpoints" 7 "Continuous"))
  11. (defun c:QT()(lay_qh "墙体" 5 "Continuous"))
上面是我目前使用的图层切换代码、
有多少个图层就要复制多少行代码、然后再修改快捷键和对应图层线性、感觉有点麻烦
现在我把快捷键和图层信息都放在表里面、代码如下:
  1. (setq lay_lst (("DEF" "Defpoints" "7" "Continuous") ("00" "0" "7" "Continuous") ("QT" "墙体" "5" "Continuous")))
然后想着根据表信息来批量创建图层切换快捷键、
不知道用Lisp能否实现、特来请教一下各位大神!
最佳答案
查看完整内容
(foreach l lay_lst(eval (read (strcat "(defun c:"(car l)"()(lay_qh \""(cadr l)"\" "(caddr l)" \""(last l)"\"))"))))
发表于 2024-5-6 15:35:06 | 显示全部楼层
 楼主| 发表于 2024-5-6 16:39:21 | 显示全部楼层
http://bbs.mjtd.com/forum.php?mo ... =%BF%EC%BD%DD%BC%FC
论坛上找到了一个类似的帖子、不过没太看懂代码
 楼主| 发表于 2024-5-6 17:57:11 | 显示全部楼层
xtjd 发表于 2024-5-6 15:35
(foreach l lay_lst(eval (read (strcat "(defun c:"(car l)"()(lay_qh \""(cadr l)"\" "(caddr l)" \""(la ...
谢谢、这个可以
GMT+8, 2025-6-11 03:53 , Processed in 0.162319 second(s), 25 queries , Gzip On.
