查看: 1708|回复: 1
autocad vba 创建引线问题
发表于 2024-5-11 16:26:51 | 显示全部楼层 |阅读模式
通过VBA创建引线,如果终点在起点的左侧, 所示文字方向不正确,如图所示,不知为何,期待有大神能够指教,谢谢!
代码如下:
AcadDoc = AcadApp.ActiveDocument;
AcadMLeader acadM;
double[] points = new double[6];
points[0] = 1000; points[1] = 1000; points[2] = 0;
points[3] = 900; points[4] = 1100; points[5] = 0;
int i;
acadM = AcadDoc.ModelSpace.AddMLeader(points, out i);
acadM.TextString = "注释";
发表于 2024-12-4 14:17:37 | 显示全部楼层
代码不全测试不了
GMT+8, 2025-5-22 16:03 , Processed in 0.168930 second(s), 24 queries , Gzip On.
