查看: 1074|回复: 6
怎么做成表样式?
发表于 2024-5-13 12:54:36 | 显示全部楼层 |阅读模式
怎么让下列代码做成一个表样式?
  • ;;;9.0.圆弧【ac0】
  • (defun C:ac0 ()
  •    (prompt "\n ac0:圆弧")
  •   (vl-cmdf "arc")
  •   (princ)
  • ;;;9.1.三点圆弧【ac1】
  • (defun C:ac1 ()
  •    (prompt "\n ac1:三点[圆弧]")
  •   (vl-cmdf "arc" (getpoint "\n 指定圆弧的起点: ") (getpoint "\n 指定圆弧的第二个点: ") (getpoint "\n 指定圆弧的端点: "))
  •   (princ)
  • ;9.2.【ac2】起点、圆心、端点[圆弧]
  • (defun C:ac2 ()
  •       (prompt "\n ac2:起点、圆心、端点[圆弧]")
  •     (vl-cmdf "arc" (getpoint "\n 指定圆弧的起点: ") "C" (getpoint "\n 指定圆弧的圆心: ") (getpoint "\n 指定圆弧的端点: "))
  •   (princ)
  • ;9.3.【ac3】起点、圆心、角度[圆弧]
  • (defun C:ac3 ()
  •       (prompt "\n ac3:起点、圆心、角度[圆弧]")
  •     (vl-cmdf "arc" (getpoint "\n 指定圆弧的起点: ") "C" (getpoint "\n 指定圆弧的圆心: ") "A" )
  •   (princ)
  • ;9.4.【ac4】起点、圆心、长度[圆弧]
  • (defun C:ac4 ()
  •       (prompt "\n ac4:起点、圆心、 长度[圆弧]")
  •     (vl-cmdf "arc" (getpoint "\n 指定圆弧的起点: ") "C" (getpoint "\n 指定圆弧的圆心: ") "L" )
  •   (princ)
  • ;9.5.【ac5】起点、端点、角度[圆弧]
  • (defun C:ac5 ()
  •       (prompt "\n ac5:起点、端点、角度[圆弧]")
  •     (vl-cmdf "arc" (getpoint "\n 指定圆弧的起点: ") "E" (getpoint "\n 指定圆弧的端点: ") "A")
  •   (princ)
  • ;;;9.6.【ac6】圆弧:起点、端点、方向
  • (defun C:ac6 ()
  •       (prompt "\n ac6:起点、端点、方向[圆弧]")
  •   (command "arc" (getpoint "\n 指定圆弧的起点: ") "E" (getpoint "\n 指定圆弧的端点: ") "d" )
  •   (princ)
  • ;;;9.7.【ac7】圆弧:起点、端点、半径【ac7】
  • (defun C:ac7 ()
  •       (prompt "\n ac7:起点、端点、半径[圆弧]")
  •   (command "arc" (getpoint "\n 指定圆弧的起点: ") "E" (getpoint "\n 指定圆弧的端点: ") "r" )
  •   (princ)
  • ;9.8.【ac8】圆心、起点、端点[圆弧]
  • (defun C:ac8 ()
  •       (prompt "\n ac8:圆心、起点、端点[圆弧]")
  •     (vl-cmdf "arc" "C" (getpoint "\n 指定圆弧的圆心: ") (getpoint "\n 指定圆弧的起点: ") (getpoint "\n 指定圆弧的端点: "))
  •   (princ)
  • ;9.9.【ac9】圆心、起点、角度[圆弧]
  • (defun C:ac9 ()
  •       (prompt "\n ac9:圆心、起点、角度[圆弧]")
  •     (vl-cmdf "arc" "C" (getpoint "\n 指定圆弧的圆心: ") (getpoint "\n 指定圆弧的起点: ")  "A")
  •   (princ)
  • ;9.10.【ac10】圆心、起点、长度[圆弧]
  • (defun C:ac10 ()
  •       (prompt "\n ac10:圆心、起点、 长度[圆弧]")
  •     (vl-cmdf "arc" "C" (getpoint "\n 指定圆弧的圆心: ") (getpoint "\n 指定圆弧的起点: ")  "L" )
  •   (princ)
发表于 2024-5-13 19:13:06 | 显示全部楼层
表样式是什么样的?
 楼主| 发表于 2024-5-13 19:54:28 | 显示全部楼层
飞雪神光 发表于 2024-5-13 19:13
表样式是什么样的?
除了命令行显示外,还要在屏幕区列表显示。
发表于 2024-5-13 20:08:52 | 显示全部楼层
哦 感觉没什么意义
 楼主| 发表于 2024-5-13 22:11:54 | 显示全部楼层
飞雪神光 发表于 2024-5-13 20:08
哦 感觉没什么意义
就是想不想在命令行里切换
发表于 2024-5-15 17:54:34 | 显示全部楼层
(initget "1 2 3 4 5 6") (setq keyword (getkword (strcat"[功能选择?/圆弧(1)/三点圆弧(2)........]")))
 楼主| 发表于 2024-5-16 00:30:11 | 显示全部楼层
是这个意思,但完整的怎么写?
GMT+8, 2025-5-24 16:28 , Processed in 0.329325 second(s), 23 queries , Gzip On.
