查看: 1622|回复: 4
[提问] read函数求助
发表于 2024-5-15 19:34:18 | 显示全部楼层 |阅读模式
10明经币
原始数据
tr1.15,tr1.9,tr.3.1,ld1.76
tr1.35,tr1.1,tr.3.4,ld1.56
tr1.12,tr1.2,tr.3.44,ld1.36
tr1.14,tr1.3,tr.3.32,ld1.56
tr1.25,tr1.5,tr.3.33,ld1.566
(defun C:SDS()
         (setq sjwj (open (getfiled "请选取数据文件" "" "txt;dat" 0) "r"))
         (setq wjlb nil)
  (while (setq mhxx(read-line sjwj))
  (while (vl-string-search "," mhxx)
         (setq mhxx(vl-string-subst " " "," mhxx)))
         (setq mhlb (read (strcat "(" mhxx ")")))
         (setq wjlb(append wjlb  (list mhlb))))
转换为列表后 read把每个元素小数点后面去掉了,并全部改为了大写,,求助  该怎么写
发表于 2024-5-15 19:57:12 | 显示全部楼层
你 参考下高飞鸟的代码
(defun mysplit (str delim / lst i len);高飞鸟代码
  (setq len (strlen delim))
  (while (setq i (vl-string-search delim str))
    (setq lst (cons (substr str 1 i) lst))
    (setq str (substr str (+ 1 len i)))
  (setq lst (cons str lst))
  (reverse lst)
发表于 2024-5-15 20:14:36 | 显示全部楼层
(defun C:SDS(/ MHLB MHXX SJWJ WJLB)
         (setq mhlb (cons(mysplit mhxx ",")mhlb))
  (reverse mhlb)
发表于 2024-5-15 20:16:40 | 显示全部楼层
仅供参考  仅供参考  仅供参考
发表于 2024-5-16 17:04:15 | 显示全部楼层
把中间那段换成下面的试一试
         (setq mhxx(vl-string-subst "\" \"" "," mhxx)))
         (setq mhlb (read (strcat "(\"" mhxx "\")")))
GMT+8, 2025-5-11 14:14 , Processed in 0.159862 second(s), 23 queries , Gzip On.
