查看: 1064|回复: 0
[提问] 自己编的一个比例格式刷,可以刷(块,文字,标注)的全局比例,唯独多重引线刷不了.
发表于 2024-5-16 13:12:14 | 显示全部楼层 |阅读模式
自己编的一个比例格式刷,可以刷(块,文字,标注)的全局比例,唯独多重引线刷不了.还请哪位大神能把多重引线的加上,还请用lisp,mac本用不了vlisp等高级语言,
(defun c:MK ()  ;刷比例
  (setq c (getvar "DIMSCALE"))
  (princ "\n把块的比例改为 ")
  (princ (getvar "DIMSCALE"))
  (setq ee (ssget))
  (setq k (ssname ee 0));可以得到K
  ;;(setq ee (entsel "\n"))
  ;;(setq k(car(list (car ee))));块的名字
  ;(setq aa (entget (car ee)))
  (setq aa (entget k ))
  (setq bb (cdar(list (assoc 0 aa))))
  (setq cc (cdar(list (assoc 41 aa))))
  (setq dd (cdar(list (assoc 40 aa))))
  (setq PT (cdar(list (assoc 10 aa))))
  (IF (= bb "INSERT" )
  (setq N (abs (/ 1 CC)))
  (command "scale" k "" pt n)
  (command "scale" k "" pt c)
  (IF (= bb "TEXT" )
  (setq N (abs (/ 1 (/ dd 3))))
  (IF (= bb  "MTEXT")
  (IF (= bb "DIMENSION")
  (command "_dimoverride" "dimscale" c "" ee "")
(IF (= bb "MULTILEADER")
GMT+8, 2025-5-11 02:08 , Processed in 0.155718 second(s), 25 queries , Gzip On.
