查看: 1056|回复: 1
[经验] 计时器
发表于 2024-5-27 14:21:35 | 显示全部楼层 |阅读模式
多个计时器并行计时,每个计时器支持暂停和继续
  1. (defun $ji-shi$  (biaoshi zt LST / time hs)
  2.           ;zt 如果是0代表是停止计时,同时打印时间到命令行;1时继续计时
  3.           ;调用示例:($ji-shi$ "分析导线" 1 NIL)($ji-shi$ "分析导线" 0 NIL)
  4.   (setq time (vl-bb-ref 'timer))
  5.   (cond
  6.     ((and
  7.        biaoshi
  8.        (assoc biaoshi time)
  9.        zt
  10.        (member zt
  11.          (list '0 '"停止" '"停止计时" '"不再计时" '"stop" '"STOP")
  12.        )
  13.      )          ;停止计时并打印
  14.      (print
  15.        (strcat
  16.    biaoshi
  17.    "耗时: "
  18.    (setq hs (vl-princ-to-string
  19.         (/ (- (getvar "millisecs")
  20.         (cdr (assoc biaoshi time))
  21.         0.0
  22.            )
  23.            1000.0
  24.         )
  25.       )
  26.    )
  27.        )
  28.      )
  29.      (setq time (vl-remove (assoc biaoshi time) time))
  30.     )
  31.     ((and biaoshi
  32.     (assoc biaoshi time)
  33.     zt
  34.     (member zt
  35.       (list  '1 '"继续" '"持续计时" '"计时" '"继续计时"
  36.       '"START" '"start")
  37.     )
  38.      )          ;继续计时
  39.      ()          ;其实啥都不需要做
  40.     )
  41.     (t
  42.      (and biaoshi
  43.     (setq time (cons (cons biaoshi (getvar "millisecs")) time))
  44.      )
  45.     )
  46.   )
  47.   (vl-bb-set 'timer nil)
  48.   (vl-bb-set 'timer time)
  49.   (if hs
  50.     hs
  51.     t
  52.   )
  53. )
xshrimp + 1 很给力!
发表于 2024-5-27 18:09:37 | 显示全部楼层
感谢杜总的分享!
GMT+8, 2025-2-23 15:04 , Processed in 0.256763 second(s), 27 queries , Gzip On.
