查看: 5534|回复: 13
[求助]谁有利用IntersectWith方法的实例程序!
发表于 2004-4-6 12:31:00 | 显示全部楼层 |阅读模式
因为多段线数量大,我想用vb编程得到直线和多段线的交点!
请帮忙!!!
发表于 2004-4-6 14:02:00 | 显示全部楼层
<RE class=Code>Sub Example_IntersectWith()
    ' This example creates a line and circle and finds the points at
    ' which they intersect.
    ' Create the line
    Dim lineObj As AcadLine
    Dim startPt(0 To 2) As Double
    Dim endPt(0 To 2) As Double
    startPt(0) = 1: startPt(1) = 1: startPt(2) = 0
    endPt(0) = 5: endPt(1) = 5: endPt(2) = 0
    Set lineObj = ThisDrawing.ModelSpace.AddLine(startPt, endPt)
    ' Create the circle
    Dim circleObj As AcadCircle
    Dim centerPt(0 To 2) As Double
    Dim radius As Double
    centerPt(0) = 3: centerPt(1) = 3: centerPt(2) = 0
    radius = 1
    Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPt, radius)
    ZoomAll
    ' Find the intersection points between the line and the circle
    Dim intPoints As Variant
    intPoints = lineObj.IntersectWith(circleObj, acExtendNone)
    ' Print all the intersection points
    Dim I As Integer, j As Integer, k As Integer
    Dim str As String
    If VarType(intPoints) &lt;&gt; vbEmpty Then
        For I = LBound(intPoints) To UBound(intPoints)
            str = "Intersection Point[" &amp; k &amp; "] is: " &amp; intPoints(j) &amp; "," &amp; intPoints(j + 1) &amp; "," &amp; intPoints(j + 2)
            MsgBox str, , "IntersectWith Example"
            str = ""
            I = I + 2
            j = j + 3
            k = k + 1
        Next
    End If
End Sub</PRE>
 楼主| 发表于 2004-4-6 17:33:00 | 显示全部楼层
谢谢了,haohaohapp! 这方法能用做获得线与面的交点??
发表于 2004-4-7 08:42:00 | 显示全部楼层
可以 Sub Example_IntersectWith()
' Create the line
'Create the face
Dim Plate As Acad3DFace
Dim Pt1(0 To 2) As Double
Dim Pt2(0 To 2) As Double
Dim Pt3(0 To 2) As Double
Dim Pt4(0 To 2) As Double
Pt1(0) = 0: Pt1(1) = 0: Pt1(2) = 0
Pt2(0) = 1: Pt2(1) = 0: Pt2(2) = 0
Pt3(0) = 1: Pt3(1) = 1: Pt3(2) = 0
Pt4(0) = 0: Pt4(1) = 1: Pt4(2) = 0
Set Plate = ThisDrawing.ModelSpace.Add3DFace(Pt1, Pt2, Pt3, Pt4)
ZoomAll
' Find the intersection points between the line and the face
intPoints = lineObj.IntersectWith(Plate, acExtendNone) ' Print all the intersection points
Dim str As String
If VarType(intPoints) <> vbEmpty Then
str = "Intersection Point[" & k & "] is: " & intPoints(j) & "," & intPoints(j + 1) & "," & intPoints(j + 2)
str = ""
I = I + 2
j = j + 3
k = k + 1
Next
End If
End Sub 我只举了一个最简单的例子。要提醒你的是线与面可能有无数个交点!
 楼主| 发表于 2004-4-7 21:19:00 | 显示全部楼层
再次谢谢了,haohaohapp! 还想问下你,能不能得到已有的线和面的交点? 这点是怎样得到的?通过捕捉吗?
发表于 2004-4-8 08:19:00 | 显示全部楼层
兄弟,你不会做个辅助线么?
 楼主| 发表于 2004-4-8 08:28:00 | 显示全部楼层
线是多段线已有的,面可以自己创建!
发表于 2004-4-8 09:06:00 | 显示全部楼层
用PICK方法分别选择面和多段线中的任意一根线,通过运算可得出交点坐标。不知你是否满意
 楼主| 发表于 2004-4-8 11:17:00 | 显示全部楼层
如图示得到面域与线的交点!怎么做?
我只是举例,因为线多,面是辅助的,得编程得到点坐标!
 楼主| 发表于 2004-4-9 11:28:00 | 显示全部楼层
看看这个程序那里有问题!!!?/ Private Sub CommandButton1_Click()
' Create the line
startPt(0) = 1: startPt(1) = 1: startPt(2) = 1
endPt(0) = 1: endPt(1) = -1: endPt(2) = 1
'Create the face
Dim curves(0 To 0) As AcadCircle ' 创建形成面域边界的圆。
Dim center(0 To 2) As Double
center(0) = 2
center(1) = 2
center(2) = 0
radius = 5#
Set curves(0) = ThisDrawing.ModelSpace.AddCircle _
(center, radius) ' 创建面域
Dim regionObj As Variant
regionObj = ThisDrawing.ModelSpace.AddRegion(curves)
ZoomAll
intPoints = lineObj.IntersectWith(regionObj, acExtendNone) ' Print all the intersection points
Dim str As String
str = ""
I = I + 2
j = j + 3
k = k + 1
Next
End If
End Sub
GMT+8, 2025-9-10 04:19 , Processed in 0.160933 second(s), 26 queries , Gzip On.
