查看: 632|回复: 2
[提问] 求助:图层名+后缀
发表于 2024-6-19 10:50:22 | 显示全部楼层 |阅读模式
15明经币
点选图形,再点选文字,将图形的图层名+文字后缀,详见样图所述.
附件: 您需要 登录 才可以下载或查看,没有账号?注册
最佳答案
查看完整内容
(defun C:TCXG(/ #layerdata1 #newlayername #pickdata1 #pickdata2 #picklayer1 #pickname1 #pickname2 #picktxt2) ;获取需要修改图层名的对象的信息 (princ "\n点选需要修改图层名的对象") (setq #pickname1 (car (entsel))) (setq #pickdata1 (entget #pickname1)) (setq #picklayer1 (cdr (assoc 8 #pickdata1)));获取对象图层名 ;获取原图层信息 (setq #layerdata1 (tblsearch "layer" #picklayer1)) ;获取后 ...
发表于 2024-6-19 10:50:23 | 显示全部楼层
        ;获取需要修改图层名的对象的信息
        ;获取原图层信息
        ;获取后缀文本对象的信息
        (princ "\n点选后缀文本")
        (setq #pickname2 (car (entsel)))
        (setq #pickdata2 (entget #pickname2))
        (setq #picktxt2 (cdr (assoc 1 #pickdata2)))
        ;组合文本
        (setq #newlayername (strcat #picklayer1 "--" #picktxt2))
        ;创建新图层
        (entmake
                (list
                        '(0 . "LAYER")
                        '(100 . "AcDbSymbolTableRecord")
                        '(100 . "AcDbLayerTableRecord")
                        (cons 2 #newlayername);图层名
                        (assoc 70 #layerdata1);获取原打印状态
                        (assoc 62 #layerdata1);获取原颜色
                        (assoc 6 #layerdata1);获取原线型
                );end list
        );end entmake
        ;合并新旧图层
        (command "_.-LAYMRG" "N" #picklayer1 "" "N" #newlayername "Y")
);end TCXG
 楼主| 发表于 2024-6-19 12:20:04 | 显示全部楼层
Leolaputa 发表于 2024-6-19 11:34
(defun C:TCXG(/ #layerdata1 #newlayername #pickdata1 #pickdata2 #picklayer1 #pickname1 #pickname2 #p ...
感谢大佬帮忙
GMT+8, 2025-2-23 07:21 , Processed in 0.167559 second(s), 25 queries , Gzip On.
