查看: 1819|回复: 11
[提问] 图形合并位置出错
发表于 2024-6-22 00:31:13 | 显示全部楼层 |阅读模式
附件是写的一个合并图形的文件的小程序,
单个文件并入时,是没有问题的,可以附在我指定的位置;
但是选择多个文件时,就会出现问题,无法定位,请朋友们帮忙看一下,能否对程序进行优化;
感谢 !
发表于 2024-6-22 15:22:20 | 显示全部楼层
nyistjz 发表于 2024-6-22 13:25
大佬,竖向排列是否可以?
我按您这个逻辑试了一个竖向排列,但没有成功。
  1. (defun c:tt2 ()
  2.   "竖向合并dwg"
  3.   (setvar "cmdecho" 0)
  4.   (if (null DTU-MultiSelectDialog)
  5.     (command "netload"(findfile "DTU-MultiSelectDialog2013.dll"))
  6.   )
  7.   (setq ao  (vlax-get-acad-object)
  8.         ad  (vla-get-activedocument ao)
  9.         ms  (vla-get-modelspace ad)
  10.         lst (DTU-MultiSelectDialog "请选择DWG文件" "*.DWG")
  11.         pt0 (getpoint "\n起始点<退出>: ")
  12.   )
  13.   (setq i 0)
  14.   (foreach l lst
  15.     (setq i  (1+ i)
  16.           pt (vlax-3D-point pt0)
  17.           e1 (vla-InsertBlock ms pt l 1 1 1 0)
  18.     )
  19.     (vla-getboundingbox e1 'll 'ur)
  20.     (setq p1 (vlax-safearray->list ll)
  21.           p9 (vlax-safearray->list ur)
  22.           dy (- (cadr p9) (cadr p1))
  23.     )
  24.     (vla-move e1 (vlax-3D-point p1) (vlax-3D-point pt0))
  25.     (setq pt0 (polar pt0 (* pi 0.5) dy))
  26.     (princ (strcat "\n>>>第" (itoa i) "张:" l "\n"))
  27.   )
  28.   (princ (strcat "\n>>>操作结束,共合并" (itoa i) "张图。"))
  29.   (setvar "cmdecho" 1)
  30.   (princ)
  31. )
发表于 2024-6-22 11:35:25 | 显示全部楼层
  1. (defun c:tt ()
  2.   (setvar "cmdecho" 0)
  3.   (if (null DTU-MultiSelectDialog) (command "netload" (findfile "DTU-MultiSelectDialog2013.dll")))
  4.   (setq ao (vlax-get-acad-object))
  5.   (setq ad (vla-get-activedocument ao))
  6.   (setq ms (vla-get-modelspace ad))
  7.   (setq  lst (DTU-MultiSelectDialog "请选择DWG文件" "DWG文件(*.dwg)|*.DWG" ))
  8.   (setq pt0 (getpoint "\n起始点<退出>: "))
  9.   (setq i 0)
  10.   (foreach l lst
  11.     (setq i  (1+ i)
  12.           pt (vlax-3D-point pt0)
  13.           e1 (vla-InsertBlock ms pt l 1 1 1 0)
  14.     )
  15.     (vla-getboundingbox e1 'll 'ur)
  16.     (setq p1 (vlax-safearray->list ll)
  17.           p9 (vlax-safearray->list ur)
  18.           dx (- (car p9) (car p1))
  19.     )
  20.     (vla-move e1 (vlax-3D-point p1) (vlax-3D-point pt0))
  21.     (setq pt0 (polar pt0 0 dx))
  22.     (princ (strcat "\n>>>第" (itoa i) "张:" l "\n"))
  23.   )
  24.   (princ (strcat "\n>>>操作结束,共合并" (itoa i) "张图。"))
  25.   (setvar "cmdecho" 1)
  26.   (princ)
  27. )
 楼主| 发表于 2024-6-22 13:25:24 | 显示全部楼层
大佬,竖向排列是否可以?
发表于 2024-6-22 07:00:27 | 显示全部楼层
捕捉关了,试下
 楼主| 发表于 2024-6-22 09:20:43 | 显示全部楼层
试过了,不是这个原因
发表于 2024-6-22 09:44:11 | 显示全部楼层
不能用吧,缺函数
 楼主| 发表于 2024-6-22 11:32:30 | 显示全部楼层
muai2010 发表于 2024-6-22 09:44
不能用吧,缺函数
把附件中的NET文件加载一下就行了
 楼主| 发表于 2024-6-22 13:02:13 | 显示全部楼层
大神,请受我一拜!
GMT+8, 2025-5-1 06:23 , Processed in 0.221149 second(s), 28 queries , Gzip On.
