- 积分
- 132
- 明经币
- 个
- 注册时间
- 2024-6-15
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
 - ;;;CADALYST 10/05 Tip 2065: HatchMaker.lsp Hatch Maker (c) 2005 Larry Schiele
- ;;;* ====== B E G I N C O D E N O W ======
- ;;;* HatchMaker.lsp written by Lanny Schiele at TMI Systems Design Corporation
- ;;;* Lanny.Schiele@tmisystems.com
- ;;;* Tested on AutoCAD 2002 & 2006. -- does include a 'VL' function -- should work on Acad2000 on up.
- (defun C:DrawHatch (/)
- (command "undo" "be")
- (setq os (getvar "OSMODE"))
- (setvar "OSMODE" 0)
- (command "UCS" "w")
- (command "PLINE" "0,0" "0,1" "1,1" "1,0" "c")
- (command "zoom" "c" "0.5,0.5" 1.1)
- (setvar "OSMODE" os)
- (setvar "SNAPMODE" 1)
- (setvar "SNAPUNIT" (list 0.01 0.01))
- (command "undo" "e")
- (alert
- "Draw pattern within 1x1 box using LINE or POINT entities only..."
- (princ)
- (defun C:SaveHatch (/ round dxf ListToFile
- user SelSet SelSetSize ssNth
- Ent EntInfo EntType pt1 pt2
- Dist AngTo AngFrom XDir YDir
- Gap DeltaX DeltaY AngZone Counter
- Ratio Factor HatchName HatchDescr
- FileLines FileLines FileName
- Scaler ScaledX ScaledY RF x
- y h _AB _BC _AC
- _AD _DE _EF _EH _FH
- DimZin
- ;;;* BEGIN NESTED FUNCTIONS
- (defun round (num)
- (if (>= (- num (fix num)) 0.5)
- (fix (1+ num))
- (fix num)
- (defun dxf (code EnameOrElist / VarType)
- (setq VarType (type EnameOrElist))
- (if (= VarType (read "ENAME"))
- (cdr (assoc code (entget EnameOrElist)))
- (cdr (assoc code EnameOrElist))
- (defun ListToFile (TextList FileName DoOpenWithNotepad
- AsAppend / TextItem
- File RetVal
- (if (setq File (open FileName
- (if AsAppend
- "a"
- "w"
- (progn
- (foreach TextItem TextList
- (write-line TextItem File)
- (setq File (close File))
- (if DoOpenWithNotepad
- (startapp "notepad" FileName)
- (FindFile FileName)
- ;;;* END NESTED FUNCTIONS
- (princ
- (strcat
- "\n."
- "\n 0,1 ----------- 1,1"
- "\n | | "
- "\n | Lines and | "
- "\n | points must | "
- "\n | be snapped | "
- "\n | to nearest | "
- "\n | 0.01 | "
- "\n | | "
- "\n 0,0 ----------- 1,0"
- "\n."
- "\nNote: Lines must be drawn within 0,0 to 1,1 and lie on a 0.01 grid."
- (textscr)
- (getstring "\nHit [ENTER] to continue...")
- (princ
- "\nSelect 1x1 pattern of lines and/or points for new hatch pattern..."
- (while (not (setq SelSet (ssget (list (cons 0 "LINE,POINT")))))
- (setq ssNth 0
- SelSetSize (sslength SelSet)
- DimZin (getvar "DIMZIN")
- (setvar "DIMZIN" 11)
- (if (> SelSetSize 0)
- (princ "\nAnalyaing entities...")
- (while (< ssNth SelSetSize)
- (setq Ent (ssname SelSet ssNth)
- EntInfo (entget Ent)
- EntType (dxf 0 EntInfo)
- ssNth (+ ssNth 1)
- (cond
- ((= EntType "POINT")
- (setq pt1 (dxf 10 EntInfo)
- FileLine (strcat "0,"
- (rtos (car pt1) 2 6)
- (rtos (cadr pt1) 2 6)
- ",0,1,0,-1"
- (princ (strcat "\n" FileLine))
- (setq FileLines (cons FileLine FileLines))
- ((= EntType "LINE")
- pt2 (dxf 11 EntInfo)
- Dist (distance pt1 pt2)
- AngTo (angle pt1 pt2)
- AngFrom (angle pt2 pt1)
- IsValid nil
- (if
- (or (equal (car pt1) (car pt2) 0.0001)
- (equal (cadr pt1) (cadr pt2) 0.0001)
- (setq DeltaX 0
- DeltaY 1
- Gap (- Dist 1)
- IsValid T
- (progn
- (setq Ang (if (< AngTo pi)
- AngTo
- AngFrom
- AngZone (fix (/ Ang (/ pi 4)))
- XDir (abs (- (car pt2) (car pt1)))
- YDir (abs (- (cadr pt2) (cadr pt1)))
- Factor 1
- RF 1
- (cond
- ((= AngZone 0)
- (setq DeltaY (abs (sin Ang))
- DeltaX (abs (- (abs (/ 1.0 (sin Ang))) (abs (cos Ang)))
- ((= AngZone 1)
- (setq DeltaY (abs (cos Ang))
- DeltaX (abs (sin Ang))
- ((= AngZone 2)
- DeltaX (abs (- (abs (/ 1.0 (cos Ang))) (abs (sin Ang)))
- ((= AngZone 3)
- DeltaX (abs (cos Ang))
- (if (not (equal XDir YDir 0.001))
- (progn
- (setq Ratio (if (< XDir YDir)
- (/ YDir XDir)
- (/ XDir YDir)
- RF (* Ratio Factor)
- Scaler (/ 1
- (if (< XDir YDir)
- XDir
- YDir
- (if (not (equal Ratio (round Ratio) 0.001))
- (progn
- (while
- (and
- (<= Factor 100)
- (not (equal RF (round RF) 0.001))
- (setq Factor (+ Factor 1)
- (if (and (> Factor 1) (<= Factor 100))
- (progn
- (setq _AB (* XDir Scaler Factor)
- _BC (* YDir Scaler Factor)
- _AC (sqrt (+ (* _AB _AB) (* _BC _BC)))
- _EF 1
- x 1
- (while (< x (- _AB 0.5))
- (setq y (* x (/ YDir XDir))
- h (if (< Ang (/ pi 2))
- (- (+ 1 (fix y)) y)
- (- y (fix y))
- (if (< h _EF)
- (setq _AD x
- _DE y
- _AE (sqrt (+ (* x x) (* y y)))
- _EF h
- (setq x (+ x 1))
- (if (< _EF 1)
- (setq _EH (/ (* _BC _EF) _AC)
- _FH (/ (* _AB _EF) _AC)
- DeltaX (+ _AE
- (if (> Ang (/ pi 2))
- (- _EH)
- _EH
- DeltaY (+ _FH)
- Gap (- Dist _AC)
- IsValid T
- (if (= Factor 1)
- (setq Gap (- Dist (abs (* Factor (/ 1 DeltaY))))
- IsValid T
- (if
- IsValid
- (progn
- (setq FileLine
- (strcat
- (angtos AngTo 0 6)
- (rtos (car pt1) 2 8)
- (rtos (cadr pt1) 2 8)
- (rtos DeltaX 2 8)
- (rtos DeltaY 2 8)
- (rtos Dist 2 8)
- (rtos Gap 2 8)
- (princ (strcat "\n * * * Line with invalid angle "
- (chr 186)
- " omitted. * * *"
- ((princ
- (strcat "\n * * * Invalid entity " EntType " omitted.")
- (setvar "DIMZIN" DimZin)
- (if
- (and
- FileLines
- (setq HatchDescr
- (getstring T
- "\nBriefly describe this hatch pattern: "
- (setq FileName (getfiled "Hatch Pattern File"
- "I:\\Acad\\Hatch\"
- "pat"
- 1
- (progn
- (if (= HatchDescr "")
- (setq HatchDescr "Custom hatch pattern")
- (setq HatchName (vl-filename-base FileName)
- FileLines (cons (strcat "*" HatchName "," HatchDescr)
- (reverse FileLines)
- (princ
- "\n============================================================"
- (princ
- (strcat "\nPlease wait while the hatch file is created...\n"
- (ListToFile FileLines FileName nil nil)
- (command "delay" 1500) ;delay required so file can be created and found (silly, but req.)
- (if (findfile FileName)
- (progn
- (setvar "HPNAME" HatchName)
- (princ (strcat "\nHatch pattern '"
- HatchName
- "' is ready to use!"
- (progn
- (princ "\nUnable to create hatch pattern file:")
- (princ (strcat "\n " FileName))
- (princ
- (if FileLines
- "\nCancelled."
- "\nUnable to create hatch pattern from selected entities."
- (princ)
- (princ "\n ************************************************************** ")
- (princ "\n** **")
- (princ "\n* HatchMaker.lsp written by Lanny Schiele -- enjoy! *")
- (princ "\n* *")
- (princ "\n* Type in DRAWHATCH to have the environment created to draw. *")
- (princ "\n* Type in SAVEHATCH to save the pattern you created. *")
- (princ "\n** **")
- (princ)
可惜只能在1X1的方格绘制,不能像源泉那样的 根据X Y间距生成自定义填充,希望大神们优化!!!!
