查看: 2011|回复: 18
[讨论] 两点动态画弧
发表于 2024-6-28 06:19:24 | 显示全部楼层 |阅读模式
闲来手痒,为画弧方便,新作一功能
仅为展示,测试需三领的支持
函数不复杂,字面一看即明白,换成你的即可
  1. ;;两点动态圆弧------(一级)-----
  2. ;三领设计 V3.0 Modify by 尘缘一生  QQ:15290049 2024.6.28
  3. ;功能:给2点画弧,且提示弧长,半径,并支持扑捉,TAB键乒乓开关信息
  4. (defun 2p-dd-arc (p1 p2 / p3 nam nam1 obj nam2 ent ent1 loop bb pt f3 d ang s0 s s1 s2 s3)
  5.   (command "_.undo" "be")
  6.   (setq s0 "\n->动态圆弧 [信息开关(TAB)/扑捉(F3)/定位(Left-Right-Other keys)]")
  7.   (setq p3 (polar (sl:mid p1 p2) (+ (angle p1 p2) pi2) 50) s1 "mm" s2 "..开.." s3 "..关..")
  8.   (make-arc p1 p3 p2) ;3P画弧
  9.   (setq nam (entlast))
  10.   (slmkwz (strcat "R=" (rtos (* (getvar "DIMLFAC") (dxf1 nam 40))) s1) p3 3.0 0 nil "f-i-n-d" nil 6 "m") ;中心定位写字
  11.   (setq ent (entget (setq nam1 (entlast))) obj (en2obj nam1))
  12.   (slmkwz (strcat "L=" (rtos (* (getvar "DIMLFAC") (sllen nam))) s1) p3 3.0 0 nil "f-i-n-d" nil 6 "m")
  13.   (setq ent1 (entget (setq nam2 (entlast))))
  14.   (setq loop t f3 (getvar "OSMODE") s s2)
  15.   (princ (strcat s0 "(" s ")"))
  16.   (while loop
  17.     (setq bb (grread t 15 2))
  18.     (setq pt (cadr bb) d (p2uu 20))
  19.     (cond
  20.       ((equal bb '(2 6));F3切换捕捉开关
  21.         (cond
  22.           ((and (< f3 16384) (/= f3 0))
  23.             (setq f3 (+ f3 16384))
  24.             (prompt "\n <对象捕捉 关>")
  25.           )
  26.           ((or (= f3 0) (>= f3 16384))
  27.             (setq f3 16383)
  28.             (prompt "\n <对象捕捉 开>")
  29.           )
  30.         )
  31.         (setvar "OSMODE" f3)(redraw)
  32.       )
  33.       ((= (car bb) 5)
  34.         (redraw)
  35.         (if (and (<= f3 16384) (> f3 0))
  36.           (setq pt (slosnappt nam pt))
  37.         )
  38.         (setq pt (trans pt 1 0))
  39.         (entdel nam)
  40.         (make-arc p1 pt p2)
  41.         (setq nam (entlast))
  42.         (if (= s s2)
  43.           (progn
  44.             (setq ang (angle-sharp (angle '(0.0 0.0 0.0) (vlax-curve-getFirstDeriv nam (vlax-curve-getparamatpoint nam pt)))))
  45.             (setq pt (polar pt (+ ang pi2) (* 0.7 d)))
  46.             (entmod (emod (emod (emod (emod (emod ent 1 (strcat "R=" (rtos (* (getvar "DIMLFAC") (dxf1 nam 40))) s1)) 10 pt) 11 pt) 40 d) 50 ang))
  47.             (setq pt (polar pt (+ ang pi2) (* 1.3 d)))
  48.             (entmod (emod (emod (emod (emod (emod ent1 1 (strcat "L=" (rtos (* (getvar "DIMLFAC") (sllen nam))) s1)) 10 pt) 11 pt) 40 d) 50 ang))
  49.           )
  50.         )
  51.       )
  52.       ((member bb '((2 9))) ;;table 信息关
  53.         (entdel nam1) (entdel nam2)
  54.         (if (not (vlax-erased-p obj)) (setq s s2) (setq s s3))
  55.         (princ (strcat s0 "(" s ")"))
  56.       )
  57.       ((or t (equal (car bb) 3) (member (car bb) '(11 25)));;左、右、其余键
  58.         (setq loop nil)
  59.       )
  60.     )
  61.   )
  62.   (command "_.undo" "e")
  63.   (redraw)
  64. )
  65. ;;测试-----(需要三领支持测试)
  66. (defun c:tt (/ p1 p2)
  67.   (setq p1 (getpoint "\n 圆弧第一点:")
  68.     p2 (getpoint p1 "\n 圆弧第二点:")
  69.   )
  70.   (2p-dd-arc p1 p2)
  71. )
三领设计 V3.0 永久下载地址:
链接:https://pan.baidu.com/s/1WsH2nmBHUhb0T3STais1Hg
提取码:i2uj
参与人数 2明经币 +2 收起 理由
hubeiwdlue + 1 赞一个!
tranque + 1 赞一个!
 楼主| 发表于 2024-6-28 22:13:00 | 显示全部楼层
bai2000 发表于 2024-6-28 21:00
slmkwz 参数都是什么?子函数发个学习一下
;;写文字------(一级)---------
;;(slmkwz  文字  基点  高度  角度  宽高比  图层  字型  颜色  方式 t= "m" 中心对齐 "z" 左对齐)
;;(slmkwz "XZY" (getpoint) nil nil nil "0sx" "hz" 7 "z")
(defun slmkwz (s p0 h ang bk ly sty col k / elist elist1)
        (setq elist
                (list  '(0 . "TEXT") (cons 1 s)
                        (if ly
                                (cons 8 ly)   ;图层
                                (cons 8 (getvar "CLAYER"))
                        (if col
                                (cons 62 col)   ;颜色
                                (cons 62 (atoi (slsjqs)))
                        (if sty
                                (cons 7 sty)
                                (cons 7 $hz)
                        (if p0
                                (cons 10 p0)
                                (cons 10 (setq p0 (cadr (grread 5))))
                        (if h
                                (cons 40 (* slbl h))
                                (cons 40 (* slbl 5.0))
                        (if ang
                                (cons 50 ang)
                                (cons 50 0.0)
                        (if bk
                                (cons 41 bk)
                                (cons 41 0.7)
        (setq elist1 (list (cons 72 1) (cons 11 p0) (cons 73 2)))
        (if (= k "m")
                (entmake (append elist elist1))
                (entmake elist)
 楼主| 发表于 2024-7-1 15:19:46 | 显示全部楼层
sachindkini 发表于 2024-7-1 13:11
dear sir,
thanks for sharing
your toll are very flexible for use
三领的集成,是自动判定版本的,英文版CAD安装,就是英文版的了。
英文版,可以改一下解压目录名字为:D:\SLdesign可以下载手动安装版本 ZIP
也可以EXE安装完,改这个解压目录名即可
链接:https://pan.baidu.com/s/1NSuDJkZC2_XNf6BgX6y5hw
提取码:tk8c
发表于 2024-7-6 18:42:18 | 显示全部楼层
尘缘一生 发表于 2024-7-6 17:03
乱码?请问朋友,你用的CAD,是哪个地区,那个版本?
(getvar "SYSCODEPAGE")
用这句,是什么结果?
dear sir
im from india
  1. (getvar "SYSCODEPAGE")
  2. "ANSI_1252"
复制代码
发表于 2024-6-28 09:26:20 | 显示全部楼层
没有实际用途的显摆。
发表于 2024-6-28 09:31:54 | 显示全部楼层
能不能加一个捕捉功能,对建筑弧形外轮廓还是有用的。
 楼主| 发表于 2024-6-28 09:38:59 | 显示全部楼层
对啊,F3即可扑捉。
发表于 2024-6-28 11:44:29 | 显示全部楼层
这个捕捉能捕捉到象限点吗?最简单的象限点就是矩形的中心点
发表于 2024-6-28 14:25:32 | 显示全部楼层
有点牛逼,牛逼,牛逼,牛逼,牛逼,牛逼,牛逼,
发表于 2024-6-28 15:09:37 | 显示全部楼层
kozmosovia 发表于 2024-6-28 09:26
没有实际用途的显摆。
有源码,可以学习其中的代码。
 楼主| 发表于 2024-6-28 18:22:59 | 显示全部楼层
目前,grread下整合的扑捉函数,还做不到这一点。
发表于 2024-6-28 21:00:53 | 显示全部楼层
GMT+8, 2025-5-8 06:17 , Processed in 0.179122 second(s), 29 queries , Gzip On.
