见过一些递归的查找文件,我来一个非递归的,我想不到递归怎么写,代码如下:
 - (defun $lie-chu-mu-lu-xia-suo-you-wen-jian$
- (lst / a f fs fs-all kzm n ns ns-1 wj wjs)
- ;列出目录下所有文件,含子级目录,所有目录下的文件
- ;($lie-chu-mu-lu-xia-suo-you-wen-jian$(list(cons "目录" "C:\\uploads")(cons "扩展名" "*.dwg")))
- (or (and lst
- (= (type lst) 'list)
- (setq kzm (cdr (assoc "扩展名" lst)))
- (> (strlen kzm) 0)
- (wcmatch kzm "[,`*.*,]")
- (setq kzm "*.*")
- (or (and lst
- (setq f (cdr (assoc "目录" lst)))
- (and lst (= (type lst) 'str) (setq f lst))
- (and
- f
- kzm
- (findfile f)
- (progn
- (while (and f (wcmatch f "*`\\*"))
- (setq f (vl-string-subst "/" "\\" f))
- (setq fs-all nil)
- (setq fs-all (cons f fs-all))
- (setq fs (vl-directory-files f "*.*" -1))
- (setq fs (vl-remove ".." fs))
- (setq fs (vl-remove "." fs))
- (setq fs (mapcar (function (lambda (a) (strcat f "/" a))) fs))
- (setq fs-all (APPEND fs-all fs))
- (while (AND fs (setq f (last fs)) (< (length fs-all) 10000))
- (setq ns nil)
- (setq ns (vl-directory-files f "*.*" -1))
- (setq ns (vl-remove ".." ns))
- (setq ns (vl-remove "." ns))
- (while (setq a (car ns))
- (setq n (strcat f "/" a))
- (setq fs (cons n fs))
- (setq fs-all (cons n fs-all))
- (setq ns (cdr ns))
- (setq fs (reverse (cdr (reverse fs))))
- (and fs-all
- (progn
- (setq wjs nil)
- (while (setq a (car fs-all))
- (setq wj nil)
- (setq wj (vl-directory-files a kzm 1))
- (setq wj (vl-remove ".." wj))
- (setq wj (vl-remove "." wj))
- (setq
- wj (mapcar (function (lambda (b) (strcat a "/" b))) wj)
- (setq wjs (cons wj wjs))
- (setq fs-all (cdr fs-all))
- (setq wjs (vl-remove nil wjs))
- wjs
