查看: 1644|回复: 2
[源码] 扩展数据读取
发表于 2024-7-12 17:06:36 | 显示全部楼层 |阅读模式
;图元扩展数据读取
  1. (defun $kuo-zhan-du-qu$  (ent app-n lst / -3d app-v vs dxf)
  2.           ;和$kuo-zhan-xie-ru$函数刚好一正一反;
  3.           ;①($kuo-zhan-du-qu$(car(entsel)) "sc" nil) ;②($kuo-zhan-du-qu$ (car(entsel)) nil nil)
  4.   (if (not dxf)
  5.     (and ent (setq dxf (ENTGET ent '("*"))))
  6.   )
  7.   (if dxf
  8.     (progn
  9.       (setq -3d (cdr (assoc -3 dxf)))
  10.       (cond
  11.   ((and app-n)
  12.    (setq app-v (list (assoc app-n -3d)))
  13.   )
  14.   (t
  15.    (setq app-v -3d)
  16.   )
  17.       )
  18.     )
  19.   )
  20.   (setq
  21.     vs
  22.      (mapcar
  23.        (function
  24.    (lambda (a / k a-cdr s)
  25.      (if
  26.        (and (setq k (car a))
  27.       (setq a-cdr (cdr a))
  28.       (setq  s (vl-remove '(1002 . "}")
  29.              (vl-remove '(1002 . "{") a-cdr)
  30.         )
  31.       )
  32.       (setq s (mapcar 'cdr s))
  33.        )
  34.         (cons k s)
  35.      )
  36.    )
  37.        )
  38.        app-v
  39.      )
  40.   )
  41.   (setq vs (vl-remove nil vs))
  42.   vs
  43. )
参与人数 2明经币 +2 收起 理由
tigcat + 1 很给力!
ssyfeng + 1 赞一个!
发表于 2024-7-13 13:13:13 | 显示全部楼层
感谢大佬的热心分享~
发表于 2024-7-23 16:34:44 | 显示全部楼层
感谢大佬的热心分享~
GMT+8, 2025-10-19 04:25 , Processed in 0.143609 second(s), 26 queries , Gzip On.
