之前学AutoLisp的时候搞的小插件,转C#,分享一下。
功能:选择单行文字,输入间距/回车,横/竖向对齐文字。
- ;已完成,勿动(-_-!)
- ;根据参数返回点列表按某一坐标轴排序,ordor=1为降序,=0为升序
- (defun pzj:sort(ptlst axis ordor / tmp)
- (setq tmp
- (cond
- ((= axis "x") (vl-sort ptlst '(lambda(a b) (< (car a) (car b)))))
- ((= axis "y") (vl-sort ptlst '(lambda(a b) (< (cadr a) (cadr b)))))
- ((= axis "z") (vl-sort ptlst '(lambda(a b) (< (caddr a) (caddr b)))))
- (if (= ordor 1)
- (reverse tmp)
- tmp
- ;更改文字为左对齐
- (defun pzj:chalignCur(ent)
- (if (not (= (assoc 72 ent) 0))
- (setq ent (entmod (subst (cons 72 0) (assoc 72 ent) ent)))
- (princ)
- ;文字横向对齐
- (defun pzj:dqth(ss dqpt space / i boxpt lst sph)
- (setq i 0)
- (repeat (sslength ss)
- (pzj:chalignCur (entget (ssname ss i)));文字改为左对齐
- (setq
- boxpt (textbox (entget (ssname ss i)))
- lst (cons (list
- (ssname ss i)
- (cdr (assoc 10 (entget (ssname ss i))))
- (1+ (fix (- (nth 0 (nth 1 boxpt)) (nth 0 (nth 0 boxpt)))))
- lst
- );构建((图元名1 对齐点1 字长1) (图元名2 对齐点2 字长2)...)列表
- lst (vl-sort lst '(lambda(a b) (< (nth 0 (nth 1 a)) (nth 0 (nth 1 b)))));((图元名1 对齐点1 字长1) (图元名2 对齐点2 字长2)...)列表按x轴排序,升序
- (setq i (1+ i))
- (setq sph 0)
- (foreach each lst
- (if (= space nil)
- (vla-move (vlax-ename->vla-object (nth 0 each)) (vlax-3d-point (nth 1 each)) (vlax-3d-point (list (car (nth 1 each)) (cadr dqpt) (caddr (nth 1 each)))))
- (progn
- (vla-move (vlax-ename->vla-object (nth 0 each)) (vlax-3d-point (nth 1 each)) (vlax-3d-point (list (+ (car dqpt) sph) (cadr dqpt) (caddr dqpt))))
- (setq sph (+ (+ (nth 2 each) space) sph))
- (princ)
- ;文字纵向对齐
- (defun pzj:dqts(ss dqpt space / i boxpt lst spz)
- (setq i 0)
- (setq
- lst (cons (list
- (ssname ss i)
- (cdr (assoc 40 (entget (ssname ss i))))
- lst
- );构建((图元名1 对齐点1 字高1) (图元名2 对齐点2 字高2)...)列表
- lst (vl-sort lst '(lambda(a b) (> (nth 1 (nth 1 a)) (nth 1 (nth 1 b)))));((图元名1 对齐点1 字高1) (图元名2 对齐点2 字高2)...)列表按轴排序,升序(x轴m=0、y轴m=1、z轴m=2)
- (setq i (1+ i))
- (setq spz 0)
- (foreach each lst
- (if (= space nil)
- (vla-move (vlax-ename->vla-object (nth 0 each)) (vlax-3d-point (nth 1 each)) (vlax-3d-point (list (car dqpt) (cadr (nth 1 each)) (caddr (nth 1 each)))))
- (progn
- (vla-move (vlax-ename->vla-object (nth 0 each)) (vlax-3d-point (nth 1 each)) (vlax-3d-point (list (car dqpt) (- (cadr dqpt) spz) (caddr dqpt))))
- (setq spz (+ (+ (nth 2 each) space) spz))
- ;执行函数
- (vl-load-com)
- (defun c:dq (/ m)
- (initget "s")
- (setq m (getkword "(s)竖向对齐/横向对齐:"))
- (if (= m "s")
- (pzj:dqts (ssget ":L" '((0 . "TEXT"))) (getpoint "\n指定对齐点:") (getreal"\n指定间距:"))
- (pzj:dqth (ssget ":L" '((0 . "TEXT"))) (getpoint "\n指定对齐点:") (getreal"\n指定间距:"))
- (princ)
