查看: 1558|回复: 16
[经验] SLdesign V3.0-lisp安装文件拖入(或复制->粘贴)绘图区安装
发表于 2024-7-30 22:06:09 | 显示全部楼层 |阅读模式
如题:新写一个此功能展示,作为补充安装办法之一。
SLdesign V3.0-lisp安装文件拖入(或复制->粘贴)绘图区自动安装
  1. ;;字符串转表 str 字符串   sign 分割符号----(一级)---------
  2. ;;(str->lst "1 2 3 4" " ")->("1" "2" "3" "4")
  3. ;;(str->lst "毛泽东;88;xy;z" ";")->("毛泽东" "88" "xy" "z")
  4. ;;(str->lst "毛泽东;88;xy;z" "泽东")->("毛" ";88;xy;z")
  5. (defun str->lst (str sign / lst n1 n2 str_1 m2)
  6.   (setq lst '())
  7.   (setq n1 (strlen str))
  8.   (setq n2 (strlen sign))
  9.   (while (setq m2 (vl-string-search sign str))
  10.     (setq str_1 (substr str 1 m2))
  11.     (setq str (substr str (+ 1 m2 n2)))
  12.     (if (/= str_1 "")
  13.       (setq lst (cons str_1 lst))
  14.     )
  15.   )
  16.   (if (/= str "")
  17.     (setq lst (cons str lst))
  18.   )
  19.   (reverse lst)
  20. )
  21. ;;倒置字符串--(一级)-----------
  22. (defun slreverstr (str / a b)
  23.   (setq b "")
  24.   (while (> str "")
  25.     (if (< (ascii (substr str 1 1)) 129)
  26.       (setq b (strcat (substr str 1 1) b) str (substr str 2))
  27.       (setq b (strcat (substr str 1 2) b) str (substr str 3))
  28.     )
  29.   )
  30.   b
  31. )
  32. ;;去除路径最后 "\"---(一级)-----
  33. (defun slpath (str / len)
  34.   (setq str (strcase (slreverstr str)))
  35.   (setq len (strlen str))
  36.   (while (= (substr str 1 1) "\")
  37.     (setq str (substr str 2 (- len 1)))
  38.   )
  39.   (setq str (slreverstr str))
  40.   str
  41. )
  42. ;;添加文件夹到AutoCAD支持搜索路径中的指定位置----(一级)---
  43. ;;(addsearchs sl-path0 2) 第二个后面
  44. ;;(addsearchs sl-path0 nil) 最后
  45. ;;(addsearchs sl-path0 0) 最前
  46. (defun addsearchs (dir pos / tmp c)
  47.   (setq tmp "" c -1)
  48.   (if (not pos)
  49.     (setq tmp (strcat (getenv "ACAD") ";" dir ";"))
  50.     (progn
  51.       (mapcar
  52.         '(lambda (x)
  53.            (setq tmp
  54.              (if (= (setq c (1+ c)) pos)
  55.                (strcat tmp ";" dir ";" x)
  56.                (strcat tmp ";" x)
  57.              )
  58.            )
  59.          )
  60.         (str->lst (getenv "ACAD") ";")
  61.       )
  62.       (setq tmp (strcat (substr tmp 2 (- (strlen tmp) 1)) ";"))
  63.     )
  64.   )
  65.   (setenv "ACAD" tmp)
  66.   (princ)
  67. )
  68. ;;在启动组加入------------
  69. ;(addtostartupsuite "D:\\三领设计\\main.vlx")
  70. (defun addtostartupsuite (appname / $akey $skey n i k)
  71.   (setq
  72.     $skey (strcat "HKEY_CURRENT_USER\" (vlax-product-key) "\\Profiles\" (getvar "CPROFILE") "\\Dialogs\\Appload\\Startup")
  73.     $akey (strcat "HKEY_CURRENT_USER\" (vlax-product-key) "\\Applications\\AcadAppload")
  74.   )
  75.   (setq n (vl-registry-read $skey "NumStartup") i 0 k t)
  76.   (repeat (atoi n)
  77.     (setq i (1+ i))
  78.     (if (= appname (vl-registry-read $skey (strcat (itoa i) "Startup"))) (setq k nil))
  79.   )
  80.   (if k ;无有加
  81.     (progn
  82.       (vl-registry-write $skey "NumStartup" (setq new-n (itoa (1+ (atoi n)))));修改启动组数量
  83.       (vl-registry-write $skey (strcat new-n "Startup") path);添加到启动组
  84.     )
  85.   )
  86.   ;;读取LoadCtrls的值,将这个值与2作“或”运算,再写回。这样可以保证AutoCAD启动时会加载Appload.arx模块。
  87.   (if (setq n (vl-registry-read $akey "LOADCTRLS"))
  88.     (vl-registry-write $akey "LOADCTRLS" (Boole 7 n 2))
  89.     (vl-registry-write $akey "LOADCTRLS" 15)
  90.   )
  91. )
  92. ;;是否在启动组中,有返回路径,无,返回nil
  93. ;;(car (slappload-filepath "D:\\三领设计\\main.VLX"))
  94. (defun slappload-filepath (appname / $skey i keyvalue numstartup svlst)
  95.   (if (member (type appname) '(STR SYM))
  96.     (progn
  97.       (setq $skey (strcat "HKEY_CURRENT_USER\" (vlax-product-key) "\\Profiles\" (getvar "CPROFILE") "\\Dialogs\\Appload\\Startup"))
  98.       (setq numstartup (vl-registry-read $skey "NumStartup"))
  99.       (if (= (type numstartup) 'STR)
  100.         (progn
  101.           (setq  numstartup (atoi numstartup) i 1)
  102.           (repeat numstartup
  103.             (if  (setq keyvalue (vl-registry-read $skey (strcat (itoa i) "Startup")))
  104.               (setq svlst (append svlst (list keyvalue)) i (1+ i))
  105.               (setq i (1+ i))
  106.             )
  107.           )
  108.           (if svlst
  109.             (setq svlst (mapcar 'strcase svlst))
  110.           )
  111.         )
  112.       )
  113.       (member (strcase appname) svlst)
  114.     )
  115.   )
  116. )
  117. ;将此文件拖入(或复制->粘贴)到ACAD绘图区即会自动安装
  118. (defun install (/ sl-env slst n str kk kk1 m1 m2 i path)
  119.   (vl-load-com)
  120.   (print (getvar "lastprompt"))
  121.   (setq sl-path0 (strcase (getvar "lastprompt"))) ;(LOAD "D:/SLDESIGN/将此文件拖入(或复制-粘贴)到ACAD绘图区即会自动安装.LSP")
  122.   (if (wcmatch sl-path0 "*:*\(LOAD "?:*.LSP"\)")
  123.     (setq sl-path0 (reverse (cdr (member (car (vl-string->list """)) (vl-string->list sl-path0))))
  124.       sl-path0 (vl-list->string (reverse (cdr (member (car (vl-string->list "/")) sl-path0))))
  125.       sl-path0 (vl-string-translate "/" "\" sl-path0)
  126.       sl-path0 (if (findfile (strcat sl-path0 "\\main.vlx")) sl-path0 nil)
  127.     )
  128.     (setq sl-path0 nil)
  129.   ) ;"D:\\SLDESIGN" 求得
  130.   (if (not sl-path0)
  131.     (cond
  132.       ((findfile (strcase "D:\\SLdesign\\main.vlx")) (setq sl-path0 "D:\\SLdesign"))
  133.       ((findfile (strcase "D:\\三领设计\\main.vlx")) (setq sl-path0 "D:\\三领设计"))
  134.       ((findfile (strcase "D:\\烩砞璸\\main.vlx")) (setq sl-path0 "D:\\烩砞璸"))
  135.       ((findfile "main.VLX") (setq sl-path0 (vl-filename-directory (findfile "main.VLX"))))
  136.     )
  137.   )
  138.   (if (and sl-path0 (findfile (strcat sl-path0 "\" "main.vlx")))
  139.     (progn
  140.       (setq sl-env (strcase (getenv "ACAD")));;查找支持路径
  141.       (setq slst (str->lst sl-env ";") i (abs (- (length slst) 4)))
  142.       (setq str (slreverstr (car slst)))
  143.       (if (= (substr str 1 1) "\") ;;如果路径后边带\\
  144.         (setq str "\")
  145.         (setq str "")
  146.       )
  147.       (if (or (wcmatch sl-env "*三领设计*") (wcmatch sl-env "*烩砞璸*") (wcmatch sl-env (strcase "*sldesign*")))
  148.         (while slst
  149.           (setq n (car slst))
  150.           (if (or (wcmatch n "*三领设计*") (wcmatch n "*烩砞璸*") (wcmatch n (strcase "*SLdesign*")))
  151.             (progn
  152.               (if (not (wcmatch n (strcase "*Fonts*"))) (setq sl-path0 (slpath n)))
  153.               (if (wcmatch n (strcase "*Fonts*")) (setq path (slpath n)))
  154.               (if (and sl-path0 (findfile (strcat sl-path0 "\" "main.vlx"))) (setq kk t))
  155.               (if (and path (findfile (strcat path "\" "Slhztxt.shx"))) (setq kk1 t))
  156.             )
  157.           )
  158.           (setq slst (cdr slst))
  159.         )
  160.       )
  161.       (if (= kk nil) (addsearchs (strcat sl-path0 str) i))
  162.       (if (= kk1 nil) (addsearchs (strcat sl-path0 "\\Fonts" str) i))
  163.       (if (= (slappload-filepath (strcat sl-path0 "\" "main.VLX") ) nil) ;无启动组,尝试加启动组
  164.         (vl-catch-all-apply '(lambda () (addtostartupsuite (strcat sl-path0 "\" "main.VLX") ))) ;尝试加入启动组,可能失败
  165.       )
  166.       (load (strcat sl-path0 "\" "main.vlx"))
  167.     )
  168.   )
  169. )
  170. (install)
似乎论坛发代码功能,有误了。
SLdesign V3.0
链接:https://pan.baidu.com/s/1s1XneKS9KJEMExJT1dudVg
提取码:aqhv
参与人数 2明经币 +2 收起 理由
baitang36 + 1 很给力!
tranque + 1 很给力!
发表于 2024-7-30 22:20:39 | 显示全部楼层
感谢,这是付费使用的吗
不用目前  发表于 2024-7-30 22:27
发表于 2024-7-31 07:23:06 来自手机 | 显示全部楼层
免费使用功能最多的插件
发表于 2024-7-31 07:39:31 | 显示全部楼层
经常调试lisp,能不能做个程序,让放在特定文件夹中的lisp在修改后 再次刷新cad能自动重新加载修改后的程序?
三领就支持,专门为用户定制一个文件夹,只要用户程序放进去,就启动自动加载,基本插件都有这功能的。 也就是,支持用户自由扩展....  发表于 2024-7-31 22:42
发表于 2024-7-31 09:31:24 | 显示全部楼层
支持尘缘大佬,感谢分享
我将继续打造成完美的工具箱,为此不懈努力了31年了。  发表于 2024-7-31 22:45
发表于 2024-7-31 12:50:30 | 显示全部楼层
前几天,三个版共装好几遍都装不上;已成功装上,提示超过试用次数,注册?
只不过是广告罢了,最终,就会全免费了。  发表于 2024-7-31 13:44
安装问题,经过研究啊,已解决BUG,关于提示的次数啊,注册,不用管,直接用即可。  发表于 2024-7-31 13:43
发表于 2024-7-31 13:59:56 | 显示全部楼层
dear sir
Thanks for sharing
发表于 2024-7-31 16:31:33 | 显示全部楼层
看了一下是极具个人风格的工具箱,就是这个试用提醒影响到测试
画图纸的我写的,你说呢?当然,有点难度,不好入门,因为已经很多年轻人不知道这种画图方式了。  发表于 2024-7-31 22:44
GMT+8, 2025-4-23 06:03 , Processed in 0.194664 second(s), 36 queries , Gzip On.
