查看: 549|回复: 1
[提问] 求助大佬以下代码怎么改能实现也可以刷属性块?
发表于 2024-8-3 22:41:02 | 显示全部楼层 |阅读模式
;;;以下代码的效果可不可以也能刷属性块?
;;;代码为本论坛收集,如有冒犯,请多关照
(defun c:tt2 ()
(if (and (setq s0 (entsel "\n选择首字串 :"))
          (setq ent1 (entget(car s0)))
          (= (cdr(assoc 0 ent1)) "TEXT")) (progn
  (setq tx1 (cdr(assoc 1 ent1))
        txt1 (substr tx1 (strlen tx1) 1))
  (while (and (setq s1 (entsel "\n选择字串 :"))
             (setq ent (entget(car s1)))
             (= (cdr(assoc 0 ent)) "TEXT"))
   (cond
    ((= txt1 "Z") (setq txt1 "a"))
    ((= txt1 "z") (setq txt1 "A"))
    (T (setq txt1 (chr (1+ (ascii txt1)))))
   (setq txt (cdr(assoc 1 ent))
         txt (strcat (substr txt 1 (1- (strlen txt))) txt1)
         ent (subst (cons 1 txt) (assoc 1 ent) ent))
   (entmod ent)
发表于 2024-8-4 00:14:28 | 显示全部楼层
逻辑完全不一样的 需要知道属性块中的标记名称
GMT+8, 2025-4-23 05:57 , Processed in 0.160874 second(s), 25 queries , Gzip On.
