查看: 919|回复: 2
[提问] 注释比例的创建方法
发表于 2024-8-8 10:35:05 | 显示全部楼层 |阅读模式
以下两种是注释比例的方法,都存在错误。第一种保存后才能看到结果。第二种所有都是注释比例。
;(addscale (car(entsel)) "1:2")
(defun AddScale (object scale / DefineNewDictHandle)
  (defun MultipleAssoc (key alist / x nlist)
    (foreach x alist
      (if (eq key (car x))
        (setq nlist (cons (cdr x) nlist))
    (reverse nlist)
  (defun LM:annoscales ( ent / dic enx itm rtn )
    (if
      (and
        (setq enx (entget ent))
        (setq dic (cdr (assoc 360 (cdr (member '(102 . "{ACAD_XDICTIONARY") enx)))))
        (setq dic (cdr (assoc -1 (dictsearch dic "acdbcontextdatamanager"))))
        (setq dic (cdr (assoc -1 (dictsearch dic "acdb_annotationscales"))))
      (while (setq itm (dictnext dic (not itm)))
        (setq rtn (cons (cdr (assoc 300 (entget (cdr (assoc 340 itm))))) rtn))
    (reverse rtn)
  (defun DefineNewDictHandle(lst / leeter numbre handles retVal)
    (foreach letter '("A" "B" "C" "D" "E" "F" "G" "H" "I" "J" "K")
      (foreach number '(0 1 2 3 4 5 6 7 8 9)
        (setq handles (cons (strcat "*" letter (itoa number)) handles))
    (setq handles (reverse handles))
    (while (member (setq retVal (car handles)) lst) (setq handles (cdr handles)))
    retVal
  (and
    (not (member scale (LM:annoscales object)))
    (setq enx (entget object))
    (setq dicLv1 (cdr (assoc 360 (cdr (member '(102 . "{ACAD_XDICTIONARY") enx)))))
    (setq dicLv2 (cdr (assoc -1 (dictsearch dicLv1 "acdbcontextdatamanager"))))
    (setq dicLv3 (cdr (assoc -1 (dictsearch dicLv2 "acdb_annotationscales"))))
    (setq handle (DefineNewDictHandle (MultipleAssoc 3 (entget diclv3))))
    (dictadd dicLv3
             handle
             (entmakex (list
                         ;((-1 . <图元名: 374da810>)
                        ;单行文字
;;;                         '(0 . "ACDB_TEXTOBJECTCONTEXTDATA_CLASS")
;;;                         '(102 . "{ACAD_REACTORS")
;;;                         (cons 330 dicLv3)
;;;                         '(102 . "}")
;;;                         '(100 . "AcDbObjectContextData")
;;;                         '(70 . 4)
;;;                         '(290 . 1)
;;;                         '(100 . "AcDbAnnotScaleObjectContextData")
;;;                         (cons 340 (entmakex (list '(0 . "SCALE")
;;;                                                   (cons 330 (cdr (assoc -1 (dictsearch (namedobjdict) "ACAD_SCALELIST"))))
;;;                                                   '(102 . "}")
;;;                                                   '(100 . "AcDbScale")
;;;                                                   '(70 . 0)
;;;                                                   (cons 300 scale)
;;;                                                   (cons 140 (atoi scale))
;;;                                                   (cons 141 (atoi(substr scale (+ (vl-string-search ":" scale) 2))))
;;;                                                   '(290 . 0))))
;;;                         '(70 . 0)
;;;                         '(50 . 0.0)
;;;                         '(10 934.317 5247.03 0.0)
;;;                         '(11 0.0 0.0 0.0)
                         ;((-1 . <图元名: 374dab80>)
                        ;多行文字
                         '(0 . "ACDB_MTEXTOBJECTCONTEXTDATA_CLASS")
                         ;'(5 . "4308")
                         (cons 330 dicLv3)
                         '(102 . "}")
                         (cons 330 dicLv3)
                         '(70 . 4)
                         '(290 . 0)
                                                   '(102 . "}")
                                                   '(70 . 0)
                                                   (cons 300 scale)
                                                   '(290 . 0))))
                         '(70 . 1)
                         '(10 1.0 0.0 0.0)
                         '(11 955.258 5258.21 0.0)
                         '(40 . 11.8314)
                         '(41 . 0.0)
                         '(42 . 0.396199)
                         '(43 . 0.140176)
                         '(71 . 2)
                         '(72 . 1)
                         '(44 . 11.8314)
                         '(45 . 0.685909)
                         '(73 . 0)
                         '(74 . 0)
                         '(46 . 0.0)
    (entupd object)
(defun c:addt (/ blocks AcDbBlockTableRecord AcDbEntity)
  (setq blocks (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))))
  ; set annotative text style to be current
  (setvar "textstyle" "Annotative")
  (vlax-for AcDbBlockTableRecord blocks
    (vlax-for AcDbEntity AcDbBlockTableRecord
      (if(eq (vla-get-objectName AcDbEntity) "AcDbMText")
          (setq text (vla-get-textString AcDbEntity))
          (setq p0 (vla-get-insertionPoint AcDbEntity))
          (setq hgt (vla-get-height AcDbEntity))
          (setq obj (vla-addtext AcDbBlockTableRecord text p0 hgt))  ; add new text, annotative = yes
          (vla-delete AcDbEntity) ; remove old text
          ); progn
        ); if
      (vlax-release-object AcDbEntity)
      ); vlax-for
    (vlax-release-object AcDbBlockTableRecord)
    ); vlax-for
  (vlax-release-object blocks)
  ; globally apply annotation scales to annotative objects
  (setvar "cannoscale" "1:2")
  (setvar "cannoscale" "1:5")
  (setvar "cannoscale" "1:10")
发表于 2024-8-8 11:23:13 | 显示全部楼层
虽然看不懂,但是顶一个
 楼主| 发表于 2024-8-15 13:39:59 | 显示全部楼层
(defun AddScale (object scale / DefineNewDictHandle dicLv2 m1:1)
        (setq handles (cons (strcat "*" letter (itoa number)) handles))))
    (setq handles (cdr(reverse handles)))
    retVal)
  (setq dicLv2 (entget(cdr (assoc 350 (entget(cdr (assoc 360  (entget(cdr (assoc 360 (entget object)))))))))))
  (setq m1:1 (cdr(assoc 350 dicLv2)))
  (setq dicLv2 (append dicLv2 (list (cons 3 (DefineNewDictHandle (apply 'append(mapcar '(lambda(x)(if(=(car x)3)(list(cdr x)))) dicLv2))))(cons 350 m1:1))))
  (entmod dicLv2)
还是不成功
GMT+8, 2025-4-23 12:39 , Processed in 0.170324 second(s), 25 queries , Gzip On.
