查看: 613|回复: 1
[源码] 这个lsp 能修剪框选内的对象 如何添加修剪填充功能
发表于 2024-8-18 15:17:05 | 显示全部楼层 |阅读模式
  • 此函数如何添加修剪填充的功能呢  研究了半天无奈求助   感谢各位大侠
  • ;★DB_KSDEL  用矩形剪切矩形里的所有线条,留下矩形框
  • ;by 马开金
  • (defun c:DB_KSDEL (/ p1 p2 p3 p4 dst ang p1a p2a p3a p4a lst)
  •   (PRINC "\n用矩形剪切矩形里的所有线条功能")
  •   (cmdla0)
  •   (setq p1 (getpoint "\n-->请点取矩形框的第一点:")
  •     p2 (getcorner p1 "\n-->请点取矩形框的另一点:")
  •   (setvar "osmode" 0)
  •   (command "undo" "be")
  •   (command "rectang" p1 p2)
  •   (setq lst (entlast))
  •   (setq p3 (list (car p2) (cadr p1))
  •     p4 (list (car p1) (cadr p2))
  •     dst (/ (distance p1 p2) 100.0)
  •     ang (angle p1 p2)
  •     p1a (polar p1 ang dst)
  •     p2a (polar p2 ang (- 0 dst))
  •     p3a (list (car p2a) (cadr p1a))
  •     p4a (list (car p1a) (cadr p2a))
  •   (command "_.trim" lst "" "f" p1a p3a p2a p4a p1a "" "")
  •   (command "_erase" "all" "_r" "_c" p1 p2 "")
  •   (command "_erase" "_w" p1 p2 "")
  •   (command "undo" "e")
  •   (cmdla1)
  • (defun CMDLA0 ()
  •   (setq cmd (getvar "CMDECHO"))
  •   (setq oom (getvar "orthomode"))
  •   (setq osm (getvar "osmode"))
  •   (setq hlt (getvar "highlight"))
  •   (setq rmode (getvar "regenmode"))
  •   (setvar "regenmode" 0)
  •   (setvar "CMDECHO" 0)
  •   (princ)
  • (defun CMDLA1 ()
  •   (setvar "CMDECHO" cmd)
  •   (setvar "orthomode" oom)
  •   (setvar "osmode" osm)
  •   (setvar "highlight" hlt)
  •   (setvar "regenmode" rmode)
  •   (PRINC "\n修剪完成")(PRINC))
 楼主| 发表于 2024-8-18 15:19:54 | 显示全部楼层
参考了G版的帖子  但是TT函数 修剪时没法指定修剪的方向
;框内物体删除 By Gu_xl
(defun c:tt (/ OS P1 P2 CP SS ENREC N *error*)
   (defun *error* (s)
     (setvar "osmode" os)
     (princ s)
   (setq os (getvar "osmode"))
   (setvar "osmode" 0)
   (setq p1 (getpoint "\n指定基点:"))
   (setq p2 (getcorner p1 "\n指定对角点:"))
   (setq cp (mapcar '* '(0.5 0.5 0.5) (mapcar '+ p1 p2)))
   (setq ss (ssget "w" p1 p2))
   (if ss (command "erase" ss ""))
   (setq enRec (entlast))
   ;;重复5次,以保证剪切干净
  (repeat 5
   (setq ss (ssget "c" p1 p2))
     (ssdel enRec ss)
   (command ".trim" enRec "")
   (repeat (setq n (sslength ss))
     (command (list (ssname ss (setq n (1- n))) cp))
   (command "")
   ;;删除绘制的方框
  (entdel enRec)
GMT+8, 2025-4-23 05:57 , Processed in 0.141796 second(s), 26 queries , Gzip On.
