查看: 822|回复: 1
[讨论] 关于U盘获取PNPDeviceID会变问题
发表于 2024-8-26 10:21:15 | 显示全部楼层 |阅读模式
http://bbs.mjtd.com/forum.php?mo ... mp;extra=#pid992500(2019.5.27上传优化版示例-仅供参考)全盘符选择注册加密代码
fangmin723 大师的全盘符选择注册加密代码 中发现部分U盘申请发会变法,在不同中计算出来的 (vlax-get n 'PNPDeviceID) 中含有&连接符号,就会导致LST1会变法。
我自己电脑获取的为 ((2 "6&26BC55B9&0&_&0"))
我朋友电脑获取的为 ((2 "6&2CB6BAA1&0&_&0"))
请大师们是什么问题造成的。
        (defun BF-str->lst        (str del / pos)
                (if        (setq pos (vl-string-search del str))
                        (cons (substr str 1 pos)
                                (BF-str->lst (substr str (+ pos 1 (strlen del))) del)
                        (list str)
        (defun bf-LIST-SORT (lst oper / x1 x2)
                (vl-sort lst
                        '(lambda (x1 x2)
                                 (if
                                         (and
                                                 (atom x1)
                                                 (atom x2)
                                         (apply oper (list x1 x2))
                                         (apply oper (list (car x1) (car x2)))
(defun getpathsn(/ drives found fso lst lst1 meth1 meth2 meth3 n path pclst pflst serialnumber uplst volumename wmi)
                ;;;↓↓↓↓↓↓↓↓获取PC序列号↓↓↓↓↓↓↓↓
                (setq fso (vlax-create-object "Scripting.FileSystemObject"))
                (setq Drives (vlax-get-property fso "Drives") pclst nil uplst nil)
                (vlax-for n drives
                        (and
                                (= 2 (vlax-get-property n 'DriveType));2 DriveType 本地磁盘
                                (setq Path (vlax-get-property n 'Path))
                                (setq SerialNumber (vl-princ-to-string(vlax-get-property n 'SerialNumber)))
                                (setq pclst (cons (list (vl-string-trim "\" :" Path) (strcat "PC" (substr (sernumConfused SerialNumber) 1 16))) pclst));电脑盘符路径及序列号表
                ;;;↓↓↓↓↓↓↓↓获取UP序列号↓↓↓↓↓↓↓↓
                (setq
                        WMI (vlax-create-object "WbemScripting.SWbemLocator")
                        meth1 (vlax-invoke WMI 'ConnectServer nil nil nil nil nil nil nil nil)
                        meth2 (vlax-invoke meth1 'ExecQuery "Select * from Win32_LogicalDisk Where DriveType = 2" nil nil nil)
                        meth3 (vlax-invoke meth1 'ExecQuery "Select * from Win32_DiskDrive Where InterfaceType = 'USB'" nil nil nil)
                ;;获取盘符 Name DeviceID
                (setq lst nil)
                (vlax-for n meth2
                        (setq lst (cons (substr (vlax-get n 'Name) 1 1) lst))
                (setq lst1 nil)
                (vlax-for n meth3
                        (setq lst1
                                (cons
                                        (list
                                                (vlax-get n 'Index)
                                                (car (reverse (BF-str->lst (vlax-get n 'PNPDeviceID) "\\")))
                                        lst1
                (foreach obj (list WMI meth1 meth2 meth3) (if obj (vlax-release-object obj)))
                (setq lst (vl-sort lst '<) lst1 (bf-LIST-SORT lst1 '<) n 0)
                (repeat (length lst)
                        (setq uplst (cons (list (nth n lst) (strcat "UP" (substr (sernumConfused (cadr (nth n lst1))) 1 16))) uplst))
                        (setq n (1+ n))
                        (PRINC lst1)
                (foreach x pclst (if (= (car x) "C") (setq pflst (append (list (list "PC" (cadr x))) (reverse uplst)))));盘符表
发表于 2024-8-26 15:46:20 | 显示全部楼层
PNPDevideID是系统给的,不是硬件自带的,所以换系统肯定会变。
GMT+8, 2025-4-23 06:03 , Processed in 0.184642 second(s), 28 queries , Gzip On.
