查看: 748|回复: 4
[提问] 请问大佬附件这个怎么改
发表于 2024-8-29 14:44:47 | 显示全部楼层 |阅读模式
[ 本帖最后由 惜惜2 于 2024-9-5 08:06 编辑 ]\n\n[ 本帖最后由 惜惜2 于 2024-8-30 21:50 编辑 ]\n\n目前的方式是需要先指定显示的层,再框选需要导出的文件。
希望公式里面默认0层然后直接导出,不用框选,不用选层这一步,感谢
发表于 2024-8-30 09:05:12 | 显示全部楼层
惜惜2 发表于 2024-8-30 08:30
(DEFUN C:V2 (/ ES EN EL A getv getv2 getv3 str)
  ;(PRINC "请选择对象,未被选中的对象所在的层将 ...
摸索一下,有利于理解
 楼主| 发表于 2024-8-30 08:30:09 | 显示全部楼层
惜惜2 发表于 2024-8-29 15:47
自动存这一步能不能默认是0层呢  这个还是需要框选
  ;(PRINC "请选择对象,未被选中的对象所在的层将被关闭(显示指定层)")
  (setq ES (SSGET "x" '((8 . "0"))))
  (setq A 0)
  (setq EN "")
  (setq EL nil)
  (setq FL nil)
  (while (and (/= EN nil))
    (setq EN (SSNAME ES A))
    (setq EL (CONS EN EL))
    (setq A (1+ A))
  (setq EL (CDR EL))
  (setq FL (CDR (ASSOC 8 (ENTGET (CAR EL)))))
  (setq EL (CDR EL))
  (REPEAT (- A 2)
    (setq EN (CDR (ASSOC 8 (ENTGET (CAR EL)))))
    (setq FL (STRCAT EN "," FL))
    (setq EL (CDR EL))
  (command "LAYER")
  (command "off")
  (command "*")
  (command "y")
  (command "on")
  (command (EVAL FL))
  (command "")
  (setvar "cmdecho" 0)
  (princ "\n功能 [自动存DXF档]")
  (setq getv  (getvar "DWGPREFIX")
      getv2 (getvar "DWGNAME")
      getv3 (getvar "FILEDIA")
  (setq str (strcat getv (vl-filename-base getv2) ".dxf"))
  (setvar "FILEDIA" 0)
  (vl-cmdf "_.dxfout" str "O" (ssget "x" '((8 . "0"))))
  (setvar "FILEDIA" getv3)
  (command "")
  (command "16")
用这个可以了
 楼主| 发表于 2024-8-29 15:47:30 | 显示全部楼层
咏郡 发表于 2024-8-29 15:41
(DEFUN C:V1 (/ ES EN EL A getv getv2 getv3 str)
  ;(PRINC "请选择对象,未被选中的对象所在的层将被关 ...
发表于 2024-8-29 15:41:39 | 显示全部楼层
  (setq A 0)
  (setq EN "")
  (setq EL nil)
  (setq FL nil)
    (setq A (1+ A))
  (setq EL (CDR EL))
  (setq EL (CDR EL))
  (REPEAT (- A 2)
    (setq EL (CDR EL))
  (command "LAYER")
  (command "off")
  (command "*")
  (command "y")
  (command "on")
  (command (EVAL FL))
  (command "")
  (vl-cmdf "_.dxfout" str "O" (ssget) "" "")
GMT+8, 2025-4-23 05:57 , Processed in 0.143798 second(s), 27 queries , Gzip On.
