查看: 1332|回复: 4
[提问] 菜鸟请教取值问题
发表于 2024-9-30 13:39:38 | 显示全部楼层 |阅读模式
(defun c:tt ( / d obj )
  (setq d (getdist "\n偏移距离: "))
  (while (setq obj (vlax-ename->vla-object (car(entsel))))
      (vl-catch-all-apply 'vla-offset (list obj (- d)))
      (vl-catch-all-apply 'vla-offset (list obj d))
      (vl-Catch-All-Apply 'vlax-put-property (list obj 'color 1))
这两行里面的d值怎么取上面d的0.5倍。((setq d (getdist "\n偏移距离: ")))
发表于 2024-9-30 13:42:26 | 显示全部楼层
直接(* 0.5 d)不行吗
发表于 2024-9-30 13:42:43 | 显示全部楼层
        (setq d (* 0.5 d))
发表于 2024-9-30 13:49:14 | 显示全部楼层
      (vl-catch-all-apply 'vla-offset (list obj (* -0.5 d)))
      (vl-catch-all-apply 'vla-offset (list obj (* 0.5 d)))
      (vl-catch-all-apply 'vlax-put-property (list obj 'color 1))
 楼主| 发表于 2024-10-8 20:05:57 | 显示全部楼层
谢谢各位大佬指点
GMT+8, 2025-11-29 07:49 , Processed in 0.149207 second(s), 24 queries , Gzip On.
