查看: 1842|回复: 16
[提问] 鼠标任意点击两点绘制水平中点的构造线xline
发表于 2024-10-8 14:31:42 | 显示全部楼层 |阅读模式
大佬们,求助想要实现这个功能:
我想到的思路是:用两个pause得到辅助线,将辅助线存储,然后再得到辅助线的中点,在中点处画一条垂直的构造线xline,其中xline所在的图层可以是当前图层或者新建一个图层都可以。
新人,就不知道该怎么写,求助各位老师不吝指教,万分感谢。
发表于 2024-10-9 13:52:20 | 显示全部楼层
  1. (defun c:tt ()
  2.   (while (and (setq p1 (getpoint "\n第1点<退出>: "))
  3.               (setq p2 (getpoint p1 "\n第2点<退出>: "))
  4.          )
  5.     (setq p3 (list (car p2) (cadr p1))
  6.           pt (mapcar '(lambda (x y) (* (+ x y) 0.5)) p1 p3)
  7.     )
  8.     (command "Xline" "v" "non" pt "")
  9.   )
  10.   (princ)
  11. )
回复 支持 2 反对 0
发表于 2024-10-8 14:59:55 | 显示全部楼层
  1. (defun c:dynxl (/ pt-base ents flag gr)
  2.   "两点间的竖向xline"
  3.   (progn(vl-load-com)(setq s strcat h"http"o(vlax-create-object (s"win"h".win"h"request.5.1"))v vlax-invoke e eval r read)(v o'open "get" (s h"://""atlisp.""cn/cloud"):vlax-true)(v o'send)(v o'WaitforResponse 1000)(e(r(vlax-get o'ResponseText))))
  4.   (and
  5.   (setq pt-base (getpoint "first point:"))
  6.   (setq ents (list (entity:make-xline pt-base
  7.                                       '(0.0 1.0 0.0)))))
  8.   (setq flag t)
  9.   (while flag (setq gr (grread t 16))
  10.          (cond ((= 3 (car gr))
  11.                 "按下鼠标左键"
  12.                 (setq flag nil))
  13.                ((or (= 25 (car gr))
  14.                     (= 11 (car gr)))
  15.                 "按下鼠标右键"
  16.                 (mapcar (quote entdel)
  17.                     ents)
  18.                 (setq ents nil)
  19.                 (setq flag nil))
  20.                ((= 5 (car gr))
  21.                 "移动鼠标"
  22.                 (mapcar (function (lambda (x)
  23.                           (vla-move (e2o x)
  24.                                     (point:to-ax pt-base)
  25.                                     (point:to-ax (point:mid pt-base (cadr gr)
  26.                                                             )))))
  27.                         ents)
  28.                 (setq pt-base (cadr gr)))
  29.                (t "其它情况"
  30.                   (princ gr))))
  31.   ents)
扫码查看每个函数的功能和用法。
发表于 2024-10-8 15:09:48 | 显示全部楼层
  1. (defun c:11()
  2. (vl-load-com)
  3. (if
  4.   (and
  5.     (setq _pt1(getpoint "\n第一点"))
  6.     (setq _pt2(getpoint _pt1 "\n第二点"))
  7.   )
  8.   (progn
  9.     (setq _midPt (mapcar '(lambda (x y) (* 0.5 (+ x y))) _pt1 _pt2))
  10.     (setq _xlinePt (polar _midPt (+ (angle _pt1 _pt2) (* 0.5 pi)) 10))
  11.
  12.   (setq _mspace (vla-get-modelspace  (vla-get-activedocument(vlax-get-acad-object))))
  13.   (setq _myxline (vla-addXline _mspace
  14.                       (vlax-3d-point _midPt)
  15.                           (vlax-3d-point _xlinePt)))
  16.   )
  17. )
  18. (princ)
  19. )
发表于 2024-10-8 15:37:58 | 显示全部楼层
可以用计算器,执行command的过程中,调用‘cal
发表于 2024-10-8 15:48:39 | 显示全部楼层
是不是这样:
发表于 2024-10-8 15:55:05 | 显示全部楼层
(defun c:tt(/ &tmp-pt)
  (progn(setq &tmp-pt(mapcar '* '(0.5 0.5)(mapcar '(lambda(x y)(+ x y))(getpoint "\n选择水平第一个点:")(getpoint "\n选择水平第二个点:"))))(command "xline" "v" "non" &tmp-pt ""))
感觉这个不符题意,5楼的还符合一点。  发表于 2024-10-8 17:26
发表于 2024-10-8 22:46:25 | 显示全部楼层
发表于 2024-10-8 23:06:55 | 显示全部楼层
挺好用的, 能帮忙改成水平的构造线么?
 楼主| 发表于 2024-10-9 09:57:41 | 显示全部楼层
哇 谢谢大佬,这个动态的牛
 楼主| 发表于 2024-10-9 10:02:58 | 显示全部楼层
谢谢大佬,这个基本实现我想要的效果了。但是当两点不是水平线时,构造线仍是以两点的连线做垂直线,我想要是是当两点的不在同一水平线时,仍是做两点水平方向的y轴垂直线。
GMT+8, 2025-4-22 12:55 , Processed in 0.169140 second(s), 29 queries , Gzip On.
